02-15-2009, 09:36 PM | #1 |
snap-on air compressor sr notch top and q45 brakes
snap on air compressor 110/220 volt 25gal tank, 5hp motor. has wheels model is bp401 used mainly used to air my up tires and light work in my garage air ratchets drills etc SOLD!!
q45 brakes calipers and rotors cleaned and are in good condition brake come with hardware need to put the pads in $120 sr20det notch top block and head w internals, intake manifold with injectors throttlebody and exhaust manifold i will include a valve over gasket and a head gasket for $1100 i will try to post a compression test within the next few days im willing to ship but it will be costly. call/text 619 933 0462 i will except trades for seats wheels suspension.... Last edited by Sad s13; 02-22-2009 at 05:05 PM.. |
02-17-2009, 01:19 PM | #2 |
bump!!!!
for 1300 i will include power steering pump, q45 ignitor with pig tails, alternator that needs new brushes(~$40), and one good one, my spare transmission, starter, and turbo manifold and elbow, head gasket and valve cover gasket intake manifold injectors and throttle body come one ppl i need this gone i can deliver it too |
02-19-2009, 09:13 PM | #7 |
what car will you be driving? if its not a compact car it should fit. the handle can unbolt and the top is maybe 30inches off the ground
02-20-2009, 09:17 PM | #11 |
the motor is still assembled it looks almost how it is in the pictures, i just havent takin new ones without the turbo and trans and coilpacks. i havent done a comp. test but i will get the time tomorrow to do it then.
02-22-2009, 05:04 PM | #12 |
the air compressor has been SOLD!
compression test results were 150+ on the motor and i believe that it may even be higher since the motor has sat for so long and everything is stiff. because the motor sat so long i put oil in the cylinders to make sure the cylinders/rings would not stick. the motor had no knock or anything. i can give a 30 day start up garentee if it doesnt start due to a faulty part on the motor ill give the money back. |
