Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Local / Regional / National > USA > North Western States
North Western States Alaska, Idaho, Montana, Oregon, and Washington.
Old 03-19-2010, 09:56 AM   #1
supra33202
supra33202 has made poor choicessupra33202 has made poor choicessupra33202 has made poor choicessupra33202 has made poor choicessupra33202 has made poor choicessupra33202 has made poor choices
A'PEXi POWER FC W/ COMMANDER tuner in San Francisco Bay Area
I am looking for a tuner for A'PEXi POWER FC W/ COMMANDER in San Francisco Bay Area. I have a S13 with SR20DET engine.
I called Performance Option in Oakland, but he said the tuner went to LA.
Thanks!
supra33202 is offline   Reply With Quote
Old 04-05-2010, 01:13 AM   #2
wildkong
wildkong's Avatar
wildkong is an unknown quantity at this point
try z garage in san jose
wildkong is offline   Reply With Quote
Old 04-13-2010, 11:38 AM   #3
Darrinyuan
Darrinyuan is an unknown quantity at this point
power fc
Thanks!
Hi,I have s14 with same set up,should we go la and get tun for the car?Give me a call at 415-623-9935,let's go together.
Darrinyuan is offline   Reply With Quote
Old 04-13-2010, 12:17 PM   #4
supra33202
I actually went to BlackTrax - Import & Domestic Tuning - Milpitas, CA.
The previous owner of the car told me the car got tuned by XS engineering in LA already. And Jei from Blacktrax told me that the car was tuned very good already, and he just pull out some fuels in idling.
This is my first turbo car, and Jei from Blacktrax told me that I can't expect to have perfect factory tuning. But I still need to crank 2 to 3 times when I first start the car in cold temperature. Other than that, my car runs fairly well.
I think Blacktrax is pretty honest about their service. Jei only changed me 1 hour of tuning since there is not much to tune. And I do understand that auto shop usually need to charge minimum 1 hr of labor even though they did less than 1 hr of work.
Old 04-13-2010, 12:24 PM   #5
slider2828
slider2828's Avatar
Sorry blacktrax sucks HORRIBLY.... their work on any other car is basically shotty... and they tune on dynapaks... come on .... Junk....
Contact SteveShadows for a base tune... Will drive 10000% times better and cheaper too....
If you gonna go to LA, go to him....
Also there are no good tuners really in the bay area any more
Turn and Burn!
Old 04-13-2010, 12:25 PM   #6
slider2828
slider2828's Avatar
I crank 1 time and it turns on and idles at 1k cause I have bigger cams, but you shouldn't need to crank 2 - 3 times....
You can go into your crank settings and increase fuel...
Turn and Burn!
Old 04-13-2010, 12:29 PM   #7
slider2828
slider2828's Avatar
If you need help, I can help you out.... and probably help you run things smoother, but just get a base map from Steve and that will help a lot too
Turn and Burn!
Old 04-13-2010, 12:51 PM   #8
supra33202
So there is an option called "crank settings" in the handheld commander?
Sometime, my car would hunt for the rpms (between 1k to 1.4k rpm) when idling. It happens in both cold and warm weather. The handheld commander shows that the ignition timing also fluctuating when idling.
Is that something I need to live with? Or is there a way I can fix it?
The full spec of the car that I just bought:
http://zilvia.net/f/cars-sale/290807...whp-daily.html
Old 04-13-2010, 01:23 PM   #9
slider2828
slider2828's Avatar
If you want, I can help you fix it a little but with 256's, its shouldn't hunt at all or rarely... PM me and maybe I can swing by an d taking a look
Turn and Burn!
Old 04-13-2010, 02:20 PM   #10
supra33202
Could you take a look at my dyno chart? Is my AFR safe for drifting/tracking?
http://zilvia.net/f/engine-tech/3139...no-charts.html
I have the abf files (Dynopack 300) from the dyno shop.
I uploaded the abf files here.
29-Mar-2010 18^11^51_1.abf
29-Mar-2010 18^17^18_2.abf
http://www.blacktrax.net/downloads/Viewer.zip
This is where I downloaded the dynapack viewer.
Old 04-13-2010, 02:22 PM   #11
supra33202
slider2828, I just pmed you.
Thanks for the help!
Old 04-16-2010, 10:41 AM   #12
Darrinyuan
I have the almost same set up like yours,but I have gt30r turbo and hks 244/272 stage 2 cam,I only making 336/285 whp and tq.I tuned at Fremont,and I don't think with my set up only make that less hp,but that is mustang dyno,so I plan to go la and find a best tunner to tune it.
Old 05-16-2010, 03:16 AM   #13
RACETUNE
RACETUNE's Avatar
RACETUNE is on a distinguished road
Send a message via AIM to RACETUNE
Thanks!
If you are still interested, hit me up.
-Frank
-Garage BOSO-
-Racetune Engineering-
RACETUNE is offline   Reply With Quote
Old 05-25-2010, 03:18 PM   #14
Darrinyuan
I might go la to xs tuning.
Old 05-25-2010, 05:32 PM   #15
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
Dynospot Racing in San Jose is a really good shop. Lynn really knows his stuff. (408) 271.9800.
DJPimpFlex is offline   Reply With Quote
Old 06-10-2010, 11:42 PM   #16
juicyjosh
juicyjosh's Avatar
juicyjosh is an unknown quantity at this point
Another option:
Steve Kan (Bay Area) Tuning Interest Date Uknown - Page 13 - RX7Club.com
He's tuned my FD a few times at various points in my build. He also tunes piston engines, all via Datalogit. There's a couple slots left for the tuning session that's coming up.
juicyjosh is offline   Reply With Quote
Old 06-11-2010, 12:00 AM   #17
supra33202
Thanks! Nice to see more tuner options.
Old 06-15-2010, 10:02 AM   #18
Darrinyuan
I got tuning on Tech 3 at San Jose by Ryant,now I got 380 whp and 332 wht for my daily drive s14.
Old 07-07-2010, 01:32 AM   #19
510-SR20DET
510-SR20DET's Avatar
510-SR20DET is an unknown quantity at this point
Any one have heard Frank? who is he? I keep hearing his name mention at performance options. he suppose to be the tuner come up here from LA.
Whats the real name of Steve Shadow?
Originally Posted by EDaciouSX
You should fix your opor grammar.
510-SR20DET is offline   Reply With Quote
Old 07-07-2010, 11:04 AM   #20
K_style
K_style's Avatar
Trader Rating: (63)
Feedback Score: 63 reviews
Are you talking about Frank Siharath from Garage Boso ??
He is awesome... he tuned my S14 and I love it !!!
Old 07-08-2010, 02:03 AM   #21
510-SR20DET
i dont know if he's from Garage Boso. I just heard his name being mentioned at Performance Options.
Old 07-23-2010, 02:04 AM   #22
darius_tii
darius_tii's Avatar
darius_tii has a spectacular aura aboutdarius_tii has a spectacular aura aboutdarius_tii has a spectacular aura aboutdarius_tii has a spectacular aura aboutdarius_tii has a spectacular aura aboutdarius_tii has a spectacular aura about
Send a message via AIM to darius_tii
Frank.
http://wolfreign.wordpress.com
Darius
darius_tii is offline   Reply With Quote
Old 07-23-2010, 02:26 AM   #23
sidedrifts13
sidedrifts13's Avatar
Trader Rating: (29)
Feedback Score: 29 reviews
Frank at garage boso is great at tunning
sidedrifts13 is offline   Reply With Quote
Old 07-27-2010, 04:35 AM   #24
510-SR20DET
How much did you have to pay to have Frank to tune your car?
They charge me $800 just for Frank to show up, not even touch the car yet. Tuning would be another $400. F that, he aint god.
Old 08-11-2010, 02:28 AM   #25
510-SR20DET
I take it back, Frank is a supper cool and good tuner. Even though its expensive to get him up here to tune but i guess it better then having headache.
Old 08-11-2010, 02:48 AM   #26
K_style
K_style's Avatar
Trader Rating: (63)
Every penny is worth it with Frank... that's all I can say !!!!
where did you get your car tuned ? did you rent dyno or something ?
Old 08-11-2010, 03:06 AM   #27
sidedrifts13
Trader Rating: (29)
Frank is legit
Old 08-18-2010, 03:35 AM   #28
RACETUNE
RACETUNE's Avatar
Thanks for the Great comments, well for all of you that don't know me. I owned a shop called Racetune Engineering in Hayward, then moved to Los Angeles and opened up Garage BOSO with Ross Petty. I work with alot of the of the Professional level cars and help out many performance shops.
For all of you that know there are many Standalone systems out there, here is alittle about some of the ones I mostly do.
-Apexi Power Excel Tuner ( I have the proper experience and certifications from Apexi)
-AEM EMS Factory Trained (since 2003)
-HKS V-Pro (very few people can tune this)
-Motec systems (I am also a Certified Tuner)
Below is a list of some cars that i have tuned:
- Garage BOSO Rasta S15 piloted by Ross Petty{APEXI Power FC}(my shop car)
- Falken Tire S15 {HKS VPRO}(originally the HKS S15 you see in D1GP back in the day)
- Megan Racing S13 piloted by Cyrus M. {Vi-Pec ECU}
- Megan Racing AE86 Piloted by Taka Aono {Motec M800}
- Falken Tire RX-7 piloted by Calvin Wan {Apexi Power FC}
- many more...............
Well I enjoy what I do and I do love the Bay Area, so every time I going to the up I always make time to help out Performance Options. They are great people and very honest and they know their shit!! Anyway, i am hella tired. got to get ready for Formula Drift Vegas..
-Garage BOSO-
Old 08-18-2010, 03:58 AM   #29
510-SR20DET
To all people around bay area who own SR, you should bring your car to Performance Options and have Frank tune it for you. All your problems will be disappear. talk to Big or Joey at PO, dont talk to Eddy cause he aint know shit eventho he's the boss.
Old 07-06-2016, 05:51 PM   #30
hellaslows13
hellaslows13's Avatar
Trader Rating: (28)
hellaslows13 will become famous soon enoughhellaslows13 will become famous soon enoughhellaslows13 will become famous soon enoughhellaslows13 will become famous soon enough
Feedback Score: 28 reviews
Hoping Zilvia friends can help out again with this. I am having a tough time finding someone to tune my SR20DET w/ Power FC. Blacktrax is over book for months, Performance Options no longer tunes. Any other shops that are current?
wavybert / zenki / build thread
hellaslows13 is offline   Reply With Quote
