05-10-2006, 12:36 AM | #1 |
fuel pump not working, tried working fuel pump, fuse not blown, help
90 ka24e
everything worked fine before the.. motor/tranny pulled along with wiring harness clutch job installed motor/trans/wiring back in car don't hear fuel pump fuse not blown tried switching with a working fuel pump/egi pump relay fuel pump still not turning on i think the wiring somewhere is fucked, can someone guide me? dirty plugs? cut wire somewhere? ground? |
05-10-2006, 01:39 AM | #2 |
pull codes off the ecu first, see where that gets you. make sure all accessible grounds are fine. then start messing around with a multimeter and an FSM.
It's not that helpful... but i'm sure people will build on it. good luck
Petition Nissan to Make the IDx on http://IDxClub.co ! |
05-10-2006, 07:00 AM | #3 |
Please search and read through this thread. It will have 99% of what you need.
http://www.zilvia.net/f/showthread.p...ight=fuel+pump |
05-10-2006, 07:02 AM | #4 |
^true enough. Recheck your harness connections, they may not be pushed in all the way and not making contact. Plus codes like ''echo'' said. The contact thing happened to me.
