Old 12-15-2019, 12:52 PM   #22951
Colorful.Knightz
Colorful.Knightz is an unknown quantity at this point
just bought a 240sx s13 and changing all the fluids. For power steering should is use ATF or just regular power steering?
Colorful.Knightz is offline   Reply With Quote
Old 12-15-2019, 02:09 PM   #22952
cured13
cured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura about
https://zilvia.net/f/showthread.php?...power+steering
cured13 is offline   Reply With Quote
Old 12-15-2019, 04:56 PM   #22953
Cirez D
Cirez D's Avatar
Cirez D is an unknown quantity at this point
Battery recommendation for a 240sx ka24de?
I was going to get Optima, but hearing real bad reviews about their current stuff.
Cirez D is offline   Reply With Quote
Old 12-15-2019, 05:01 PM   #22954
mint40
mint40 is an unknown quantity at this point
I bought a optima redtop for my ka two years ago and havent had a problem with it.
mint40 is offline   Reply With Quote
Old 12-15-2019, 09:19 PM   #22955
gio240sx
gio240sx is an unknown quantity at this point
HID Headlight help
just bought a 97 240sx and headlights are crap, i want to upgrade to some HID headlights but not sure of a good brand to go with, anyone have some recommendations?
gio240sx is offline   Reply With Quote
Old 12-16-2019, 07:47 AM   #22956
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
did you try aiming/aligning the headlights first?
Old 12-16-2019, 09:04 AM   #22957
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
if this is strictly a daily, just get an interstate from Costco
if this is a track car where weight is priority, get a Corner3 battery
http://www.corner3motorsports.com/corner-3-garage/
send john an email. Theyre developing a new lithium ion battery that's like 3lbs.
Old 12-16-2019, 10:09 AM   #22958
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
mr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond repute
Feedback Score: 31 reviews
I've had my redtop for 4 yrs. Two of them it's been sitting on a shelf while I build my new chassis. I just charge it off my Xterra once a month or so to keep it topped off, and it's been good.
Sent from my Galaxy Note 10+ using Tapatalk
mr.nismo. is offline   Reply With Quote
Old 12-16-2019, 02:33 PM   #22959
Cirez D
Cirez D's Avatar
Cool, thanks for your input guys!
Old 12-16-2019, 05:25 PM   #22960
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
Synthetic ATF. PS fluid of today's cars vary by manufacturer, and will each through inner tie rod seals. MOTUL or REDLINE have never done me wrong.
Old 12-16-2019, 05:32 PM   #22961
S14rebuild
Inner tie rod seals? What is this seal u speak of?
Old 12-16-2019, 06:29 PM   #22962
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
It's the seals that are at each end (also called end seals coincidentally) of your rack and pinion internals.
Old 12-16-2019, 07:23 PM   #22963
gio240sx
Fuel Pump Leak
Hey so i’ve been smelling gas for the past few days and decided to check my fuel pump today, when i checked it out and disconnected the two connectors; gas immediately came out of them. i then proceeded to plug everything back in and give the car a little throttle, which led to a little bit of gas leaking out of the side of this plastic piece, anyone know exactly what this plastic piece is called? i’m gonna replace it and see if that fixes it, thanks!
https://ibb.co/YLS46Wg
Old 12-16-2019, 09:20 PM   #22964
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
Fuel pump sending unit. It only leaks when the car is running?
Old 12-17-2019, 11:37 AM   #22965
frsh2fourty
frsh2fourty's Avatar
frsh2fourty has a spectacular aura aboutfrsh2fourty has a spectacular aura aboutfrsh2fourty has a spectacular aura aboutfrsh2fourty has a spectacular aura aboutfrsh2fourty has a spectacular aura aboutfrsh2fourty has a spectacular aura about
Send a message via AIM to frsh2fourty
Whats the best way to install/seal the metal water neck outlet that goes in the block just behind the thermostat housing on an SR?
Its a press fit piece the machine shop had to remove when cleaning up the block for the rebuild. I have some loctite 660 retaining compound I used on the valve cover breather tee I was thinking of using but wanted to see if there was something better.
frsh2fourty is offline   Reply With Quote
Old 12-17-2019, 03:51 PM   #22966
aymaeid
aymaeid's Avatar
aymaeid is making his/her stupidity well-knownaymaeid is making his/her stupidity well-knownaymaeid is making his/her stupidity well-knownaymaeid is making his/her stupidity well-knownaymaeid is making his/her stupidity well-known
Whats the valve stem size on 5Zigen FN01R-C wheels?
A tire installer said he didn't carry a size that small and i had to buy them. Google got me no where. any help would be greatly appreciated
Originally Posted by racepar1 View Post
Talking shit is half the fun of zilvia.
aymaeid is offline   Reply With Quote
Old 12-17-2019, 03:52 PM   #22967
aymaeid
aymaeid's Avatar
edit: nvm its .453. has to be
Old 12-17-2019, 05:30 PM   #22968
[240sx]
[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute[240sx] has a reputation beyond repute
...anyone know exactly what this plastic piece is called?
The Bulk head? :shrug:
https://zilvia.net/f/showthread.php?t=573370
Sent from my SM-G970U using Tapatalk
[240sx] is offline   Reply With Quote
Old 12-17-2019, 05:35 PM   #22969
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
Bulkhead/sending unit, whatever you want to call it. But if it just leaks when running/a little after, the lines themselves could be leaking. Otherwise it's up to the plastic of the sending unit or seal for it.
Old 12-18-2019, 08:36 AM   #22970
S14rebuild
When explaining something proper names and terminology go a Long way
Old 12-18-2019, 09:28 AM   #22971
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
You'd be surprised how many different names manufacturers give for the same part.
Old 12-18-2019, 12:19 PM   #22972
S14rebuild
Been an ase master tech since 2005, never one have i heard the name inner tierod seal.(doesnt seal the inner tierod) just sayn. Thats for teachn me something new?
Old 12-18-2019, 01:29 PM   #22973
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
Also an ASE master tech along w/ my L1 if were trying to flex certs lol. I understand literally what you mean, but it's a name for that seal I heard a lot working with old timers, so it stuck. Just like diagrams I've seen that call a FWD axle seal a "transmission output shaft seal" even though the axle has the shaft and it's not a stub with an axle. Doesn't make literal sense, but it's been named that.
Old 12-19-2019, 10:05 AM   #22974
S14rebuild
No flexing here..just statements
Ur example of transmission output shaft seal does not make sense, so idk where ur going with that one. Many cars have axles that dont have stubs there splined on to the "outputvshaft".. and that seal does in fact seal the output shaft/axle nose
No where on any rack and pinion is there a seal that "seals" the inner tierod. Theres no fluid pressent on the inner tierod. In fact the deaign keeps the tierod away from the seal so it cant nick or damage it.
We really dont have togo back and forth on this. I was simple correcting/educating you on proper components. Thats all. Nonharm no foul
Old 12-19-2019, 10:22 AM   #22975
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
You seem to want to though? Like before, I understand what you are literally saying. You don't have to keep explaining the parts of a rack. The point I was trying to make is there are times that the names of parts don't make literal sense, but is still understood.
Old 12-19-2019, 02:25 PM   #22976
S13pandaLS
S13pandaLS is an unknown quantity at this point
Ka24de won’t start in 240sx
So I just installed a running s13 ka24de from another 240, into my s13. My problem is that I’ve hooked up the engine wiring harness and the accessory engine harness to most of there respected places including grounds, except for stuff like lights.
And yet my 240 won’t even begin to turnover when I turn the key but the car does get power. I know the starter is good. Could there be a sensor that I’m just not seeing that is preventing the car from starting?
S13pandaLS is offline   Reply With Quote
Old 12-19-2019, 03:21 PM   #22977
brndck
brndck's Avatar
this is way too vague.
1. was the car dual cam before? or are you swapping from sohc to dohc?
2. what else changed? was it auto before and now its manual? if all you did was replace a dohc with another dohc, obv you missed a plug, or forgot to check something, etc.
3. when you turn the key to the on position, do you get power at the ecu? does the eccs relay engage? when you turn the key to crank, does the starter engage? does the fuel pump prime and provide pressure? do you have spark?
theres a ton of things you need to check first before looking for answers. otherwise we're just guessing.
Old 12-19-2019, 05:21 PM   #22978
S14rebuild
Sounds like u didnt hook up the starter solenoid wire(black femal connector with black/yellow wire)
Old 12-21-2019, 01:30 PM   #22979
gio240sx
Window Regulator Won’t go all the way down
As the title says my window regulator won’t go all the way down, i took the door panel off to get access to it and once i attempted to roll the window down it stopped about halfway. Any idea on how to get the regulator to go all the way down?
Old 12-21-2019, 02:38 PM   #22980
S14rebuild
See whats jamming it. These cars have a vert basic and simple setup for the windows, remove it and inspect it
