01-01-2008, 12:31 PM | #61 |
I would rather cover the whole bottom and be safe.... besides, this is here and I know who makes it..
I wanted to do a group buy on them.... but since i'm not a sponsor........ |
01-01-2008, 03:37 PM | #62 |
i seen the tomei knockoffs on ebay - anyone verify they are ok?
I still have stock because im poor
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope |
05-13-2013, 11:06 AM | #63 |
Heres an oil pan WARNING and I swear should be stickied. I know of two revisions of the greddy oil pan for sr20, one being marked in small letters between fins on bottom Trust and one with significant lettering on center of bottom Greddy. Greddy has recession inside pan and Trust does not, otherwise identical. Trust pan placed on an s13 sr20det will seal off oil pickup unless you upgrade to s15 pickup tube. Trust pan on s14 or s15 will be just fine. Greddy pan fine for all. Learned a hard lesson to come up with this. Losing a built motor at idle in a minutes time. Be careful out there everyone.
1991 S13.5, 1993 Vert, 1998 180sx |
03-16-2014, 11:13 AM | #65 |
I'm designing a new oil pan at GKTech and am looking for some input from you guys. What would you like to see in it? Features so far are stainless steel construction with internal baffling. We have so far not agreed on whether to use a gasket for mounting surface or silicone seal like oem.
Here is what I have so far: |
03-16-2014, 11:46 AM | #66 |
I prefer liquid gasket seals over paper/rubber gaskets, especially on oil submerged/soaked areas.
A paper/rubber gasket would be another expense for you guys, because as far as I know, no one makes one for the SR oil pan. I'd recommend an oil temp sensor bung, and a splash guard located right around the pick up as to prevent sloshing from breaking suction and grabbing air. Similar to the Tomei style for the RB's. http://www.tomei-p.co.jp/_2003web-ca...B_oillube.html
03-16-2014, 02:14 PM | #68 |
Yes, but theirs replaces the lower baffle that's bolted in the bottom of the motor. If you have it welded into the pan you no longer have to unbolt the factory one.
Obviously it has to be cost effective, but most people buy oil pans, not lower baffling plates...
03-16-2014, 04:51 PM | #70 |
i like my moroso pan so far ...
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
03-19-2014, 10:40 AM | #72 |
Looks awesome... Now price it competitively!
03-20-2014, 06:55 AM | #78 |
Currently the clearance is same as the previous model sold. For a track day a sump guard is IMO a must have so raising it would not be very good for business as it would require all SR guys to have FWD SR pickups. In case you do bottom out on the oil pan the baffle plates will prove stiffness so oil pickup should not be left to starve. We could probably have one made just so we could crush it and see the aftermath. |
03-20-2014, 10:38 AM | #79 |
This would be a great idea and a good selling point. Show before and after the damage, the speed and obstacles that were hit.
06-04-2015, 03:29 AM | #81 | |
I have a prototype fitted on my car: It also clears the anti-roll bar for those running it For production model the bungs are located inside the oil pan
GKTech |
11-09-2016, 09:11 AM | #82 |
Has anybody had the baffles in the Tomei oil pan break free? I've heard of this happening so have been worried about it. Considering swapping my Tomei pan out for a Canton or Moroso pan now.
11-09-2016, 09:16 AM | #83 | |
Trader Rating: (130)
Feedback Score: 130 reviews
I had a trust/greddy, but switched to a phase2 (I had it side by side on the counter with a circuit sport and a tomei, and I can't see any benefit to the tomei, or not enough to justify the price jump http://www.frsport.com/P2M-P2-OPNSR2..._p_963771.html |
11-09-2016, 09:22 AM | #84 |
Honestly I don't know if the one I've been using is a Tomei, Circuit Sport, or P2M pan, they all look the same and mine doesn't have any markings on it. It's been on the engine for a couple years but I've always been concerned with the baffles, and about how slim it is. It seems like the bottom could be pretty close to the oil pickup since it seems to sit a lot higher than the stock or other options.
11-09-2016, 02:19 PM | #87 |
Anybody have input on the Moroso vs. the Canton? The canton might have a better baffle design, but the welds look to be pretty shit inside. Maybe they're better now who knows. I think the Moroso has been ran by a lot of people with no issues.
11-09-2016, 02:21 PM | #88 | ||
(its for sale btw http://zilvia.net/f/showthread.php?t=636040 ) |
11-09-2016, 04:51 PM | #89 | |
Right now I'm leaning toward a stainless pan, but good luck with the sale. |
