FS: 1998 S14 240sx RB25DET
City: Portland
State/Province: OR Country: USA Price: $12,600.00 OBO 1998 Nissan 240sx SE Cobalt Green Pearl Metallic Sun Roof Interior: •Power door locks with Clifford Security system •Power windows •Sony CD player •“Silvia” Embroidered head rests •240sx floor mats •Greddy weighted shift knob •Cusco silver e-brake drift button Engine: •R33 Series 1 Nissan Skyline RB25DET •Tomei Pon-Cams •New OEM timing belt •New OEM cam seals •Apexi Power-FC stand alone ECU with Commander •Apexi AVC-R boost controller •Stock clutch fan and R33 fan shroud •Working Air Conditioning •HKS cat back exhaust system •New Nismo Cold thermostat •New N1 water pump •New OEM timing belt tensioner pulley •New OEM timing belt idler pulley •New OEM crank seal •Fresh coolant change with Red Line Water Wetter added •OEM R33 air cleaner box •R33 mass airflow meter Transmission: •OEM Nissan Skyline RB20DET Transmission •One piece steel drive shaft •S14 Viscous LSD Suspension: •Tein SS coilovers •Solid metal rear sub frame bushings •Battle Version rear upper control arms Wheels and Tires: •OEM R33 Nissan Skyline GTR wheels in 17x9 + 42 offset •Fusion Zr-I tires in 275-40zr 17 all four corners Brakes: •Fronts: Nissan Skyline R33 GTR front brake calipers and rotors with metal ceramic pads •Rear: Stock S14 rotors and brake calipers with metal ceramic pads Exterior: •S14 JDM Silvia Grill ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Dyno sheet is before cams. Power is now up a little bit with less boost. Currently running a .8 bar and 1.0 bar settings. Knock numbers are under 25 under abuse. All work done by UPGarage in Tacoma, WA. If you have any questions or would like to see more pictures please e-mail me at [email protected]. No trades. |
Miss print. Wheels are a +30 not +42.
Yah I know I can edit, was just using it as a bump. If I was keeping the car the manifold would have been powder coated black, I like the stock clean sleaper look. |
![]() Join Date: Dec 2005
You can edit your post. Clean swap. If that Greddy manifold was black you might just be able to get away with that in CA lol.
#11 | ||
460
rb25, rb25det |
