Old 01-12-2013, 07:52 PM   #271
mcnaughty
mcnaughty is an unknown quantity at this point
Originally Posted by kiriyama View Post
How you do that? lol
2UP S13 Clear Headlight Covers - 2UP Japanese Styling it comes with instructions on how to strip the old lenses off it was easy as
mcnaughty is offline   Reply With Quote
Old 01-12-2013, 09:25 PM   #272
tapdeznutz
tapdeznutz's Avatar
Trader Rating: (50)
tapdeznutz is an unknown quantity at this point
Feedback Score: 50 reviews
are you LED mod guys running individual resistors to each of the led's? and what rating resistor you using.
FS: DSS 1pc Steel Non ABS, 6bolt axles
WTB: Boost Gauge, Hatch Roof Wing
tapdeznutz is offline   Reply With Quote
Old 01-12-2013, 09:40 PM   #273
rat240
Trader Rating: (87)
Feedback Score: 87 reviews
its not good to run them like that
in my tail lights im using one resistor for every 4 leds
use this site LED series parallel array wizard
Old 01-13-2013, 02:33 AM   #274
Tempo
Tempo's Avatar
Trader Rating: (39)
Tempo is an unknown quantity at this point
Feedback Score: 39 reviews
Originally Posted by hellion240sx View Post
Wow... have a frontal shot?
IG - allen.kerose
Tempo is offline   Reply With Quote
Old 01-16-2013, 09:19 PM   #275
ixfxi
ixfxi's Avatar
ixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfection
my wife looked at that photo and said, in her wonderfully broken english
"what is it inside that, some tube?"
yes indeed. some tube. this thread is so awesome.
ixfxi is offline   Reply With Quote
Old 01-16-2013, 09:43 PM   #276
90240sx07
90240sx07 is an unknown quantity at this point
Originally Posted by mikeyee View Post
Photo by solo_8 • Instagram
installed a FD "style" 3rd brake light and front windshield light on a friends s13. also threw a switch on the front windshield brake light to keep off while driving around town, then on while at the track.
got a write up for the fd light or a wiring diagram i wanna throw one in front and back on my hatch for track days or extra lighting at night for safety
90240sx07 is offline   Reply With Quote
Old 01-16-2013, 09:54 PM   #277
driver11324
driver11324's Avatar
driver11324 is an unknown quantity at this point
Just Finished up my NSX projector retrofit in the stock kouki headlights
Forgot to snap a pic of the cutoff
driver11324 is offline   Reply With Quote
Old 01-16-2013, 09:55 PM   #278
K_style
K_style's Avatar
Trader Rating: (63)
Feedback Score: 63 reviews
Nice Blue color... what kind of blue is that?
Old 01-16-2013, 09:56 PM   #279
driver11324
BMW Lemans Blue
Old 01-16-2013, 11:54 PM   #280
rat240
Trader Rating: (87)
for the rear you can tap to the 3rd brake light or tail lights
for the front you tap the fuse box brake wire
Old 01-17-2013, 12:08 AM   #281
Matej
Trader Rating: (39)
What is the best way to make the low beams stay lit while the high beams are activated on an S13?
I know it has been discussed countless times, but I assume the light masters will know best.
One supposed method that sounds most simple and appealing is to use the pop-up headlight motor wiring as the power source for the low beams (the headlight motors would not be used). Apparently it sees constant power whenever the low/high beams are on, plus it already has its own relays and fuses. The high beams would remain wired normally. Can anyone confirm if this method works?
Old 01-17-2013, 07:13 AM   #282
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
This is what i used to wire my headlights when i converted to bricks from pop-ups. it tells you which wires to splice together to keep both beams on. Unfortunately the pics arent up anymore.
Installing Silvia Non-Projector (Brick) Headlights : 240sx Articles
Old 01-17-2013, 09:52 AM   #283
silviaks2nr
silviaks2nr's Avatar
Use an H4 relay harness with a diode between the low and high beam +12v.
'98 240sx 5spd
kouki 2jz t56 swap build
Old 01-17-2013, 10:02 AM   #284
tapdeznutz
tapdeznutz's Avatar
Trader Rating: (50)
please elaborate...^^^
Old 01-17-2013, 10:07 AM   #285
silviaks2nr
I know for a fact this harness works for h4 so your low and high will stay on at the same time. I use them for my s14 zenki retros
Bi-xenon: 'MotoControl 9003/H4/HB2 - Relay Harnesses from The Retrofit Source Inc
'98 240sx 5spd
Old 01-17-2013, 10:16 AM   #286
silviaks2nr
Looks real nice. What projectors do nsx's use? Is it a small d2s kioto with the black plastic lens holder? Get some clear headlight lenses on there if you can.
'98 240sx 5spd
Old 01-17-2013, 01:19 PM   #287
driver11324
From what I've read, they use the same projector as the TSX but they are in a different housing. I had to trim the NSX housing to fitImageUploadedByTapatalk1358453960.856418.jpg
Old 01-17-2013, 04:33 PM   #288
silviaks2nr
Interesting. That looks more like an sc430/s2000 projector, not a tsx.
'98 240sx 5spd
Old 01-18-2013, 03:55 AM   #289
Matej
Trader Rating: (39)
How does the 'two-wire' lamp stay on with the high beams? I thought the low beam wire (red/blue +) does not receive power when the 'ALT' (red/white +) is switched on. Though it looks like the S13 Silvia headlights still use a dual-beam H4 bulb.
My headlights will have separate low and high beam projectors, so it will be more similar to wiring S15 headlights on an S13. I have been searching for ways to keep the low beams on when the high beams are activated, and stumbled across this:
If all you need is the High and low beams to come on at the same time you can modifty the headlight switch so that both the high and low are on at the same time with the high beams selected. Just take off the back plastic piece of the switch and there is a square plate in the switch that has dips in it. This piece slides along the plastic piece pushing up on the contacts. There is a spot on the plate where it is just a indentation. this is the high beam spot. Notch it out to the edge of the plastic piece and put back together. Viola!, no extra wiring.
So far that sounds like my favorite method, though I have not been able to find any more details, or if it really works.
Is this the plastic piece it talks about? I am not quite sure what to notch.
Old 01-21-2013, 08:20 PM   #290
kouki-gymkhana
kouki-gymkhana is on a distinguished road
If you will be running HIDs, then you MUST use a relay-based harness. I made a custom one when I retrofitted D2S H9 projectors and separate H9 high beam modules into pop-ups on my s13. I made a separate trigger switch on the dash to activate the HIDs and the harness design allows them to stay on once the high beams are triggered. I will be revising this setup so that the OEM headlight stalk will trigger the HIDs with information from the following link:
Xenon (HID) retrofit
Granted, this applies to the s14 switch but the principle should be the same for the s13. Hope that helps...
**The atypical S-chassis enthusiast***
kouki-gymkhana is offline   Reply With Quote
Old 01-28-2013, 06:59 PM   #291
240sxDavid
240sxDavid is an unknown quantity at this point
So I fitted these projector foglights I took off of a lexus at the junkyard and installed them on my car and surprisingly its a direct bolt on for the s13 pignose besides wiring and buying longer bolts for bracket to work. I don't know if all pignose bumpers come pre drilled but mine was and the install was fairly easy I'm loving them
Onto what you guys wanna see PICTURES:
Originally Posted by 4nmscle View Post
How much power does your shit box make there champ?
240sxDavid is offline   Reply With Quote
Old 01-29-2013, 12:12 AM   #292
rat240
Trader Rating: (87)
not finished yet
Old 01-29-2013, 12:42 AM   #293
Matej
Trader Rating: (39)
This would most likely be with using one of these terrible LED bulbs for the high-beam:
The output of them is supposed to be terrible, which is exactly why. I never really use the high-beam anyway, so I would mainly just like to figure out a good way to make it look lit along with the low-beam, without blinding people. I have also considered hiding small LED's as 'running lights' inside the projector housing, but at the same time I do not really want to cut up and ruin the headlights.
My other idea is to use two low-beam projectors.
Would it be alright to use a low-beam projector in place of the high-beam one in a headlight housing, or does the shape of the outer glass play a role as well?
Old 01-29-2013, 09:15 AM   #294
tapdeznutz
tapdeznutz's Avatar
Trader Rating: (50)
did you get those off an early model Lexus ES300?
Old 01-29-2013, 09:44 AM   #295
Nategreat923
Nategreat923's Avatar
Nategreat923 is making a name for him/her selfNategreat923 is making a name for him/her self
Man, that's a good idea for the switch. Here's mine:
Nategreat923 is offline   Reply With Quote
Old 01-29-2013, 09:46 AM   #296
240sxDavid
Yeah this is what they look like with bracket
Sent from my T-Mobile myTouch 3G Slide using Tapatalk 2
Old 01-29-2013, 09:52 AM   #297
silviaks2nr
they are kioto yellow fog projectors, same as found in zenki s14, is300, etc.
'98 240sx 5spd
Old 01-29-2013, 09:59 AM   #298
bejota180sx
bejota180sx's Avatar
bejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura about
just out of curiosity... would any of you recommend some decent priced LEDs to PRACTICE with... something cheaper than the high quality stuff im finding so i can practice and then if i get the hang of making decent stuff...
Originally Posted by Taniguchi_Is_#1 View Post
...this is zilvia; prepare to get your feelings hurt.
bejota180sx is offline   Reply With Quote
Old 01-29-2013, 03:40 PM   #299
tapdeznutz
tapdeznutz's Avatar
Trader Rating: (50)
get ebay led's
Old 02-01-2013, 11:46 PM   #300
t_rempel
t_rempel's Avatar
t_rempel is an unknown quantity at this point
If you're wanting to practice for a retro on your car, superflux leds like Phillips Lumileds are a quality product and are cheap enough to experiment with. Good quality, affordable and binned... dont know what else you'd want.
Superflux LEDs will also look 1000x times better than 5mm leds when finished... Unless you like the lite-brite look with terrible viewing angles.
t_rempel is offline   Reply With Quote
