03-30-2008, 02:15 PM | #1 |
350 carburated into an s13
Alright, so I know people do the ls1 etc swaps into their s13s. But I want to know about sticking a carb'd small block into my car. Since there is no need for a computer, what do i do about all my wiring? how do i keep my speed sensors etc all working? I dont mind if i have to get an after market cluster to accommodate for it. What would you recommend? Im trying to do research on it but im not finding carb'd v8s
03-30-2008, 02:26 PM | #2 |
Zilvia.net GB Vendor
Trader Rating: (52)
Feedback Score: 52 reviews
Just look up the wiring diagram on a 69 camaro, you wouldnt have much wiring to deal with.- This is something that I have been wanting to do for a while. It would rip for sure muncie 4 speed or a newer 5 or 6 speed?
WWW.JIMMYUP.COM |
03-30-2008, 02:37 PM | #3 |
Well I dont mean the wiring for the engine because there really isnt any other then a positive wire to the distributor. But I mean for the sake of all my interior lights, tachometer, speedometer, temperature etc. How do I keep use of all them? Or will I be tearing apart my dash to rewire everything?
03-30-2008, 02:57 PM | #4 |
it would probably be easiest to get an aftermarket gauge setup (water temp, speedometer, fuel level, tachometer, + any other accessory gauges you want) because they would all come with their own sensor. This way you can eliminate a lot of wires for the stock gauge cluster and just run the few you need for the aftermarket ones you buy. Plus it will look all hot rod and junk with a sheetmetal gauge cluster
03-30-2008, 04:08 PM | #5 |
Trader Rating: (52)
I run autometer gauges in my chevelle, and this gentleman^^^ is right. They all have their own sensors and are very straightforward installation wise. Go for it man, if you have experience with sbc's its perfect.
WWW.JIMMYUP.COM |
03-30-2008, 04:16 PM | #6 |
Trader Rating: (106)
Feedback Score: 106 reviews
The problem with your idea, which HAS been done before, is weight. A 350 is fuckin heavy compared to a ls-x. That is the primary reason that anyone does the ls-x swap, on paper it just makes sense. Less weight, more power, TONS of torque, and a lower center of gravity.
03-30-2008, 09:39 PM | #8 | |||
The VSS goes with the gearbox. You can get any universal speedo to work with a T5 VSS. Quote:
You can go fancy if you want. There are a lot of aftermarket gauges. I got all the info you need. What do you want to know? |
03-30-2008, 09:41 PM | #9 | |
OEM tach will not work. OEM speedo will not work unless mated to a correct generation KA or SR gearbox. OEM temp gauge will work if you mount the KA/SR temp sensor or equivalent in the V8. Custom wiring will be required at least to move the connectors to where they need to be. |
03-30-2008, 09:43 PM | #10 | |
Keep in mind that LSX = LS Extreme according to GM if you want to be technical. That would be the only LS I would get. |
03-30-2008, 09:51 PM | #12 |
The 350 would DEFINITELY be a LOT cheaper. I was just using the x to substitute for 1,6,7, etc.... I would like to do the swap carb legally if I ever do it so I think I would have to use a GTO motor as it is the only one that would have a carb legal intake that I might be able to use.
03-31-2008, 02:04 PM | #17 |
Check the V8 FAQ thread. Lots of good info in there: http://www.zilvia.net/f/showpost.php...&postcount=350
I have just the basic to get the car to run: one wire alternator, starter, e-choke, grounds, HEI, spark plugs of course, and that's it. |
03-31-2008, 03:31 PM | #18 | |
You want LS1, its cable driven throttle body and not DriveByWire shit that I have to deal with. |
03-31-2008, 04:29 PM | #19 |
I am a big fan of swapping in the 350, or better yet a high revving built 327....The power potential is amazing, and for only a grand or so, you can run aluminum heads and take off 60-75 pounds off the top end of the motor and gain nearly 70-100 hp with the proper cam and tuning. My last conversion was in my 914...
[ame]http://www.youtube.com/watch?v=cs79VZSm9Lw[/ame] [ame]http://www.youtube.com/watch?v=HqHsA0EuYzk[/ame] that car was suicidal, 1900 pound dry weight with glass deck lids and completely gutted. Can someone post up some pics of a carbed SBC in an s13-14? Last edited by mugendork; 03-31-2008 at 04:30 PM.. Reason: imbed error.. |
03-31-2008, 05:18 PM | #20 |
Ya I DEFINITELY don't want the gay ass e-throttle. I fucking hate it when a computer has to decide weasther or not my inputs are valid! Fuck every single electronic "safety" system other than ABS.
04-01-2008, 10:11 AM | #23 |
Actually I think it has to do more with idle control than safety. But yeah, we'll see how it goes on my swap.
