02-23-2012, 03:43 AM | #181 |
Are you shitting me?
Lets all not cage any race car because you dont see them upside down. S14 drift crash - YouTube
Nagasaki Motors Friends help you move. Real friends help you move bodies. |
02-23-2012, 04:51 AM | #183 | |
02-24-2012, 07:12 AM | #184 |
Trader Rating: (22)
Feedback Score: 22 reviews
Honestly though its fairly unlikely that you'll actually roll your car but don't forget all the other benefits of a cage (chassis stiffness, side protection, proper harness mounting, they look awesome, etc..)
It's obvious that most s-chassis are not used for high speed road racing but they're designed to crush up, so its your call. I can't wait to get on building mine! There has got to be more cages on this forum.
02-25-2012, 12:53 AM | #186 |
I like.. ^^
http://www.tarmac-spl.blogspot.com/ |
12-14-2013, 03:04 PM | #193 |
bumping this old ass thread up.
I will be getting the S&W 8pt cage and installing that with a few modifications. ill be looking at a full interior with carpet rear seats, everything. |
12-15-2013, 08:01 AM | #195 |
Some of this is quite good while other parts are terrible... Id like to see it finished.
http://buildmakecreate.tumblr.com/ |
12-17-2013, 05:12 PM | #196 |
Trader Rating: (18)
Feedback Score: 18 reviews
Okay, so this is the cage that Touge Factory is doing for my Modified Class Global Time Attack Car. It's still not 100% complete yet, but you can get a sense as to the quality of the work and what the overall structure of the cage is.
https://instagram.com/eck_matthew/ |
12-19-2013, 10:53 AM | #197 |
Didn't really specify if you could post bolt ins or not but here's my cusco safety 21 and NRG harness bar, eventually will have a nice weld in with door bars but this cage was 300 bucks and it stiffens the chassis especially after I welded in floor plates to bolt it too, so this will do for now
12-19-2013, 01:53 PM | #198 | |
Are all of you guys running Nascar style door bars for ease of access? An X is stiffer and lighter...
12-19-2013, 05:32 PM | #200 | |
12-19-2013, 05:42 PM | #201 |
I see mostly caged S13's. Any chance does anyone have photos of the rear setup to an S14? Where exactly do you box to weld the cage too or do you weld a pipe onto a plate and weld the cage to the pipe like the s14 in before pages?
S14 KA NA two cylinders, 75whp limper |
12-19-2013, 06:53 PM | #202 | |
I dont have many its still under construction in AZ.. I still am having him add some horizontal bars in the front tube front and thru the firewall bars..and a couple rear end bars.. keep in mind it also will have a small trunk cage . [IMG][/IMG] [IMG][/IMG] [IMG][/IMG]
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap. |
12-19-2013, 07:13 PM | #203 | |
Edit: nvm, I remember who you are. Its being done by Intense power with the viper engine. Long time ago I was offered a Viper engine setup complete, trans, ecu, wiring, etc for $6k but only had 3k. Regret not making it work out. Hope to see this in person when its finished. When I get some time, Ill stop by there and see how its going. Maybe even send you some more pics.
12-19-2013, 09:07 PM | #204 | |
that Z33 is rocking an SR with a P11 head I believe. crazy shit |
12-19-2013, 09:58 PM | #205 | |
12-19-2013, 11:39 PM | #206 | |
Interesting. I agree, and highly doubt a Nascar bar is any safer than a proper X, especially if it's just as close to the driver.
12-20-2013, 12:10 AM | #207 | |
Those really are not true NASCAR door bars either. Those extend into hollowed out doors to help keep it off the driver in the event of a side impact. It would be interesting to see the X style compared to the faux NASCAR bars in a side impact.
Need to adjust your idle? http://zilvia.net/f/s-chassis/395413...-pictures.html |
12-20-2013, 05:54 PM | #208 | |
A: B: Pulled from NASA FORUMS: No photos, but here is an excerpt of Greg Amy's description: "But post-race we all got a good look at the car. As described the door was completely destroyed, hammered well into the car. The passenger-side rollcage/intrusion protection had completely failed. Richie had the venerable "X" bar on the passenger side, one diagonal tube, with two other tubes welded to that to make an "X". That structure failed. Your first thought is probably that the welds failed, but you would be wrong: all welds seemed to hold. The primarily structural failure was on the first main diagonal bar, which simple tore apart at its center in tension. Then, the two triangular "halves" of the X-bar system hinged inwards where they were welded to the main the front hoops, tearing the two tubes partially off.
12-20-2013, 08:45 PM | #209 |
I would definitely agree about the two bent bars, and I would make gussets even larger than the ones in that pic.
12-20-2013, 09:00 PM | #210 | |
Sent from my SGH-T989 using Tapatalk 2 |
