#2701 | ||
![]() Join Date: Jan 2011
Trader Rating: (26)
![]() Feedback Score: 26 reviews
Sleeve it. Quote:
Sleeve it, forged pistons and rods, stock crank (polished and knife edged if you want) completely blue printed and balanced. Then build the head. Bottom end is nothing without a strong, high flowing head to go with it.
IG/TikTok-ThatS14_Z06guy |
#2703 | |
![]() Join Date: Dec 2004
Trader Rating: (58)
#2705 |
^ What does a certain psi matter. Airflow is airflow. No boost leaks, and the tune is correct keep cranking until it does what you want. This is coming from someone that trapped 120 on a jdm s14 t28 on 22 psi (still running) and DD'd a stock longblock 2860 car at 22 psi forever (still running). Also I see people blow these turbos up using way to thin of an oil. I only use Valvoline vr1 20-50 or Shell Rotella 15-50.
#2707 |
psi matters since the higher pressure a turbo is pushing, it is likely to push air temps higher which drives timing out of the tune. Eventally you run out of incremental power.
When we were professionally custom tuning my GT2871R setup with external wastegate housing, going from 18 psi to 20 psi of boost only added a quarter of a hp because the turbo was heat soaked. |
#2708 |
I'm saying everybody's setup is different and his setup could need more than 20 to make the power he wants. That statement was focused on just the gt28 compressors. I just see guys so hell Bent on making a certain number on a certain psi of boost and that shouldn't be the case in my experience. There's a lot of factors that come into making power so why say I need "x" amount of whp at "x" psi?
#2709 |
Trader Rating: (26)
I shouldn't need more than 18psi to break 400. The oversized valves, S3 cams and ISIS manifold should make a huge difference in airflow.
#2710 |
![]() Join Date: Jul 2005
I like to keep the pressure a slow as possible. That bad day, bad gas, going uphill on the highway, fries in your mouth hands covered with grease, you dont downshift from fifth... it happens and the engine chews small pits out of your head and deck.
Dont be greasy going uphill in fifth gear with 22psi on 93 octane. ![]() |
#2711 | |
likewise, if you could spin 9k you might be able to make 400whp with only 10psi. hang on let me check... Using a garbage quicky math equation for rough estimates on any engine displacement: (122 x 9000 / 3456 = 317CFM * 1.75 * .069 = 38lb/min ) Ah, yes, 11~psi and 9k rpm will get you very close to 400 You are actually in hope of this: (122 x 7200 / 3456 = 250cfm * 2.24 * .069 = 38lb/min) There is a 2L @ 7200rpm and 18psi producing 380 These numbers include compressor losses, and I do not factor drivetrain loss because most of the time the intercooler (airpath) tends to help recover some of that compressor efficiency which makes up for the drivetrain loss in the math. The turbocharger constant, iirc, includes adiabatic efficiency, which means no heat transfer to the environment, which is clearly not our case. From a thermodynamic perspective, what happens between the compressor and the intake manifold can vary GREATLY due to the varying availability of low and high quality intercoolers, and length/size of pipe. |
#2712 | |
#2713 | |
![]() That civic is gonna pass my redtop? I think not! I step down in fifth and the wastegate source falls off... well, at least my shifter doesnt get any grease on it. I look back with fries hanging outa my mouth |
#2714 |
Trader Rating: (58)
18psi on a perfect engine would have a hard time making 400whp. It simply doesn't push enough air.
#2715 | |
![]() Join Date: Jun 2008
![]() Feedback Score: 13 reviews
I dont think 20+ psi is alot for these turbos.... On a T2 housing i think its alot because of the backpressure, which will create more heat and it becomes less effecient. Its almost like taking a deep breath then blowing out with a straw. An external wastegate helps out alot with backpressure and boost control. which is what I highly recommend on the t2 setups with this turbo.
Agreed, but it is possiable. On a bigger turbo its really easy but not an effecient set up due to lag. Back when I had my evo and I was getting it tuned at AWD motorsports it made 386whp at 16 psi on the wastegate spring (Pump Gas) when they started tuning which would feel like crap since it didnt get full boost until 4900, but that was with a HTA3586R turbo. Ended up finishing with 600+ at 33psi. 610whp Stock Block HTA86!!!!! AWD Motorsports Diiirk Tuned - evolutionm.net
1990 240sx fast back ![]() SR20det GTXX71R Sips on E-85 ![]() 1998 S14 Kouki ![]() KA24de Bone Stock...... 2004 Lancer Evolution |
#2716 | |
lol ![]() |
#2717 |
![]() Join Date: Aug 2008
I havent posted on this tread but I just finished my car. Overall im very happy with the results.
List 95 240sx s14 sr gt2871r .64 S3 cams Nistune 740cc injectors OEM mani polished ported and coated 38mm external gate greddy intake stock bottom end, changed bearings and oem rings Numbers 384 hp 347tq at 21psi, still running high flow cat I had tomei mani with internal gate same setup could only mange 357hp at 21psi spiking. ![]() This is the final run, sorry for crappy pix, I dont have print out. ![]() |
#2719 | |
Trader Rating: (26)
![]() True that lol
#2720 |
Stock SR20 stock pistons stock rods everything is stock
![]() How to be safe pressure above engine ? and i'm thinking get GT2871r .64 is this make sense with that engine or do I need any other parts ? This is my first message so I hope you will understand ![]() |
#2721 | |
![]() Join Date: Apr 2011
On a stock block I would not push beyond 16-18 PSI this is of course with a built head, with the whole engine stock I would stick at 12-14 PSI with a good tune ... Remember these engines are OLD !!!
#2722 |
![]() Join Date: Oct 2007
Im looking into building a sr right now ! My friend have a sr that is fucked , I thought of picking it up and doing a 2.2 with the bottom end ! 90mm piston with sleeve
Would it be that much better then a 2.0l ? (looking for 400/450 whp , is it possible with the gt2871r and a 2.2L or i should just go tonthe gt30 trim ) !?!? Your thought please
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
#2723 |
U may consider the gtx2867r too ,never read a bad review on them compared to the 2871r , well look up on codyace he broke the 400whp with the 2871r with stock bottom end but a reliably done up head.
#2724 |
the financial investment to get to 2.2L far exceeds the value it represents. Spend the money going to a twin scroll top mount GTX3067R and spin up faster than any GT2871R while making more than 400+rwhp. Done.
#2725 |
i have the sr for what ! 500$
I have Darton sleeve instaled for around 750$ localy here in montreal , canada And i was forging the bottom end anyway!!! Or keep that money and build a vvl head with the 2.0L bottom end but i know me and the vvl is going to rape me $$$$
#2726 | |
Can i send you money so you can sleeve my SR block? Not kidding 750? I pay 3,000 at my shop for sleeves. |
#2727 |
I just talked with my tuner and he had is sr sleeved there !!!
Two of the sleeve moved in is block ! I wont go that route for sure !
#2730 |
![]() Join Date: Aug 2009
I don't know why people think this turbo will get them to 400whp. It won't. Save yourself some money , time and headache go straight to T3 with 60mm turbine . The cost is the same. Look at the compressor max, hp at 2PR is 450. 15% drivetain loss put you at 382.5whp. Now I have to sell this turbo, manifold, lines and elbow.
