![]() Join Date: Jun 2007
![]() Feedback Score: 15 reviews
No Battery cables?
So I got a free stripped 89 shell...put a harness on it, motor, etc. Now I'm noticing I have no battery cables...can anyone provide pictures and stuff to tell me where I'd wire it into and stuff? It's like the last thing I need to get it to run.
96 S14 w/ Kouki Front 05 Yamaha YZF600 |
Negative isn't a problem. I have plenty of gauge 1 and 2 wire. Terminal kits are cheap too. I know negative is grounded to the motor and chassis, which isn't hard. Just not sure where the power comes from. I know it goes to the alternator and starter...just not sure as to how...
#7 |
Okay, went ahead and took apart the harness for the most part...maybe you guys can point out if I've got it setup wrong and where exactly the cables are supposed to be wired in?
Overview of everything spread out: ![]() Wires to alternator: ![]() Wires to starter (2 black wires next to each other) ![]() Wires to plugs around the relay box (Don't know what circled one plugs into??): ![]() Couple things I noticed: ![]() ^This thick white wire runs from alternator to a plug around the relay area. ![]() ^This less thick white wire also runs from the alternator to a plug in the relay area. ![]() ![]() ^This ground (A) runs from the alternator to the starter. ![]() ^This goes to a plug in the transmission Now I think that accounts for all the wires on that section of the harness....do I have anything wrong? And where am I wiring the positive battery cable to? I didn't see anywhere that it would appear to go...
#8 |
AFC #1
![]() Join Date: Oct 2003
(a)Ground goes from the Alt to the body behind the fusebox by the strut tower. Starter grounds to the block.
The rest is hard to make out against the engine. I will try to figure out the rest later.
#9 |
Hmm So am I missing the ground wire from the starter to the block? Lemme know when you figure out the rest.
#10 |
AFC #1
The starter grounds out through the housing. Should only have the power wire and the signal wire going to the starter.
#11 |
![]() Join Date: Dec 2006
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
you should have a thick zero guage wire coming out of that harness as well, which goes to the battery terminal. all the white wires are power. look within that plastic sleeve for it. its black and red i think
