10-05-2008, 05:41 PM | #1 |
5 lug conversion ?'s
so im doing a 5 lug conv on my 98 kouki. front are easy..
now on the rear.... whats easier. -take the rear spindle off and then replace the hubs? or -take the axles off, leave spindles on and replace hubs? im sure its easier to just take off the axles, just wanna make sure this is the right way. i took a peak today and i'll b getting to it tomorrow. |
10-05-2008, 05:44 PM | #2 |
when we did mine we disconnected the RUCA, toe rod, and axle so we could tilt the spindle enough to get an impact driver back there to get the bolts. then we used an air hammer to slowly work the hubs out.
10-05-2008, 05:45 PM | #3 |
1. search.
2. search 3. a hot dog 4. search
high performance driveway photography zenki s14---v8 fc rx7 my crappy flickr page (drift cars whoo) |
10-05-2008, 06:20 PM | #4 | |
10-15-2008, 03:44 PM | #13 |
If the hubs are the same (which they are, you know that from this thread), how would the rotors not work?
Think about it.
10-20-2008, 11:04 PM | #15 |
will the front hubs from a z32 bolt right onto a s14 with no problem? Also, does it matter if the z32 is a turbo or not for the front?
www.maydaygarage.com Follow me! @Maydaymikey |
10-21-2008, 10:42 AM | #18 |
anybody have any good reviews on aftermarket hubs they have used for the conversion? i have done some research and havent been able to find anything that i think is reputable. Also, when converting from 4-5lug, are the calipers interchangeable? i know you'll have to change out the rotors for sure, but ive heard of people using the same calipers. Just want to confirm since i myself am going 5-lug next week.
10-21-2008, 07:44 PM | #19 | |
Trader Rating: (44)
Feedback Score: 44 reviews
Ichiba bearings go out i had mine for 9 months now and need new bearings already but can get new ones for 60bux yea u can use same calipers u can use the same rotors to if u redrill them to 5lug if its s13 just but se s14 rotors same size if u dont redrill ur old ones
Red Rocket |
10-21-2008, 11:38 PM | #20 |
Super Moderator
Trader Rating: (73)
Feedback Score: 73 reviews
The easiest way to do it is
Take off wheels Disconnect brakes (Use transmission if you need to stop the rotating assembly) Rotate axles to get to the 4 bolts in the spindle that hold the hub in place Get all four bolts out Hit hub on top and bottom with a BFH til the hub is loose Replace old 4 lug hub with 5 lug hub Reinstall in reverse order. I've done it so many times I can do the rears by myself in like 20 minutes.
10-29-2008, 01:22 PM | #22 | |
