02-27-2007, 02:39 PM | #1 |
re-doing MAF wires...help(yes, that means you r240na)
I keep getting a CEL on my 96 240sx obd2 ka24de. No matter how many times i reset the ecu/clear codes it keeps coming back as MAF.
I have tried THREE different stock mafs and still get the CEL light for "faulty air/fuel metereing device". The wires are visibly worn and have cracks in them leading to the MAF. THE CAR RUNS FINE, but i'm wondering if the cracks are enough to throw a bad maf cel. SO, ONE- Am i correct in assuming its the wiring considering the car runs good and i've tried THREE MAF'S. TWO- Suggestions on re-wiring please. I know the signals from the maf are based on resistance... therefore if i use the wrong type/length wire won't i get a faulty/innacurate reading? I'm good at soldering, so please give me advice... Also, where can i get the same pins that go into the maf plug, or should i just re-use the old ones... thanks and sorry for the essay |
02-27-2007, 03:37 PM | #3 |
LAID OUT
You might have a short in the wires to the MAF, try measuring each wires continuity with a DMM from the ECU to the sensor pin. Although i think if you had a short you would be in the 2500rpm safe mode.
02-27-2007, 04:36 PM | #4 |
yep, measure the wires.... theres definetly a short... or just use one of those probe testers..
S14 TrackSlut coming to a raceway near you... 510 TimeAttack on its way... |
02-27-2007, 06:53 PM | #5 |
The MAF doesn't care about wire length or type. The only thing you need to make sure is the shielded signal lead is properly connected and the shield around it is grounded. I'd cut the plug off and back a few inches and start with a good plug. IIRC, the 98-01 Altima plug is the same, but don't quote me on that.
02-27-2007, 08:34 PM | #7 |
hmmm. interesting..
Thanks for the tip, i would have thought for sure solder would be best...guess i learned something. I won't be able to source a new plug before friday night(when i need to leave for saturdays track event). I'm lost on the grounded shield. I looked and still don't quite know what you mean by that. Could i just cut back 6 inches or a foot into the maf wires and re-wire with similar guage right to the back of the plug? thanks for your time |
02-27-2007, 08:45 PM | #9 |
No more nissan.
Make sure its the legit crimps though.. not the tubed plastic cheap-o ones.
the kind MoTec sells for their wiring. Ballertastic. WAAYY better than solder. Nobody uses solder on engine wiring harnesses. NOBODY. Just the thermal expansion difference between copper and tin(solder) is enough to explain why you don't want it in there.
02-27-2007, 08:57 PM | #12 |
No more nissan.
yeah, fastest pic I could find.
Umm.. dunno. Google it or call MoTec tech and ask them. They probably sell them. AMP's crimp connectors or any mil-spec crimp connectors
02-27-2007, 09:17 PM | #13 |
lol uhh yea if you say so, thats why when ther is a TSB from the factory for any car they say to stager and cut method and that they should be repaird with the proper solder and heat shrink method??? even for shielded wires. look up some of the procedures for the repairs, i can print some out for you, no problem.
ill save all you some time http://www.markwilson.com/mustang_ts...e%20splice.pdf ford factor TSB
giantroboteyes.wordpress.com/ |
02-27-2007, 10:32 PM | #14 |
No more nissan.
*sigh*
read. http://fsae.com/eve/ubb.x/a/tpc/f/12.../m/53010954411 As I said before... heat + vibration = solders worst nightmare. But don't use shitty crimps. If you use shitty crimps, you might as well just use shrink + solder. T&N enterprise build and race formula atlantic series cars and they don't use solder. GOOD crimps are factually better than any solder job.
02-27-2007, 11:36 PM | #16 |
alot of that spacial race... connectors are GM style... just for ur info... and soldering wires is still in fashion...
02-28-2007, 10:38 AM | #18 |
when repairing a circuit like joining wires together, go for solder. if you are using a specialty connector and have the crimp tool and prongs, then go for the crimping procedure.
for basic automotive repairs, both work really well. a good crimp tool is quite good. and in certain situations, solder is also good. both are very good techniques, it just depends on whether you need to repair or re-run new wires. in the case of a mafs, just re-wire the entire damn thing. no sense in wasting time with shitty old wiring. i mean, 90% of the users on this forum have NO idea how fuckin dry rotted the wires are in their chassis. our cars are fuckin ancient history, the wiring is WAY past its lifetime.. especially the wiring around heat sources. mike / clearcorners.com |
02-28-2007, 08:02 PM | #19 |
Great. Thanks for the replies guys. I"M GOING TO SOLDER. Just because i don't want to spend the 500 on a 20 dollar problem.
PLEASE HELP ME- I don't know a DAMN THING about wiring... 1.Exactly what wire(guage and composition) do i need 2. what is with this "shielded" wire? 3. Can i re-use the pins in the maf plug or can i buy new ones somewhere? thanks! |
03-02-2007, 08:29 AM | #22 |
ok, gotcha. Thanks again.
Can you quickly expain this "shield" that was spoken of earlier? Is it some type of shrink wrap or is it that 1 inch by two inch square thing that is about 5 inches in from the plug? Again, any help is appriciated as track day is in 24hours and counting down. |
03-02-2007, 11:54 AM | #23 | |
do what russ said, get a better condition connector and cut some it off about a foot back. |
03-02-2007, 12:42 PM | #24 |
LAID OUT
Can someone please link to appropriate shielded signal wire to use if recycling another harness is not an option? I find all kinds of UTX, GTX automotive wire, CAT6 ethernet, etc...
03-02-2007, 07:22 PM | #26 |
ok, i just clipped another plug and am wiring it up now.
Everything is being solderded, shrunk wrapped, and covered in electrical tape. HOWEVER- How do i take care of the shielded wire? Now that i cut it it isn't exactly "shielded"....suggestions? Tinfoil and tape!?!?! LOL. Seriously. |
07-09-2007, 07:11 AM | #28 |
The shielding doesn't matter that close to the plug. If you're splicing it in several inches away (18+) you would want to tie the shield in, but right near the plug you can leave it loose and just pull the remaining portion off.
If it is farther back, solder the wire together first, insulate, then wrap the shield together over that connection and solder again.
07-10-2007, 12:37 AM | #29 |
i am redoing the entire 3 maf wires, meaning i am only going to leave about 3 inches of the maf plug/wires left then i am going to use my own wires to run all the way back to the ecu. so do i need to find some shielded wire then? or will regular wire work?
