03-18-2013, 10:41 AM | #2792 |
03-19-2013, 02:56 PM | #2797 |
03-20-2013, 04:00 PM | #2798 |
I have 275/40/17 Nitto NT05s--not exactly a slouch of a tire and probably the most aggressive compound I can run in a climate that runs down to 35 degrees at night and sees rain frequently.
Even in the dry and in a straight line, as soon as my powerband starts my car will spin 275s in 2nd gear like they were bicycle tires. That's why I want a larger contact patch: it is a function of what compounds are available for a daily driven car that have some grip. |
03-21-2013, 05:40 PM | #2799 |
Can't help you bro.
I used to live in Hazel Dell and 6 months out of the year nothing is gonna help you except for pro efi traction control. I run nt01's daily, but can't recommend them in the wet.
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers |
03-30-2013, 04:45 PM | #2800 |
Just a quick question... What would be an ideal offset to run a 275/40r17 on a 17x9? I'm sure it's in here somewhere, but I thought it would be quicker to just ask instead of reading 94 pages of posts. Thanks in advance
Edit: this is for an s13 |
03-30-2013, 09:38 PM | #2801 |
Whatever gets you as close to the coilovers as you can. Probably +35 or so...
03-31-2013, 07:23 PM | #2803 |
I need help I'm on 17x10.5 on a 225/45 inch tire I need to roll the fronts more. I'm on stance coils, Godspeed toe arms and Yamato garage rucas. Will this do?
03-31-2013, 07:35 PM | #2804 |
You're in the wrong thread.
04-07-2013, 08:28 PM | #2807 |
I have a set of 17x9.75 +25 wheels, and i plan on running 245/45.
i'd like to have no camber on all 4's. My question is- what do i need to do to get it to fit up front? I want to keep stock body, no flares, widebody, nothing. any pics? |
04-13-2013, 01:19 AM | #2811 |
you need 245/40 on a 17" wheel. I had 255/40 on my 17x10J before and it was good IMO. 45 series is too tall on 245+
04-14-2013, 09:22 AM | #2812 | |
Trader Rating: (26)
Feedback Score: 26 reviews
For my s14 I'm looking for a wheel and tire combination. I'm thinking of going with a 17x9. I plan to roll the fenders, but I do not want to pull them and I do not want to run much camber either, the less, the better. Going for a nice semi flush look against the car, no poking, or gay stretched tire. I love the look of Spool_sample's zenki, I think its perfect, but I would like to have mine just a little lower. I have stance coils with stance rucas. Up front I also have z32 brakes. What would be a good setup ? 17x9 + lower or higher offset? Same size tire ? 245/40/17? Hoping one of guys could help me out!
04-14-2013, 11:11 AM | #2813 |
You want slightly higher offsets. +25 in the front is about max on 9" wheels. That same offset will work great in the rear. You can easily get 255's all around as well. A 245 has a slight stretch to it on 9".
04-14-2013, 06:42 PM | #2814 |
My 240
I have a set of work vsxx 3 piece
18x9 (Offset +4) Fullway front tires 225 front 18x10 (Offset +10) Falken rear tires 245 rear....So my question is what kind of decent priced coilovers can I run with these wheels without rubbing or lowering it ..I just want to lower the front some with maybe -2 on the camber all around...any help here..my 1st 240 [IMG][/IMG] |
04-14-2013, 08:29 PM | #2815 |
Wrong thread... You want the small questions thread and 225/245 is not a max tire setup.
04-14-2013, 08:38 PM | #2816 |
04-14-2013, 09:06 PM | #2817 |
BC RACING, stance, and fortune auto
1998 240sx 2jz swap in progress 2006 FULLY built WRX Rotated w/ PPG's |
04-23-2013, 02:09 PM | #2820 |
Hey guys, I currently run Toyo Extensa HP 235/45/17 all around on 17x9.75 +17 front , +25 rear ( i needed a 8mm spacer to clear coils in front) and im looking to get alot of grip in rear when i decide to get new tires. im currently at -4 camber in rear and -2 in front.
I recently decided i wanted to start autocrossing and going to the track and i wanted to know whats a good set-up and even if those wheel measurements are even good for autocross/track. thanks alot, Tim. |
