Old 04-26-2013, 01:49 PM   #1
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
Drift Freaq Polyurethane Engine & Trans Mounts! FINAL CLEARANCE SALE!
These are 80 durometer track tested high quality polyurethane engine and trans mounts. There is a link in my sig that will take you to a multi page review. Lots of people here are using my mounts.
[B]The studs do not run straight through the center of these mounts unlike other brands.
You will not get any excessive vibrations from these because of this.
You will get mounts that are better than Nismo and do not rattle your teeth.
A trans mount replacement is recommended as most 240sx stock trans mounts are worn by now. Unless it's been replaced previously. If your shifter moves around a lot your trans mount is probably worn out.
See below for the solution.
Drift Freaq Trans Mounts
The trans mount has exhaust hanger studs!! It also improves your shifting because your transmission no longer moves around under your shift lever like stock. Because of this you get a the effect of having a short shifter without really having one. The shift lever goes straight into its gates quickly and with less effort.
You may experience minor vibrations from the trans mount compared to the feel of a stock trans mount. The trans is responsible for a lot of NVH in our cars hence why Nissan put in the wimpy stock trans mount that let's you shifter wiggle all over. This vibration will diminish as the mounts set in.
I also should point out that the nuts that are provided are Nyloc which means you do not need to torque them down hard. A hand wrench is fine for tightening them. Do not use an air ratchet or impact gun.
This is the latest design with centered studs (that are not connected) in British Racing Green.
Ok Guys this is it we are entering Final days. I am leaving the business. I will be having an End of Business sale with fairly decent discounts.
Which you see below this will be a sale til end of stock.
There will also be no heat shields sold as they are going out of production
$136 shipped for trans mount.
$136 shipped for a set of mounts
$255 shipped for a set of mounts with trans
All sales are final i.e. No returns because you decide you don't want or need them. So please make sure you want/need the item before making your purchase.
my paypal is [email protected]
New Video
Buy my mounts!
drift freaq is offline
