04-06-2003, 09:28 PM | #1 |
MAXXX Boost on a T25 setup ?
Ok, this is my setup as of now, s13 sr20 det T25 w /stock SMIC, plus I have a 255 walbro fuel pump, how much boost is safe on this setup before detination.
Thanks |
04-06-2003, 09:34 PM | #3 |
no more than 14-15 PSI, i dunno the barage on that
04-07-2003, 04:10 AM | #7 |
I ran 14lbs on my completely stock setup w/ no problems. Just don't do it in the summer. while it's cool out have fun but not in the heat
'91 hatch w/ SR Sold; '03 Evo Sold 401 HP; '03 MS Protege sold; '00 Evo 6.5 TME Sold 300HP |
04-07-2003, 06:32 AM | #9 | |
04-07-2003, 08:35 AM | #10 |
mmm...12-14 psi. Sounds nice. I think I need to invest in something to turn up the wick.
Since this thread sucks, imma jack it. Any opinions on boost controllers? Yes, I've read a LOT about them. I'm leaning towards the Greddy Profec B for ease of tuning, but the AVC-R would match an S-AFC so nicely. And then there's the super-cool Blitz SBC-iD. Or go cheap and just make/buy an MBC. Thoughts? Eric
2002 Mazda Protege5 1989 S13 w/SR20DET (sold) |
04-07-2003, 09:21 AM | #11 | |
04-07-2003, 09:29 AM | #12 | |
AVC-R cool because of it's monitoring functions..that's the best part about the controller. other than that self learn mode is a focking joke but once you get it tuned right it holds good boost. Blitz newer It's a neat looking little gadget. Installation is a breeze (installed in friends car) and tuning it is also simple. Only down side is it costs as much as the AVC-R and doesn't have any of the monitoring functions. Greddy profec: meh..fuzzy logic sucks nuff said. I'd reccomend looking into the NEW greddy..that one looks cool! That's all I can think of. on to MBC's!! a good friend runs a manual boost controller. Bottom line it's the best way to go since all the pretty electronic boost controllers lose their novelty after a while. I just installed an HKS actuator with my new turbo. I'm very impressed. It holds boost better than any boost controller I've seen yet. for 65 bucks new I think it's the best way to go for a t25 setup! Hope this helps Jed |
04-07-2003, 02:15 PM | #13 | |
04-07-2003, 02:43 PM | #14 | |
1 bar = 14.7 psi. that's really all you need to know. i mean unless you don't want to go and use a calculator or anything. but seriously it's a simple ratio. if you have psi and you want bar, just divide by 14.7 if you have bar and you want psi, multiply by 14.7 Tim |
04-07-2003, 02:46 PM | #15 |
from Canada, eh!
Hum... I wouldn't recommend going over 10 psi with the stock SMIC!!!
-> HaLo Race Car: '98 E36 BMW M3 Daily Drivers: '23 Audi Q4 e-tron & '13 VW Touareg SOLD: 01 GPW Honda S2000 PARTED: 93 Pearl White 240SX LE Fastback w/SR20DET SOLD: 93 Super White 240SX SE Convertible w/Silvia Front |
04-07-2003, 06:49 PM | #17 | |
PROCEED Grip Gambler Last edited by KiDyNomiTe; 04-07-2003 at 06:51 PM.. |
04-07-2003, 08:45 PM | #19 |
Alright, I'm wrong, i admit it. I guess I just thought everyone refered to 1 bar as 14.7psi. but like Duffman said that's atm's. And all along I thought
1 bar = 1atm = 1 kg/cm^2 = 760mmHG = 14.7 psi but it's just 1atm = 760mmHG = 14.7 psi all the other ones are a little off, so Jeff was closer with 14.5 psi = 1 bar. but everything else i said is still true, in respect to figuring out bars and pounds per square inch. Take a look at this page, all conversions Tim |
04-08-2003, 02:24 PM | #20 |
the hks actuator wont allow you to hold more than around .80-.88 bar however. I am using an avcr on my upgraded t25/t28 turbo at 1 bar with 370s stock ecu and a nismo fpr on 91 with octane boosetr for daily. I would go with 14.5 psi of boost with a nismo fpr. I would set the fpr at 45 psi at idle and you should be safe. It will increse the amount of fuel being pushed thru your injectors every pulse thus a little more fuel. you should be find at 1 bar on stock turbo. It looses efficency after that anyways. Mine loses effiecency at 18.5 psi thats why i like it.
04-08-2003, 05:22 PM | #21 | ||
Yes, I look like that
04-08-2003, 06:25 PM | #24 |
Look at the link I posted before. It's got all the conversions. Boost is measured in a bunch of different ways, ie bar, psi, kg/cm^2. And they are all slightly different. like i always thought 1 bar = 1 kg/cm^2 = 14.7psi, but from everything i found when i was looking for it proved me wrong.
well here's page again, conversions and if you don't believe that one try this Tim |
04-09-2003, 07:31 AM | #25 | |
Keeping it Godzira bishes. So I murdered another turbo |
04-09-2003, 08:50 AM | #26 | |
I'm sure most of our familiar 240 shops can get it. Just call around I'm sure at least one of em has one in stock. |
04-09-2003, 06:10 PM | #28 | |
But I guess someone scanned it, and I juss saved it for future reference
PROCEED Grip Gambler |
04-10-2003, 02:33 PM | #29 | |
04-10-2003, 03:55 PM | #30 |
you can buy the Hks acturator at www.jspec.com or phase2motortrend.com..
stock fuel deliever system (370c.c.) only safe to boost around 10 psi but can be push to 12psi making about 220-230 at the wheel even with the hks act. upgrade and 555c.c. injetors...T25 only efficient to run around 1 to 1.1 bar and makes about 240 rwhp... i had a T25 turbo bore out to T28..with 265 in/exh cams i made about 260 at the wheel...similar set up with a S14BB turbo made 270rwhp but with a faster spool compare to my midifided turbo.. every number is comfirmed on a dyno jet tuned at XS engineering with power FC just to give u guys an idea Richard |
