Old 09-28-2016, 08:26 PM   #181
R3b
R3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond repute
Anyone here running and driving with a ka24? Just finished building my motor and was looking to do the z32 swap but now this is catching my eye to do. Should work out cheaper than sourcing a TTz32 manual. Can easily find a wrecked 350z-g35 down here for under 600.
Without including tranny I should be under 1k to just bolt it up right?
Colin Adapter + Clutch release bearing - 394
Gtech cross member(use my nismo tranny mount) and shifter adapter - 277
Steel drive Shaft -300 to 350.
Somone post a write up getting there speedo working with gps signal and dakota box which is around 180 but its that necessary.
R3b is offline   Reply With Quote
Old 09-29-2016, 06:35 AM   #182
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
TT and non TT Z32 trannys are the same, and a non TT tranny goes for about $250, just food for thought before you bury yourself in some debt
[email protected]
hanzbrady is offline   Reply With Quote
Old 09-29-2016, 10:55 AM   #183
R3b
Not around here, most sell them local in the scene for 500-800 and if you look on
car-part.com the lowest ive seen is 300 and high as 700 but all the places are 200 miles away. I can find a cd009 60k tranny 10 miles aawy for 500-600 bucks all day.
I think 1.5k for everything swapped isnt a bad deal. Then in a few years or so when I swap out the ka and do a proper swap all I have to do is get the adapter and new shifter if its sits too far back.
Old 09-29-2016, 08:53 PM   #184
fatduece
fatduece is an unknown quantity at this point
Originally Posted by TheRealSy90 View Post
That's exactly it, you order specific sleeves to set the depth of the throw out bearing.
Got it. Thanks for clarifying!
fatduece is offline   Reply With Quote
Old 10-05-2016, 01:15 PM   #185
rbs14kouki
rbs14kouki's Avatar
rbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to all
Gktech z33 shifter with a Autotech Motoring sr to vq plate (bellhousing machined down .500in)
last week i did a sr to vq swap with the Autotech plate i had laying around on my friend s14 .
here are the spec i took of the transmission and engin to calculate the air gap that was needed in between is clutch and bearing
target was .300in !!! (I know on my paper i used .200 ! i though it was the same spec as an internal release bearing like on our formula d drift car... i was abit off . .300 is perfect)
we had to put a spacer or .400in inbetween the bearing and the carrier ... but from doing this the carrier we had wasnt long enought and the bearing had no more surface to seat properly .
to correct this situation we took the z33 carrier welded it back to back to our sr 24mm carrier ... cut away the portion where the fork attaches .
it looked like this
we machined everithing back to spec :
- outside diam. 40mm
- Inside diam. we left the sr carrier section un-toutch but the z33 portion we welded on had to be machined just abit loosser (from the weld line to the extremity) . that way it wasnt grabing on the shaft where it slides
slip on spacer was .400in thick (inner diam. 40.10mm) ... that way it can slip on without pressing it in for mantenance or to changed the set-up later on .
Then re-installed the bearing
Final air gap 0.290in perfect clutch engagement
AV FABRICATION
Built thread sr20vet s14
http://zilvia.net/f/showthread.php?t=535574
rbs14kouki is offline   Reply With Quote
Old 10-05-2016, 08:06 PM   #186
Yellow4g63
Thanks for the pic. That's the setup I have right now.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Old 10-05-2016, 09:54 PM   #187
rbs14kouki
rbs14kouki's Avatar
For anyone info . I found these part number and spec after i did my last transmissiom swap
Nissan oem carrier part# and mm
12mm : 30501-A3800
14mm : 30501-N1601
16mm : 30501-U0200
18mm 30501-S0200 (Z33)
22mm : 30501-S0160 (Z32)
24mm : 30501-K0404 (S13/S14)
26mm : 30501-K0510 (D21 Frontier / Xterra)
28mm : 30501-N1600 (D22 Frontier / Z31 Turbo) [07/83 - 09/86]
32mm : 30501-U8584 (D40)
AV FABRICATION
Old 10-06-2016, 02:40 PM   #188
t66-240
t66-240 is an unknown quantity at this point
I think I found the perfect solution for the speedo.
Hey Guys,
It looks like the new AEM GPS speedo will be perfect for our cars.
http://www.aemelectronics.com/?q=pro...eries/GPSspeed
- It displays speed, heading and altitude.
- It has a peak hold feature
- it has a fast refresh (10 samples/second)
- Integrates with their ECU's to do track mapping.
- It has a VSS output of 4.444 HZ/MPH which translates to 16k pulses per mile (no converter needed) that our cars use. (someone check my math) so our factory speedo will work too.
At $154 retail it's a really cost effective solution too!
I'm still working on my swap, so it will be while before I try it. If anyone beats me to it let us know how it works.
t66-240 is offline   Reply With Quote
Old 10-06-2016, 02:49 PM   #189
roninwon
roninwon's Avatar
roninwon is an unknown quantity at this point
Send a message via MSN to roninwon Send a message via Yahoo to roninwon
Only thing is more than likely people want the readout from the oem cluster.
roninwon is offline   Reply With Quote
Old 10-06-2016, 02:54 PM   #190
t66-240
I guess you missed the last point which I bolded
This will make the OEM cluster work as well!
Old 10-06-2016, 03:39 PM   #191
Nissansota240
Nissansota240's Avatar
Nissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really nice
Depends if its a sin wave, the s-chassis vss requires a 2 wire input for the speedometer
DLG - DIRTYLOVE
Nissansota240 is offline   Reply With Quote
Old 10-06-2016, 03:49 PM   #192
t66-240
it is a 2 wire output...
I guess worst case use a signal converter?
Old 10-06-2016, 04:03 PM   #193
Nissansota240
This is what I used for mine
Intellitronix GPS Speed Sensor, Dakota Digital Speed Converter
This is how I wired mine up, but I don't remember if my notes where correct, I was in a rush finishing my car before SSC and just happened to get the input/output settings correct. Works perfect though. Probably will double check settings later this fall.
DLG - DIRTYLOVE
Old 10-06-2016, 04:11 PM   #194
t66-240
Thanks for posting that.
This guy figured out a way to skip the Dakota converter.
https://ekwang.wordpress.com/2012/12...0sx-s13-speed/
Old 10-06-2016, 05:14 PM   #195
TheRealSy90
TheRealSy90's Avatar
Link didn't work for me but I'm at work so idk.
Such a good signature.
Old 10-08-2016, 01:20 PM   #196
dwnshft2drft
dwnshft2drft's Avatar
Trader Rating: (28)
dwnshft2drft will become famous soon enoughdwnshft2drft will become famous soon enoughdwnshft2drft will become famous soon enough
Feedback Score: 28 reviews
Has anyone figure out or know a link where I can radioshack a s14 speedo cluster with abs diff?
dwnshft2drft is offline   Reply With Quote
Old 12-16-2016, 05:54 PM   #197
jerry_beans
jerry_beans is an unknown quantity at this point
F I N A L L Y finished assembling my transmission! I'm running the Maverick Motorsports adapter (sent out my bell housing to George FPR machining) and I'm using the GKTech shifter bracket and crossmember!
Anyone know?? will the reverse lights on my car still function?
IG @jerry_beans_
jerry_beans is offline   Reply With Quote
Old 12-16-2016, 06:05 PM   #198
Black240Ct
Black240Ct will become famous soon enoughBlack240Ct will become famous soon enoughBlack240Ct will become famous soon enough
Send a message via AIM to Black240Ct
yeah reverse lights are that blue plug on the drivers side under the shifter in that last pic you posted
Black240Ct is offline   Reply With Quote
Old 12-16-2016, 06:45 PM   #199
jerry_beans
Thanks!!!
IG @jerry_beans_
Old 12-18-2016, 12:39 PM   #200
TheRealSy90
Got my Bellhousing cut off last night, definitely should have got a longer sawzall blade. I got a shorter one thinking it would be easiest. Longer blade is the way to go.
Old 12-18-2016, 03:42 PM   #201
Koukiii
Koukiii is an unknown quantity at this point
Nice thats the collins swap I'm guessing? What clutch are you going with? I'm going with the stage 5 or 6 don't know yet twin disc tho
Koukiii is offline   Reply With Quote
Old 12-18-2016, 03:43 PM   #202
TheRealSy90
Mazworx Bellhousing. OsGiken twin disc, TS2BD.
Old 12-18-2016, 03:48 PM   #203
Koukiii
Can you use a stock 2jz flywheel? I want a nice streetcar without the crazy rattle of the lightweight custom flywheels the other kits make you use.
Really interested in the parts you are using.
Old 12-18-2016, 03:50 PM   #204
TheRealSy90
This is on an sr20 lol.
Old 12-18-2016, 03:56 PM   #205
Koukiii
Sorry bro I'm stoned and this has been on my mind so I just assumed lol
Old 01-08-2017, 10:18 AM   #206
Itsalexwoo
Itsalexwoo's Avatar
Itsalexwoo is an unknown quantity at this point
What throw out bearing do you guys use for the SR to CD009 swap. SR bearing or z33 Bearing or do they both happen to be the same size.
Itsalexwoo is offline   Reply With Quote
Old 01-08-2017, 10:19 AM   #207
TheRealSy90
The Mazworx Bellhousing uses the sr fork, sleeve and bearing.
Old 01-08-2017, 10:25 AM   #208
Itsalexwoo
Itsalexwoo's Avatar
Thanks I need to find out what to use with a Collins sr adapter
Old 01-10-2017, 08:00 AM   #209
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
Anyone having Issues with the GKTech Shifter? ive got all it all assembled on the tranny sitting on a table. The problem that im having is the reverse lock-out, when i push the shifter down to engage reverse, it wont pop back up when in neutral, I have greased the bushing, lightly scuffed it with a file, cleaned up the inside diameter of the new selector (part bushing sits in) to no available. Ive even shimmed the spring a bit to increase the rate. Anyone else have this issue? if so any fix?
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 01-10-2017, 08:13 AM   #210
TheRealSy90
Mine does the same thing but was better after i greased it all up. I just have to lightly pull it up. Really doesn't bother me honestly, I don't use reverse that often lol.
