10-18-2015, 06:19 PM | #3511 |
...so I think I've been on here long enough to warrant one freebie? No? Can that be a thing? Just wondering what some good sizes are for 17" on a stock-bodied S13. I had 17x9.5+15 and it was too much. I'm thinking 17x9+22 but want some second opinions. Any pictures, Zilvia nerds?
The mark of a true sucka: 'RARE JDM' & 'OLD LOGO NISMO'
10-18-2015, 06:53 PM | #3512 | |
17x9 +22 with 235/40/17 tires all around. Latez |
10-18-2015, 06:57 PM | #3513 |
Meaty ass tires. Any of you stance guys wanna chime in?
10-19-2015, 03:16 AM | #3514 | |
Not sure about the new backspacing but If you can continue to fit 255's up front Id run 255F 275R. Could go bigger but may need a big roll pull flatten hammer etc. |
10-19-2015, 12:26 PM | #3515 |
Somebody help a noob out.
Will these wheels fist on my S13 with 300ZX non turbo calipers? http://www.summitracing.com/parts/clm-7015055/overview/
Hyer. |
10-19-2015, 08:27 PM | #3516 |
I need to be recommended a good inner/outer tie rod combo for an s13 with +25mm extended flca. I am leaning towards pbm inners but the description says there is limited motion on their ball joint.
11-03-2015, 10:13 PM | #3517 |
Going to be putting a pair of Shoki's on my s14 pretty soon. I'm dabbling in tire size ideas. I'm thinking for the front 18x8.5 +18 with 215/40 and the rears 18x9.5 +15 with 225/40. Anyone here running that? Some reference photos would be awesome.
11-05-2015, 02:16 PM | #3518 |
I need some 7mm slip on spacers to use to get my wheels to fit my car. I also have ARP extended studs all around. Would I need to get hub centric spacers or would the standard 7mm spacer be okay?
11-09-2015, 08:02 PM | #3519 | |
17x9 +25 with a 3mm sspacer up front for clearance. Stance has the adjustment or camber on the top mounting bolt... Max negative.. Tires are 225 45 17. slight roll up front and rolled flat roun back. Rear camber is about -1.2ish Wanna do 235 40 17s though |
11-13-2015, 04:53 PM | #3521 |
Looking at a set of 18x9 +22 front and 18x10 +15 rear on a stock bodied kouki s14. Car has z32 brakes and nismo strut/spring combo. Any mods needed to fit these? Looking at 235/40 front and 245/40 rear. I'm a z32 guy modding my wife's s14 so excuse the noob fitment question.
Thanks in advance guys |
11-30-2015, 07:16 PM | #3523 |
I'm trying to fit 18x9.5" +25ish rota p45rs onto my fronts on s13 body.
I'm assuming I would need to pull my fenders or buy overfenders. I currently have no mods except for section coilovers with camber plates and 15mm spacers. Is it possible to fit these p45s on? If I left out any info, let me know. Just curious as to whether I may need to buy aftermarket steering or suspension parts before I install everything. |
11-30-2015, 10:39 PM | #3526 | |
Follow me on Instagram or don't @cason880 |
12-11-2015, 08:15 AM | #3527 |
12-18-2015, 07:43 PM | #3531 |
12-19-2015, 08:11 AM | #3533 |
run 225-45-17 0* and you will be fine. Those are wide enough to fill the wheelhouse, and offer just enough sidewall angle that they will not rub with a '0' fender gap(lowered to be even with the tread)
12-21-2015, 10:10 AM | #3534 |
What are peoples opinions on Cosmis Racing wheels?
Anyone have an appropriate fitment for the front/rear with stock fenders? (s14, Rolled inner lip) I know Enkie RPF1 18x9 +22 (front) & 18x10 +38 (rear) with fat 255 and 275 tires fit (not sure if that really helps) |
12-29-2015, 04:56 PM | #3535 |
Glad to see this thread is still going strong. Good to see members help one another. Maybe I'll get another s13 and get back in the s chassis loop again. Ha
http://thatistupid.tumblr.com/ |
01-02-2016, 10:40 AM | #3536 |
Ok looking into ....MBBattles plan is 17x9.5 +15
First off in rocking the s13 with an aftermarket coilover right now... No clue what is is And the from z32 brake upgrade So 1 with the rim clear the brakes? And 2 do I need to space due to the coilover And what size tire should I run And to wrap all this up I am 10000% noob when it come to tires plz treat me like a retard Thanks! |
01-02-2016, 11:48 AM | #3537 | |
MRP Manufacturing |
01-02-2016, 05:58 PM | #3539 |
Yes, you will still need it especially in the rear
MRP Manufacturing |
