Old 12-16-2016, 01:52 PM   #20581
SoundEfx
SoundEfx's Avatar
SoundEfx is an unknown quantity at this point
Originally Posted by LoSt180 View Post
If you remove the needle rest stop, you can twist the needle off also.
Does it matter which direction you turn it?
SoundEfx is offline   Reply With Quote
Old 12-17-2016, 12:29 AM   #20582
Lompang
Lompang is an unknown quantity at this point
Anyone else have any experience taking out front collars on megan coilovers for the S14? I only took out one perch in the front and brought them the lowest to the perch left on it and it bounces a lot even on softest dampening setting. I hear that people are actually getting decent ride by taking both perches out? How is that possible when I only took out one and it really is not ride able at all lol.
Lompang is offline   Reply With Quote
Old 12-17-2016, 06:36 PM   #20583
1on1
1on1's Avatar
1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all
Can you provide a photo? I have a feeling your springs are compressed a lot but I can be wrong.
instagram
1on1 is offline   Reply With Quote
Old 12-18-2016, 07:47 PM   #20584
Jrod12
Jrod12's Avatar
Jrod12 is an unknown quantity at this point
I had a quick question if anybody could help me out. I own a 1993 KA 240sx and just the other day I noticed that the heater isn’t getting as hot as it used to this problem literally started this week it still blows hot air but not as hot and if I run it too long it eventually just feels like semi cool air flowing if that makes any sense lol but also if I turn the heater on after warming up the car my temp gauge will slowly will drop to the point where its reading no temperature like if I had just turned the car on I have tried searching but nothing like this problem seems to pop up can anyone chime in on the situation
Jrod12 is offline   Reply With Quote
Old 12-18-2016, 08:37 PM   #20585
Standard
Standard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud of
Sounds like a stuck open thermostat, it's a cheap easy thing thing to try replacing at least. Good luck!
Standard is offline   Reply With Quote
Old 12-18-2016, 08:49 PM   #20586
Jrod12
Jrod12's Avatar
Replaced the sensor and the thermostat back in June do you think it could be anything else?
Old 12-19-2016, 01:28 AM   #20587
black'N'proud
black'N'proud's Avatar
black'N'proud is an unknown quantity at this point
I want to to connect the lines that flow coolant to the iacv and throttle body on the sr20det, but one of the hard lines that circulates the coolant has been pinched off. Is there a way I can still route the lines to flow the coolant properly? Thanks in advance for the advice.
under cover brother
black'N'proud is offline   Reply With Quote
Old 12-19-2016, 11:27 AM   #20588
Standard
Hmm interesting, could maybe be a sticking heater control valve? Not sure where that's located or if our cars even have them, I'll look at the fsm when I get home
Old 12-19-2016, 01:21 PM   #20589
1on1
1on1's Avatar
When you bled your cooling system, did you turn on the heater full blast so the coolant flows through the heater core?
instagram
Old 12-19-2016, 01:56 PM   #20590
Standard
^most vehicles heater control valves open when you start the car, so that's not really necessary. However it sure does seem like a heater core realated problem, what do I know anyway I have the lines looped on mine lol
And hey 1on1,
Saw a pic of your car, looks really good! Much better than that last kit you had I think haha
Old 12-19-2016, 02:06 PM   #20591
1on1
1on1's Avatar
And hey 1on1,
Thanks man!
The only reason why I say to blast the heater because I did that last time, forgot to turn on the heater, and my heater didn't get hot after 20-mins of driving. Then when I bled my system again, the heater worked within 5-mins.
instagram
Old 12-19-2016, 02:25 PM   #20592
Standard
^thats interesting, he should try that for sure!
I just looked at my fsm and there is no mention of heater control valve, good luck Jrod12, let us know what happens
Old 12-19-2016, 10:40 PM   #20593
TheRealSy90
TheRealSy90's Avatar
Some cars like s13's I believe have a cable actuated heater valve.
Such a good signature.
Old 12-20-2016, 08:56 AM   #20594
Crazyced
Crazyced's Avatar
Crazyced is an unknown quantity at this point
I know there's adaptor plates to fit T25 inlet and outlet onto a T28 but does the opposit exist? It seems like my S14 SR20 is fitted with a T25 style HKS 2530 turbo. The pipes have been hacked and extended and I guess it works, I was just wondering if there was something more elegent.
Crazyced is offline   Reply With Quote
Old 12-20-2016, 09:18 PM   #20595
caspa
caspa's Avatar
caspa is an unknown quantity at this point
When you're installing a new chain kit on a ka24de is it recommended to swap the Cam Gears + Crank Gear?
caspa is offline   Reply With Quote
Old 12-21-2016, 04:35 AM   #20596
I'm Redline
I'm Redline's Avatar
If your car fly's the EBay banner on the quarter panel, then NO, you don't(lots of the 240/Honda kids)
If your car flies the I Do Thongs Right banner on teh quarter panel, then you buy the kit that comes with all the timing parts and change the sprockets.
If you're new to 240 like me, and you set your timing to the wrong part of TDC, you bend valves like a BOSS and have to rebuild the head
My work in progress...
Old 12-21-2016, 11:05 AM   #20597
1on1
1on1's Avatar
Im going to assume you purchased this kit, or similar that doesn't have the sprockets. I didn't change out my sprockets when I swapped out my chain/guides.
http://www.frsport.com/KA24DE-DOHC-T..._p_254157.html
As for installing, there are a lot of guides out there and I recommend following the FSM. However, you can follow these guides:
Thread:
http://forums.nicoclub.com/ka24de-ti...t-t555211.html
Video:
https://www.youtube.com/watch?v=WXMEDwEY8C4
instagram
Old 12-21-2016, 11:43 AM   #20598
1on1
1on1's Avatar
Anyone know where I can find replacements for these mirror adjusters?
https://www.instagram.com/p/BN2ghogADQT
Or for anyone who had damaged ganador mirrors, what did you do replace the mirror?
instagram
Old 12-21-2016, 03:13 PM   #20599
caspa
caspa's Avatar
Thread:
Video:
This brings me to my next questions, what chain kits do you guys recommend? I heard many good things about OSK's kit.
I also heard most of nissans parts are rebranded shit.
Old 12-22-2016, 07:03 AM   #20600
aymaeid
aymaeid's Avatar
aymaeid is making his/her stupidity well-knownaymaeid is making his/her stupidity well-knownaymaeid is making his/her stupidity well-knownaymaeid is making his/her stupidity well-knownaymaeid is making his/her stupidity well-known
KA injector? seal? set it on fire?
One of the '95's i daily unfortunately began to misfire yesterday. Bone stock ka24de - 160k. The spark plugs and wires are a month old, so assuming that was my culprit, i pulled them to ensure they were all firing. Indeed they were. I quickly replaced the distributor cap but still; same misfire. When running, the engine had no worse response when cylinders 1's plug was removed, but begins to bog out (misfire worse) instantly if any others were pulled. Im positive the issue is cylinder one, but no clue where to begin. If anyone can give me any advice / what may be going on here, it would be greatly appreciated.
Originally Posted by racepar1 View Post
Talking shit is half the fun of zilvia.
aymaeid is offline   Reply With Quote
Old 12-22-2016, 07:07 AM   #20601
lunchmeat
lunchmeat's Avatar
lunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond repute
Check your injectors.
lunchmeat is offline   Reply With Quote
Old 12-22-2016, 09:04 AM   #20602
aymaeid
aymaeid's Avatar
Forgot to mention i did. injectors are fine. when placing any other injector in cylinder 1, it remains to misfire.
Old 12-22-2016, 09:29 AM   #20603
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
clean your MAF, check for vacuum leaks post MAF
dorkidori_s13 is online now   Reply With Quote
Old 12-22-2016, 09:31 AM   #20604
Crazyced
Crazyced's Avatar
Do a compression test on all cylinders.
Old 12-22-2016, 12:07 PM   #20605
Crazyced
Crazyced's Avatar
Considering that my 92 240sx has an SR20 anyways. Could a service manual for an 89 240sx still apply for everything else? Or are there too many changes? A used one came up for sale.
Old 12-22-2016, 02:05 PM   #20606
theStig880
theStig880's Avatar
theStig880 is on a distinguished road
The only things that would be different would be engine stuff. All of the suspension, exterior, electrical, and interior things would be applicable. Nissan only changed a few cosmetic things but didn't really touch the rest of the car apart from dual cam and super hicas on a few.
Follow me on Instagram or don't @cason880
theStig880 is offline   Reply With Quote
Old 12-22-2016, 03:04 PM   #20607
mau5trap
mau5trap's Avatar
mau5trap is an unknown quantity at this point
Send a message via AIM to mau5trap
Can i get away with the torquing my ka24de Cam Sprocket bolts to 80-90 ft/lbs?
I believe FSM says 123-130ft/lbs but my ka24de is old as turd.
mau5trap is offline   Reply With Quote
Old 12-22-2016, 04:59 PM   #20608
jumpman2334
jumpman2334's Avatar
jumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud of
is there a review on the PBM seats anywhere? I searched the forum and PBM's forum and couldn't find a thing. I am on the fence about em. I have an 'ash white' interior in my altezza and am having trouble finding a seat that would match with the leather, its like a cream/bone white (I planned to sand blast the aluminum PBM inserts and paint cream/bone white to match the leather.)
Also open to other suggestions for seats that are somewhat reasonably priced. I don't have 2k to drop on seats right now.
edit: I hope this is the right place for this weird enquiry, I didn't want to make another thread.
jumpman2334 is offline   Reply With Quote
Old 12-22-2016, 05:05 PM   #20609
jared420sx
jared420sx's Avatar
jared420sx is on the path to ruinjared420sx is on the path to ruin
Sparco evo || youre welcome.
jared420sx is offline   Reply With Quote
Old 12-23-2016, 12:14 AM   #20610
Standard
Just saw crzsteveo post in a thread that he had the pbm bucket seat, maybe try to pm him and ask?
@ Mau5trap, so just because your engine is old you don't think you should torque bolts to factory spec? Just curious, does it seem like too much? I think recommended torque will be fine
