Old 09-06-2006, 06:49 PM   #1
95se
95se's Avatar
95se is an unknown quantity at this point
fog light bulb replacement
I am trying to replace the bulb in the fog light on my '95se. I have got the bulb out but can't get to the harness where it is connected. It looks like it connect into a black harness but it is down in the assembly that I can't get to. I have untwisted the back and undone the sleeve the holds the back of the bulb in so its just the harness. I didn't think changing a bulb had to be this much of a pain.
thanks
95se is offline   Reply With Quote
Old 09-07-2006, 07:58 AM   #2
projectRDM
projectRDM's Avatar
You're joking right?
Two M8 nuts remove the lamp assembly. Twist the cover off, unplug the bulb, and unclip it from the housing. You should be able to do a full replacement in less than 60 seconds.
Old 09-07-2006, 08:05 AM   #3
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
lollering so much funny
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 09-07-2006, 11:20 AM   #4
95se
95se's Avatar
Ya, I was having problem getting to the connection point of the lamp wire. It was down in the assembly. I just had to pull on it a little harder. Guess i was afraid I was going to pull it too hard and it up shorting it but it came out pretty easily. I waisted time taking out the stupid assembly. Anyway, thanks it was easy.
