Old 02-14-2008, 12:25 PM   #1
Streetfighter
Streetfighter's Avatar
Streetfighter will become famous soon enoughStreetfighter will become famous soon enoughStreetfighter will become famous soon enoughStreetfighter will become famous soon enoughStreetfighter will become famous soon enough
sr20 Lower harness Help needed
Need alittle help...my swap is almost done.
it was a 240 auto...just so we all know what we're dealing with.
the lower SR20 harness (not the KA) has only 1 plug on it that connects to the middle plug of the row of 3 plugs on the passenger fuse box. is this correct?
i unplugged and removed the altinator/starter harness from the KA completely...it unplugged off 3 plugs on the side of the ecu facing the motor on the passenger side.
so if i remove the KA lower harness entirely....and plug the 1 plug from the SR lower harness in the middle of 3 plugs on the passenger ECU...thats it?
thanks!
Streetfighter is offline   Reply With Quote
Old 02-14-2008, 12:47 PM   #2
BoostinGST
BoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant future
you should just reuse the stock lower harness... i went through alot of trouble trying to mate the sr harness to the car and ended up spending $250 on a new harness from the dealership, just a warning so you dont make that mistake.
www.DecalsStore.com custom decals... buy a premie account and save money from me
BoostinGST is offline   Reply With Quote
Old 02-14-2008, 12:54 PM   #3
Streetfighter
mine was an auto...
and the tranny wires do not mate with the stock KA lower harness...instructions on heavy throttle says use SR harness..
Old 02-14-2008, 02:41 PM   #4
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
use the ka harness that came with ur car
last time i checked the z32 maf pinout on heavy throttle wasn't correct either ^_^
just like the tach signal wire on an sr20 is 1 notch over than apexi's website, if you're wiring in an safc using apexi's ecu pinout for an s13 sr20 ^_^
bridge the park neutral wires together, oval grey 2 wire plug (thick black/white & brown wire) together, deal with whatever connector swaps you need to do ie starter solenoid, voila
Dave =]
RB25 280z GT30/76R 441hp/381tq [email protected]
Z U L8R is offline   Reply With Quote
Old 02-14-2008, 02:45 PM   #5
Streetfighter
just like the tach signal wire on an sr20 is 1 notch over if you're wiring in an safc using apexi's ecu pinouts ^_^
Dave =]
what about the wires coming out of the SR tranny...the speed sensor and so forth...
Old 02-14-2008, 03:13 PM   #6
Z U L8R
Z U L8R's Avatar
the sr speed sensor should plug into your auto lower harness, however it's a jdm motor/tranny, so the speed sensor reads for Kilometers, you need a ka 5spd speed sensor for it to read correctly. the other wires, clip off or tuck up, the only other sensor you even need (if u even care about it) would be your reverse lights.
i don't want to type up an autobiography on how to do it right now, so if you really really really wanna get ur reverse lights to work, identify which switch is the reverse light switch on the sr tranny (you can put the shifter in reverse then check the 2 wires for continuity to isolate it) then look up your auto tranny schematic for your reverse lighst, and run those to wires to the 2 wire reverse light switch and VOILA lol
Dave =]
Old 02-14-2008, 03:36 PM   #7
g6civcx
g6civcx's Avatar
Be very careful with wiring diagram you find online. Always double check and verify. People are not careful and may post bad info by mistake.
You may want to check this part before Russ shows up.
Old 02-14-2008, 05:31 PM   #8
projectRDM
projectRDM's Avatar
Dave =]
Dave, you should know better. The JDM and US speed sensors are the exact same, either one will read either cluster. Only differences in VSSs come from auto/manual and S13/S14.
To the OP, you haven't read anything if you're asking. Use the existing KA lower harness, everything plugs in, starter, alternator, and oil pressure switch.
For the transmission, the VSS plugs right in, the reverse switch is hardwired (if you even need it), and the starter inhibit is jumped in the plug. There is nothing else required, you should be done with it in less than 5 minutes.
FORMERLY R240NA
Old 02-14-2008, 05:45 PM   #9
joel.fox
joel.fox is an unknown quantity at this point
Man I wish someone had asked this question a couple weeks ago. I just finished doing this on my SR swap and I wouldn't have been able to do it if it wasn't for a good buddy of mine providing a stock KA lower wiring harness. I did a real number on my original one, thinking I wouldn't need it. It's much easier to start with a fresh and uncut lower wiring harness. Once you have it, and the old one is off your motor it will all be clear. Spend some money and source a new lower wiring harness, that's probably your best bet.
joel.fox is offline   Reply With Quote
Old 02-14-2008, 06:05 PM   #10
sblack13
sblack13's Avatar
sblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud of
I don't think you can use the dohc/sr lower harness on a sohc car or vice versa. One plug is different for the fuse box.
sblack13 is offline   Reply With Quote
Old 02-14-2008, 08:49 PM   #11
Z U L8R
Z U L8R's Avatar
using a dohc lower harness on a sohc car i've ran into issues like the dash lights staying on and the efi relay clicking it's ass off, then i put the original lower harness that came with the car and problem solved (stupid red plug missing)
@project rdm, my first car was back in 2000 i had an s14 with an s13 blacktop sr, and i had to swap the sr speed sensor with a ka speed sensor, i would go 10mph and it would say i'm going 30mph....i swapped em and problem solved. (of course 8 years ago i didn't know what i do now, and i've never given the vss's another thought besides mechanical vs elec), but in my defense! he said his 240 was an auto but he didn't say whether he had an s13 or s14 :P but good call none the less HI-5 i was presumptious (sp) and i've been working on a lot of s14's lately :P (plus i just bought one to daily drive while my 510 gets its roll cage/paint)
@g6civc "Be very careful with wiring diagram you find online. Always double check and verify. People are not careful and may post bad info by mistake"
that's what i was saying.....we're all capable of mistakes and misprints......as well as presumptions :P
gl street figher & take care fellas,
Dave =]
Old 02-14-2008, 08:56 PM   #12
Streetfighter
thank you for the help guys, much appreciated. i will use the stock KA lower harness and figure out the tranny wires.
i will take some pics soon so i can be alittle clearer.
Old 02-15-2008, 08:24 PM   #13
Z U L8R
Z U L8R's Avatar
only because i just did it tonight and it's still fresh in my brain, only possible issue is it was on an automatic s14, so it may be different (but not much) for an s13 *shrug
the auto tranny harness vehicle speed sensor wire colors
speed sensor wire colors Red/yellow and the other wire was red
the reverse lights on the auto harness were green/white stripe and the other was green
which go to the first little sensor towards the front of the car on the side of the tranny. should have an oval grey plug. you can always put it in reverse and check for continuity
if your car's not an s14. and the wire colors are totally different, turn the key to the on position. grab all the plugs on your tranny's lower harness. take a paperclip and jump the 2 pin plugs. the one that makes your reverse lights come on is your jewel. wire that into your trannies reverse switch.
Dave =]
Old 04-20-2008, 07:38 AM   #14
snowmants
snowmants's Avatar
snowmants is an unknown quantity at this point
Dave =]
These are the colors on the KA harness you are talking about right? Not the SR harness? Thanks.
snowmants is offline   Reply With Quote
