Old 04-17-2013, 09:50 AM   #391
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
silviaks2nr,
have you ever done a LHD projector retrofit into the JDM zenki headlamps?
Old 04-17-2013, 09:53 AM   #392
silviaks2nr
silviaks2nr's Avatar
I've never done a retro in jdm housings but it should be the same as any other projector retrofit in a reflector housing. The mounting/adjustment points may change slightly from USDM housings I imagine.
'98 240sx 5spd
kouki 2jz t56 swap build
Old 04-17-2013, 10:39 AM   #393
Mister.E
Mister.E's Avatar
Trader Rating: (53)
word. when funds allow, i will be contacting you. that wont be for quite some time though.
Old 04-25-2013, 07:46 AM   #394
jamg
Originally Posted by RedBullRioter View Post
I got these awhile ago and haven't gotten around to installing them yet. they have a halo although its not hooked up in these photos. I'm going to split the wires on the front turn signals and run them to the halos.
S13 240sx Popup HID Light Conversion Bi Xenon Projector | eBay
Gladman Performance HID conversion - YouTube
Attachment 53240
Close up pic of the projectors.
Attachment 53241
Comes with arms that are shortened to the right length.
Attachment 53242
Highbeams
Attachment 53243
I would like to run the pbm hmic which would require relocating the motor for the flip ups and fabricating new arms like this.
HOW TO: Keep your 180sx pop up headlights with the Part Shop Max Intercooler Kit. 180sx RS13 - YouTube
Also I'm a bit worried about debris breaking the lens. I've been told to make wire mesh and a couple of other weird ideas. The only thing I can think of is retrofitting some casing around the hid but I'm not sure that casing will withstand the heat and you don't want to have vents let moisture in.
that guy wanted $200 for just brackets and arms alone...
i need a retrofit h4, i figured i'd use those brackets.
anyone want to make some for me lol
Old 05-15-2013, 01:40 AM   #395
rat240
Trader Rating: (87)
Feedback Score: 87 reviews
06 mazda5 tail lights
Old 05-15-2013, 05:35 AM   #396
Spark
Spark is a glorious beacon of lightSpark is a glorious beacon of lightSpark is a glorious beacon of lightSpark is a glorious beacon of lightSpark is a glorious beacon of lightSpark is a glorious beacon of lightSpark is a glorious beacon of lightSpark is a glorious beacon of lightSpark is a glorious beacon of lightSpark is a glorious beacon of lightSpark is a glorious beacon of light
My retrofit
Bixenon projectors 5000k
ebay clear headligts
Dont have good night photos, but light is much-much=) better then stock.
like 80% better=) couse stock headligts suck
RPS13 TypeX
Zenki=>Kouki
Spark is offline   Reply With Quote
Old 05-19-2013, 10:51 PM   #397
rat240
Trader Rating: (87)
Finished these yesterday
Old 05-19-2013, 11:07 PM   #398
Driftpretty
Driftpretty is an unknown quantity at this point
If anyone wants some projectors from a kouki s14 let me know! i was gonna do something cool with them. but changed my mind.. pm me!
just cause your cars crappy, doesnt make it a missile
Driftpretty is offline   Reply With Quote
Old 06-10-2013, 04:31 PM   #399
soryu
soryu's Avatar
soryu is an unknown quantity at this point
anyone got shots of other s13 headlights? bricks, projectors, cibie, stock, ebay
here's hella's with nightbreakers
The lights are pointed toward the center here.
I adjusted them later pointing forward
soryu is offline   Reply With Quote
Old 07-07-2013, 12:21 PM   #400
40craz
40craz's Avatar
40craz is an unknown quantity at this point
Ho hard was it to retrofit the hids into the s13 headlight?
40craz is offline   Reply With Quote
Old 07-10-2013, 12:46 AM   #401
240sxDavid
240sxDavid is an unknown quantity at this point
Not sure if im retarded or what the deal is, but I have these s13 bosch foglights I just bought aaaand I cant take off this H3 bulb uploadfromtaptalk1373438775710.jpg
Originally Posted by 4nmscle View Post
How much power does your shit box make there champ?
240sxDavid is offline   Reply With Quote
Old 07-10-2013, 01:15 AM   #402
soryu
soryu's Avatar
That doesn't come off.
That's how they are.
Old 07-10-2013, 01:32 AM   #403
240sxDavid
Thank you soryu, how do I replace it?
Sent from my SGH-M919 using Tapatalk 4 Beta
Old 07-10-2013, 01:35 AM   #404
soryu
soryu's Avatar
Just buy new bulbsand that's it.
Bulbs come with that metal piece attached.
Old 07-14-2013, 06:29 AM   #405
240sxDavid
Found em Thanks, have any of you guys modified type x foglights in any way? Tint/vinyl/led
Old 07-14-2013, 08:08 PM   #406
Andres_G
Andres_G's Avatar
Andres_G is an unknown quantity at this point
Originally Posted by 240sxDavid View Post
Not sure if im retarded or what the deal is, but I have these s13 bosch foglights I just bought aaaand I cant take off this H3 bulb Attachment 57504
That's an H3C bulb.
I asked this same question in 2010
What bulb is this?
Also, check this out:
Lexus LS400: How to Convert H3 Bulbs into H3C Bulbs
Andres_G is offline   Reply With Quote
Old 07-14-2013, 09:21 PM   #407
240sxDavid
Makes sense, ill take that into consideration, Thank you
Old 07-31-2013, 10:58 PM   #408
driver11324
driver11324's Avatar
driver11324 is an unknown quantity at this point
Just finished up my X5M retrofit into the JDM kouki headlights. Wired up the bixenon solenoid and using the old high beam housings as fog lights.
driver11324 is offline   Reply With Quote
Old 07-31-2013, 11:37 PM   #409
soryu
soryu's Avatar
^^Cutoff pics?
Old 08-01-2013, 11:18 AM   #410
tapdeznutz
tapdeznutz's Avatar
Trader Rating: (50)
tapdeznutz is an unknown quantity at this point
Feedback Score: 50 reviews
2nd that, i want to see the lighting in front of the car, see how bright it is. it does look very nice though. i still need to post up my s13 pop ups. hope to have them done this weekend.
FS: DSS 1pc Steel Non ABS, 6bolt axles
WTB: Boost Gauge, Hatch Roof Wing
tapdeznutz is offline   Reply With Quote
Old 08-09-2013, 09:44 PM   #411
driver11324
Originally Posted by soryu View Post
^^Cutoff pics?
Not the best pic but the lights are BRIGHT!
Old 08-10-2013, 09:31 AM   #412
silviaks2nr
not my work
http://www.youtube.com/watch?v=c5MqsW7PXaY
Old 09-19-2013, 10:06 AM   #413
silviaks2nr
bump.
refinished/candied some more kouki tails. I did an HID/ quad projector retrofit on this car as well.
Old 09-19-2013, 10:28 AM   #414
Andres_G
Andres_G's Avatar
Nice! But for my taste, I think the orange would have looked better. Any photoshoppers in here?
Old 09-19-2013, 11:02 AM   #415
new2sr20
new2sr20 is an unknown quantity at this point
the candied/refinished tails look great. Kudos sir. Care to share what clear you used? and has the factory black been repainted with black again?
new2sr20 is offline   Reply With Quote
Old 09-25-2013, 07:23 PM   #416
S T Y L E S
S T Y L E S's Avatar
S T Y L E S is an unknown quantity at this point
Let's see more lights!!
S T Y L E S is offline   Reply With Quote
Old 09-25-2013, 09:05 PM   #417
silviaks2nr
Not a nissan but...
2008 highlander
oem rx350 bixenon projectors modded with clear lenses
blue chrome bezels
I'll get some pcitures of the s14 quad retro I just did soon.
Old 09-26-2013, 09:50 AM   #418
ixfxi
ixfxi's Avatar
ixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfection
Originally Posted by future View Post
The minis blow to be honest
its all cheap overseas junk. i didnt even want to post in this stupid thread, but i figure i would post a screen cap of the typical junk mail i get on the day to day from stupid vendors overseas who think i want to sell cheap shit. apparently, now there is an ULTIMATE version of the mini... 100% increased light output. really! ONE HUNDRED PERCENT! i wonder where they get their facts and claims from. I mean, if the previous version was so good, imagine how good this one is... 100% better! its a win-win situation. and for us vendors, buy 100 and get 20 free. i mean, they're just giving this shit away. lucky!
Originally Posted by tapdeznutz View Post
dang silviaks2nr, wish i knew about the d2H style bulbs before i blew a few bucks on used d2s/r's
d2h ISNT a real bulb, it does not exist. however, companies overseas are quick to assign names to an inferior/flawed product. so, thats that... let there be a d2h bulb.
just like there is no such thing as a xenon bulb for halogen enclosures (h1, h4, etc). but if you search ebay, you'll find plenty of illegal, non-compliant, flawed junk online...
its all CHEAP SHIT, no different than the godspeed intake manifolds
ixfxi is offline   Reply With Quote
Old 09-26-2013, 01:37 PM   #419
Trap Star
Trap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant future
Send a message via AIM to Trap Star
Anyone know where I could find a set of stock s13 triple projector headlight covers? The PO of my headlights decided to replace the factory ones with clear ones and I'm thinking thats why my headlights are pretty much worthless from a functional standpoint. Right now they only cast a little bit of light about 5ft. Shits weak.
86 300zx/90 240sx/97 240sx/96 LS400/03 350z
-Shake N' Break Racing-
Trap Star is offline   Reply With Quote
Old 09-27-2013, 09:41 AM   #420
ixfxi
ixfxi's Avatar
i guess not all people understand how projectors work
wtf
