10-31-2009, 09:48 PM | #1 |
Swapped ECU and car won't start
This is probably something easy to fix but I'm so frustrated with this thing I can't figure it out. Engine is a bone stock KA24DE in a 92 hatch. Everything ran perfectly fine until I swapped out the ECU for one with a daughterboard. The stock ECU is #28, the new one #24, and I put the stock rom from the 28 onto the new one prior to installing it. After I swapped it over the car will not start. Basically all I did was disconnect battery, unplug the old one and plug in the new one then reconnect the battery. It sounds like the fuel pump is priming and what I presume is the starter but the engine does absolutely nothing. I swapped the stock ECU back over and it still won't start. I checked every fuse and relay I could visually check that I could think of. Could I have blown the eccs relay (the green one to the far left I believe) and if so how do I check? Anything else it could be? Is there anything I'm supposed to do aside from just switching the big harness plug over to the new ECU?
Thanks for the help and sorry for the stupid question but searching didn't turn up anything like this.
'92 240SX, '07 G35S 6MT, '09 CBR600RR |
10-31-2009, 10:01 PM | #3 |
I was told it worked from the seller and told it was tested when I had the daughterboard installed on it but honestly, no, I'm not. If it didn't work to begin with what could I have blown by trying to start the car with it? The car still won't start now with the original (known working) ECU.
10-31-2009, 10:06 PM | #4 |
Oh boy, lots of things could be going on.
If you want to check the ECCS relay, or just about any relay for that matter, pull the relay, apply current and ground to the two small pins, and measure continuity across the big pins. There is literally thousands of things it could be. Start with the basic. You have starter. Let's assume that's true. Do you have fuel, spark, or compression? |
11-01-2009, 01:16 AM | #5 | |
At any rate thanks for the help!
