Old 07-03-2008, 02:46 PM   #1
SForce
SForce is on a distinguished road
VLSD Question!?
We pulled the vlsd out of a friend's sr'd s13 and w'ere attempting to put it in my 1993 s13, but the vlsd pumpkin is about 2 inches longer in my open diff pumpkin, but the axels match up, so what's goin on?
SForce is offline   Reply With Quote
Old 07-03-2008, 02:49 PM   #2
wow-thats-a-cool-car
wow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfection
Send a message via AIM to wow-thats-a-cool-car
did u change the pumkin covers from ur open to the vlsd.....that should fix the problem
wow-thats-a-cool-car is offline   Reply With Quote
Old 07-03-2008, 02:57 PM   #3
adrians_s13
adrians_s13's Avatar
Trader Rating: (29)
Feedback Score: 29 reviews
you sure its not upside down? One axel is longer than the other...
@adrianfromthecastle
Old 07-03-2008, 03:06 PM   #4
spoolandslide
Location: lost in a bump splice in the fabric of our clockwork
spoolandslide is close to perfectionspoolandslide is close to perfectionspoolandslide is close to perfectionspoolandslide is close to perfectionspoolandslide is close to perfectionspoolandslide is close to perfectionspoolandslide is close to perfectionspoolandslide is close to perfectionspoolandslide is close to perfectionspoolandslide is close to perfectionspoolandslide is close to perfection
No he means the pumpkin is 2 inches longer length wise to the drive shaft.
But why would it be longer?
spoolandslide is offline   Reply With Quote
Old 07-03-2008, 03:07 PM   #5
adrians_s13
Trader Rating: (29)
oops my bad... yea I guess I skimmed too fast.
hmm....
Old 07-03-2008, 03:08 PM   #6
mrmephistopheles
mrmephistopheles's Avatar
You've probably got an ABS differential and you're trying to use it on a non-ABS car (with non-ABS driveshaft).
Originally Posted by PHLIP
Old 07-03-2008, 03:08 PM   #7
spoolandslide
Sooo what is necessary to make this thing happen?
Swap the drive shaft too?
Old 07-03-2008, 03:31 PM   #8
mrmephistopheles
Wait wait. I'm thinking of S14/S15 diffs.
Is there a difference between the cars in terms of A/T and M/T?
Those driveshafts are def. different.
IIRC, S13 ABS diffs have the two sensor setup like Z32, where S14/S15 have one sensor at the front. Fuck I can't remember! My brain is all melty.
Old 07-03-2008, 03:37 PM   #9
spoolandslide
double post, sorry
Old 07-03-2008, 03:38 PM   #10
spoolandslide
Haha no both cars are m/t.
One is a wrecked sr'd s13 hatch, the other a ka s13 coupe.
There is one little plug coming off the diff that wasn't connected to anything when it was on the hatch. (I assume this had to do with abs)
Would simply putting the drive shaft that's on the hatch onto the coupe solve the problem?
Old 07-03-2008, 03:43 PM   #11
mrmephistopheles
It should, but before you go unbolting anything, take a measurement first!
Old 07-03-2008, 03:44 PM   #12
spoolandslide
Will do.
Luckily we did that with the pumpkins first, before we went to town.
Thanks
Old 07-04-2008, 01:13 AM   #13
ESmorz
ESmorz's Avatar
So after all the shit and all the unbolting and time. We couldn't get the bolts off from the drive shaft without stripping them.
balls
Old 07-04-2008, 01:32 AM   #14
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
abs vlsd has a longer snout against the non vlsd. how i know? i used to have both
Old 07-04-2008, 01:34 AM   #15
ESmorz
ESmorz's Avatar
But will it still fit?
I've never dealt with diffs before.
Old 07-04-2008, 01:37 AM   #16
wangan_cruiser
kouki man
Trader Rating: (36)
as far dealing with the cover. doesnt really matter on the rear cover 2 bolt vs 4 bolt. all the 4 bolt are the same. but when try to mate it 2 axles side by side check the length on it. if you are using 300zx factory axles it wont fit. i had this prob before. i tihnk you need to make mix match with diff 5 bolt axle. if you have a problem for connecting the drive shaft. try to grind a small piece from the joint. itll slide through. the reason it wont go in because of the spline with a nut in the way.
Old 07-04-2008, 01:41 AM   #17
ESmorz
ESmorz's Avatar
The axles line up fine.
It's just the pumpkin is 2 inches longer, but the drive shafts on the two cars are the same size... so I'm guessing if we make it fit it will haha
Old 07-04-2008, 01:51 AM   #18
wangan_cruiser
kouki man
Trader Rating: (36)
for u
msgs lngth
Old 07-04-2008, 01:56 AM   #19
downshift_sideways
No Limit Soldier.
downshift_sideways's Avatar
downshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfection
Send a message via AIM to downshift_sideways
You have an a VLSD diff with ABS.
Your going to need an abs driveshaft to bolt it up flush.
Take out your friends driveshaft and swap it with yours. That should fix the problem.
How did you manage to strip the bolts?
allntrlundrgrnd: "you never really appreciate your parents fridge until you look into your own and its full of condiments only"
downshift_sideways is offline   Reply With Quote
Old 07-04-2008, 01:58 AM   #20
ESmorz
ESmorz's Avatar
Your going to need an abs driveshaft to fit that driveshaft in there.
I have the abs drive shaft too.
Measured them and put them side by side and they looked exactly the same though. But, I wasn't the one doing the measuring soo... I will just go pick it up and do this shit tomorrow.
Old 07-04-2008, 02:00 AM   #21
downshift_sideways
No Limit Soldier.
I mean..
In general..If both cars had driveshafts attached to the diff's and drove perfectly fine.
then if you were to swap out diffs and driveshafts onto each others chassis's is should mount up correctly without any problems.
Old 07-04-2008, 02:02 AM   #22
ESmorz
ESmorz's Avatar
Yeah I'll just do it any way. Couldn't hurt.
Just got to figure out how to get the drive shaft bolts off without stripping them. Those bastards just do not want to come off.
Old 07-04-2008, 02:05 AM   #23
downshift_sideways
No Limit Soldier.
get a ratcheting wrench.
and a breaker bar.
Done.
Take off the e-brake..spin the driveshaft...then lift up the e-brake.
Get the other bolts.
Done.
<3
Old 07-04-2008, 02:09 AM   #24
ESmorz
ESmorz's Avatar
and a breaker bar.
Done.
Done.
<3
Yeah I know that much...
But the sockets+ratchet are too big to fit in the space lol
I was too tired to deal with this shit today.
Old 07-04-2008, 02:40 AM   #25
wangan_cruiser
kouki man
Trader Rating: (36)
or you can attach the driveshaft to the diff then raise them at the same time.
Old 07-04-2008, 02:43 AM   #26
ESmorz
ESmorz's Avatar
Yeah, that's what I planned on doing.
The drive shaft and vlsd are out of the other car already.
It's my drive shaft's bolts that wont come undone without going gay...
Old 07-04-2008, 02:57 AM   #27
wangan_cruiser
kouki man
Trader Rating: (36)
gud luck. i just recently installed my one piece driveshaft
Old 07-04-2008, 03:03 AM   #28
thejapino
thejapino's Avatar
thejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfection
Pb blaster is the best, I was once a skeptic and now I'm a believer!
WTB: 13kg springs! Eibach, Stance, or Swift.
thejapino is offline   Reply With Quote
Old 07-04-2008, 08:03 AM   #29
Slammed180
Slammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of light
Yea, you're right S13 ABS diffs have the two sensors. And you will definately need an ABS driveshaft.
EDIT: just read through the whole thread. Doesn't look like I helped much, sorry.
Blow me, bitches.
Slammed180 is offline   Reply With Quote
