![]() This is my first engine build and I'm in a little over my head but I'm learning as i go. I am having trouble picking the right HG. I am building a KA-T and have super tech pistons 10.5:1 with eagle rods, arp studs, fully built head and got the head decked. I don't know exactly how much they decked the head but it was not extreme. I am planning on shooting for around 400 hp and have been looking at metal head gaskets. Help would be appreciated.
![]() Join Date: Oct 2007
Cosworth is always a good choice
On my friend s14 ka-t with 390whp 410trq We run a stock head gasket with o-rings in the block ... allmost two year of dayli driving and drifting nights !!! Still going strong
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
Just go thicker / safer and you will never have to look back
+1 for Cosworth HG but the block and head should be confirmed flat by the machine shop.
There are plenty of people running the felpro for under 400hp goals. With that said, a turbo application at 10.5 is going to be a harsher environment in the chamber, people usually drop compression for turbo. The thicker HG will knock off a bit of compression which might be desired. I've only heard of people running 10.5 pistons on e85 engines, is that what you'll be running? |
Here's a good article on lapping engines written by Eric Hsu, a man who's worked at Cosworth for many years:
http://www.motoiq.com/MagazineArticl...eparation.aspx |
#14 |
![]() Join Date: Sep 2008
Im personally on a ka24e i built. Arais pistons, eagle rods, lots of machine work including having my cyls bored just slightly beyond stock. Making it somewhere in the 2.4/.5 basically 2.5 and i've been running the stock head gasket for years. I peak around 16 psi before fuel cut. Never had to change it since i built the engine and never had any steam issues besides the usual warm up in cold weather type steam.
Car has been reliable and running strong. Stock head gaskets usually are very durable. But then again with 400+ hp youll probably want an upgraded multi layer steel head gasket. Also, are you planning on running E85 with that compression ratio ? If you plan on unleaded fuel ( pump gas ) your going to blow through just about any upgraded head gasket you buy.
1994 toyota supra...... n-a D= 1992 nissan 240sx KA24E-T fully Built =D |
head gasket, ka-t |
