Old 09-08-2008, 02:02 PM   #1
jakobie
jakobie is an unknown quantity at this point
How to install Apexi Safc 2
Does Zilvia have a right up on this for a redtop sr20det?
jakobie is offline   Reply With Quote
Old 09-11-2008, 03:49 PM   #2
jakobie
so how to install and tune anybody?
Old 09-11-2008, 08:20 PM   #3
gt3071r240
gt3071r240 is an unknown quantity at this point
haha newbie... throw it in the garbage.
gt3071r240 is offline   Reply With Quote
Old 09-11-2008, 08:53 PM   #4
Erjay1
Erjay1's Avatar
Erjay1 is making a name for him/her selfErjay1 is making a name for him/her self
what he said. SAFC's are crap andwillonly causemore problems. Its like using a band-aid instead of stitches.
Erjay1 is offline   Reply With Quote
Old 09-11-2008, 11:28 PM   #5
louisdaboois
louisdaboois's Avatar
Trader Rating: (28)
louisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfection
Feedback Score: 28 reviews
this coming from the guy with 40 posts.
uhm, i dont see how an safc can cause more problems. they are good to use only has a fine tuning instrument rather than a primary source of tuning. but i do agree that it is like using a band aid instead of stitches.....
for the OP, try here http://www.apexi-usa.com/pdfWiring/18.pdf. the search button is a great tool to use on zilvia to avoid flaming.
louisdaboois is offline   Reply With Quote
Old 09-11-2008, 11:31 PM   #6
S14DB
AFC #1
S14DB's Avatar
It really fucks up your timing maps as they are load dependent. SAFC fakes out your ecu to think there is more load to get more fuel.
Old 09-12-2008, 09:32 AM   #7
louisdaboois
Trader Rating: (28)
not trying to argue with you or anything, correct me if im wrong. since an safc converts the input signal of the mafs to the ecu, it should change the load varient at whatever the user specifies the rpm, throttle and correction settings. the spark and fuel map will be essentially the same throughout the loads, but just at user defined times.
in other words, for instance, the mafs sees a certain amount of load at 5000 rpms and 50% throttle, which Cell A of the fuel and spark map will be effective, but with the safc, the same cell (A) will kick in at 3000rpms for richer conditions at a given correction setting.
so what im trying to say is that the fuel/spark are essentially untouched and "factory", but just shifted (assuming that the fuel/ spark maps are excel format). right?
Old 09-12-2008, 11:30 AM   #8
Sileighty_85
Sileighty_85's Avatar
Here it is. (and its spelled "Write")
Were trying to educate people here not confuse them and make them dumber.
http://zilvia.net/f/tech-talk/196800...all-guide.html
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 09-12-2008, 02:00 PM   #9
louisdaboois
Trader Rating: (28)
lol. sorry.
Old 09-12-2008, 02:52 PM   #10
Sileighty_85
Originally Posted by louisdaboois View Post
lol. sorry.
I wasnt referring to you Louis. :P
後輪駆動車1番
1986 SR86 - 200ish
Old 09-12-2008, 07:27 PM   #11
S14DB
AFC #1
S14DB's Avatar
Yes, the timing map and the fuel map are locked together. The SAFC fakes the ecu out to get the desired fuel output. Unfortunately, the timing map will usually not be at the right point.
I will usually manifest it self in dang my manifold is glowing red. Kool I must be making power. Then 6 months down the road they wonder why they melted a piston.
Greddy is a little better cause it clamps the Timing too. But you are still faking the ecu.
AEM FIC. Handles it differently it leaves the ecu alone to operate like nothing has changed. it takes the ecu's output as a trigger then puts out it's own signal to the injectors/coils. FIC is running the show but the ECU thinks everything is kosher to run the Emissions/OBD, TCU, AC, TC/ABS, ect..
Old 09-13-2008, 09:24 AM   #12
blackej7
blackej7's Avatar
blackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really nice
lol. so the more posts you have on zilvia, the smarter you are? I need more posts!!!!
blackej7 is offline   Reply With Quote
Old 09-13-2008, 09:34 AM   #13
airforceone451
airforceone451's Avatar
airforceone451 will become famous soon enoughairforceone451 will become famous soon enoughairforceone451 will become famous soon enoughairforceone451 will become famous soon enoughairforceone451 will become famous soon enough
On the same note, it's "we're" since it's a contraction of we and are. Remember, we're trying to educate people
airforceone451 is offline   Reply With Quote
Old 09-16-2008, 12:47 PM   #14
jakobie
thanks guys, it's in the trash...
Old 09-16-2008, 03:18 PM   #15
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Why? You can use it if you're still running a fairly stock setup...its not completely and utterly useless...
CLICK HERE!!!
Old 09-17-2008, 02:48 PM   #16
jakobie
I have no idea how to tune it, i might just sell it...
Old 09-17-2008, 03:16 PM   #17
S14DB
AFC #1
S14DB's Avatar
yeah sell it. it's like herpes, the gift that keeps on giving.
