01-09-2010, 12:19 PM | #1 |
too much fuel!!!!!
hey well my car is running too too rich.. that its making my car bogg and i guess misfire. but it only happends at a certain time i guess wen the car reaches operating temp. help plz im stuck im thinkin its the collant temp sensor telling my ecu my car is still cold?
01-09-2010, 02:03 PM | #4 |
heeeeeeelllllllpppppp plz guys im stuck i dont kniow wg=hat to do know. idk pressure regulator stuck injector. just pulled out plugs they been in there for 2 weeks and there black allready sign of to rich. also car backfiring from exhaust also sighn of too rich.. plz help
01-09-2010, 02:31 PM | #6 | |
If you think there is to much fuel might als be a leaking injector more details, Why do youthink its too much fuel?, what have you tryed, done? |
01-09-2010, 02:42 PM | #7 |
because wen it starts bogging it smells like fuel and white smoke. turbo is fine spools good. pulled hose from pvc ans smell like fuel. i can literaly see my gas gage go down... wen it starts bogging i wont idle ill shut off. then hard time to crank i think its getting flooded with fuel?
01-09-2010, 02:49 PM | #9 |
take the rail out of the manifold and pressurize the system see if its got a leaky o ring
do you have a FPR? stock fuel pump?what ecu? all these things can affect your fuel |
01-09-2010, 03:01 PM | #11 | |
remove the fuel rail from the manifold, turn the key to the acc switch to pressurize the fuel rail, look for leaks. make sure your FP is at 3 bar and if your running a Nismo FPR make sure you have teflon tape on the screw |
