![]() Join Date: Oct 2011
Chassis harness delete?
Im trying to remove as much of the chassis harness as i can, I just want bare bones. I want to run a switch panel. Has anyone done this and have any pointers? My guess would be looking at the relays and finding which ones i dont need and then removing the wires for that specific relay?
![]() Join Date: Jul 2005
Grab the box, start pulling, find the first thing stopping it from coming out, remove that thing, keep pulling, don't stop
thats how I relocated mine. Removing it? You must be bored |
#7 | |
Well I'm building a track car and I want minimal wires to clean everything up and make ts wiring much easier. I just need the essentials so i figured instead of chopping up the harness and de-pinning I would just run my own wires and relays but seeing all these wires I'm skeptical on what I actually need. |
Why not just remove the circuits and accessories you don't want from the current harness? Unless there's a physical problem with the wiring there's no need to remove it all. Most "track cars" have original wiring, unless there's something really wrong, like it's a British car.
#9 | |
#10 | |
buy the super awesome 'bare bones' harnesses I just pulled outta my car
*some assembly required*
@UpshiftEngineering |
![]() Join Date: Jun 2003
Trader Rating: (130)
step one: acquire a FSM
step two: hit yourself in the face with it step C:??????? step 9: PROFIT |
#14 |
![]() Join Date: May 2004
Trader Rating: (40)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 40 reviews
Just need wire, switches, and relays:
- Accessories - Ign - Fuel Pump - Start - Elec Fan override - taillights - kill switch - universal fuse box You literally just connect to stuff you need to power/not power. I used the12volt forums to get some basic relay wiring information. After a year of running it like that & making more modifications based on what I wanted/added, I got one of the painless wiring kits - super easy.
bew bews! |
#15 | ||
#17 |
I recently did this.
Some photos on my IG - @skhotso https://www.instagram.com/p/Bl6hFB-j...d=96vrlxki6yyg The PO hacked stuff together with a lot of relay plugs open and no clue what's even connected anymore. I ended up just ripping everything out along with the relay box, fuse boxes, and whatever harnesses weren't necessary. Ended up being about 27 lbs of wires and tape. This greatly reduced the headache I had Everytime I looked under the hood. Just need to work on the fender rubbing now.... |
#18 |
They look pretty expensive, id rather make my own. I have someone drawing me up a schematic for my specific needs so it should be simple enough to do. If all else fails ill consider the arc. Thanks to everyone for the tips!
#19 |
Aw. My post earlier didn't make it up.
I did it because the PO hacked the whole chassis harness up. You really need to get familiar with the chassis harness and figure out what you need and don't need. You'll need your time control unit if you want to retain thinks like timed defroster, intermittent wipers and such. Check some pics on my IG - https://www.instagram.com/p/Bl6hFB-j...d=96vrlxki6yyg |
#20 | |
#21 |
Yeah I figured. In that case you really just want to get all the lighting wires identified, flasher relay for signals if you needed it, the 4 or 5 fuel pump and fuel gauge wires. You probably want to directly wire up a momentary switch for starter and separate switch for ignition on.
#22 | |
#23 | |
