#13051 |
Philosopher King
Does anyone have a good picture or diagram of the vacuum lines behind the head and intake of the KADE? I'm having a hell of a time getting that bowl of spaghetti right.
G O L D E N B E A R R E P U B L I C |
#13052 |
![]() Join Date: Jan 2013
Question :
What kind of spool up time would I be looking at on an RB20, With a T3 turbo Twin scroll-divided housing 1.00 AR Hotside and 78mm Turbine. Anything Think I could be fully spooled ( about 22psi ) by 5k RPM? |
#13053 |
![]() Join Date: Dec 2004
Trader Rating: (58)
I do think it would be close, if not 5500 rpm to run it that hard. It's still a two liter at the end of the day.
#13054 | |
subframe bushings, poly would be better for a daily driver. solid bushings everywhere and you ass is gonna fall out
street dancer. GLEAM |
#13056 | |
![]() Join Date: May 2009
Need to adjust your idle? http://zilvia.net/f/s-chassis/395413...-pictures.html |
#13057 |
for z32 ebrakes, the anchor nut. mine has a nub on it, like on the side that goes into the rotor. now, does the nub face the front of the car or the back?
hard to explain, but the picture should help ![]() the one i have is the one on the left. that nub! does it matter if its closer to the back of the car or to the front? my anchor bolt has r & l written on them but its confusing the fuck out of me
#13059 | |
![]() Join Date: Aug 2012
1. Get photobucket account 2. Upload pictures to photobucket (can be done from PC or phone) 3. Cope IMG code on an uploaded picture 4. Paste on reply area directly ![]() 5.??? 6. Profit
WTB: zenki hood, passenger headlight!! |
#13062 |
![]() Join Date: Mar 2008
![]() Feedback Score: 21 reviews
I am looking for nuts for some project kics spacers. Where can I find them? regular lug nuts don't allow enough space to fit a socket on it.
Any suggestions? This has been bugging me for days. |
#13063 | |
Align bore/hone both the cam journals and crank journal, installing NEW bearings with plenty of assembly lube Overbore the cylinders at least .030 over(this insures exact alignment of all four cylinders). Me, I go as big as I can because cubic displacement still rules, and I love hand grenade engines with big compression and fat lumpy cams If you plan on half assing it, then ignore everything I say from here New pistons, rings, and rods will need to be balanced and blueprinted. This is cheap insurance for reliability and power Head will need new valves, springs, and rockers, all stuff that will lend itself to reliability for added boost GASKETS. Use good gaskets, no bullshit. Cometic has great stuff, and it's not super 'in vogue' expensive like say Apexi Make sure everything is torqued to spec and set to spec so you KNOW it is ready for initial turnover I am probabaly wasting words beacuse you know all this, but I cannot stress the importance of building an engine RIGHT. Doing it right makes for a reliable, powerful engine that will last. Big cams, and huge compression grenades are fun, but for DD, well tune it down about 1/4 or so, but still, 284 - 306 cams DO sound really good(yes, these are freakin HUGE cams with gigantic lobes and freakin sick separation and lift, so racy, but sound sooooo suh WEET!)
#13066 | |
I'd think 14psi should be attainable before 5500? Guess I'll just install the turbo this weekend, fab up the down pipe and see.. I'm shooting for about 400whp. ( I live 6500FT above sea level, so it takes more work to get there ) It's got a 58mm Billet Compressor. I've read that Billet wheels help for better airflow/ slightly quicker spool.. any truth in that? Last edited by OrangeVirus1; 03-14-2013 at 08:04 PM.. |
#13069 |
![]() Join Date: Jan 2011
The SR I bought has 264 cams in it and the owner wanted to trade me for stock ones but has never contacted me since. What do I need to run in conjunction with these cams to ensure nothing will shell out.
#13070 |
I got this one. Inexpensive, low profile, and the pad fits well at any of the frame based jack points...only a enema nozzle will jack the car from a body panel and bend shit(like the prior owner of my car...dipshitmotorfrikkershitheadassclownfucktard bent the bottom body seam using a freakin round bottle jack(yeah, that evident)
Low Profile Aluminum Racing Jack - 2 Ton, Rapid Pump®
#13071 | |
Either way, you are running what from all intensive purposes(by the photos on your build site) a nicely rebuilt bottom end. You should run some 270's or 280's with 91 octane at a total compression of 11:1 with a good tune. You'll need to rebuild the head with better springs and valves(Supertech is good stuff), and smooth out the combustion chambers, and run either quad platinum plugs or at least index your plugs so the electrode is open to the center of the combustion chamber
#13072 |
I have a Z32 rear Brake installment question as well.. I know you won’t need an adapter if you use R33 E-brake cables for the other guy that is asking about the adapter…. Will I need the z32 brake Drums in order for the E-brake to work?
#13073 |
i want to rotate my t 25 compressor housing cause the exhaust manifold interfere with the turbo outlet i have try many option hit with a hammer pry etc pb blaster the huge c-clip etc but it won't budge i want to let the turbo on the engine cause a have a brand new gasket and dont want to mess it up do you guys have an idea for me so i can leave the turbo there and clock the t25
#13074 |
![]() Join Date: Oct 2010
![]() Feedback Score: 9 reviews
Can't find exactly what I'm looking for on here, Google, or KA-T.org...
Has anyone ever done a KA24E-T with bottom mount turbo, stock/factory SR20 IC piping, airbox, and SMIC or turn flow type (retaining SMIC piping of course)? I can't find pics or video. Has this been done or am I about to make my car a unicorn? |
#13075 |
![]() Join Date: Sep 2004
Trader Rating: (24)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 24 reviews
Yes it's been done, but there are no t2 manifolds really available for a sohc, and not ones that put the turbo in stock SR location.
People that have done it have made their own. And just because it's unique (unicorn) doesn't make it good.... take it from someone who has been down the sohc-t path. |
#13076 |
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() Feedback Score: 5 reviews
There is only one t2 manifold I've seen, and that was a gladman manifold. This was eyars ago, and I recall it was a side mount.
EDIT:http://gladfab.myshopify.com/product...turbo-manifold Dunno if he's still around. |
#13077 | |
I'm honestly just planning on a mild build, nothing crazy. |
#13080 |
![]() Join Date: Sep 2010
Hey guys,
Need help with Brake line running across the firewall. I got s14 Non abs and bought brake line relocation kit. The relocation kits replaces 2lines that run on the firewall. Does anyone know what the third line is? Cars in storage so i cant take a look at the moment. IS it for the Canister/evap setup?
IG-jonathanprem |
