11-12-2009, 12:10 PM | #1 |
Trader Rating: (44)
Feedback Score: 44 reviews
need help asap!!!
ok guys i got a big problem..... i got no spark... i have power to the cas plug, i have a knone working ignitor,switched coil packs with knone working one, all my grounds have been tripple checked so has my wiring at the chasis plugs. i have power at the ecu at to each coil pack output, so does each ecu pin for the cas sensors, 180 degree, and 1 degree. eccs power and back up power are all good. but i still have no spark. tore apart coil pack harness and it at looks good.
is thr anything else i could be missing to check????wut should my reading be after the cas? and how do i check that i dont kno wut it could be??when i move the cas by hand and the ignition on, i should i hear injectors click??? maybe harness???but if im getting power to all those things then my harness should be good rite??? im thinkin cas, but i dont have anothr one to pull and use at the moment. |
