Old 03-25-2013, 02:10 AM   #1
tsahlin489
tsahlin489's Avatar
tsahlin489 is an unknown quantity at this point
Auto>Manual Conversion and Motor Swap?
After approximately an hour of searching and reading posts, I have been unable to locate a post direct enough to answer my question.
As the title suggests, I am in possession of an Automatic 91 Coupe that will soon undergo a Manual conversion as well as an RB25 swap. My question being, what is this best way to go about the two? Manual first? Simultaneously? My original (and current plan) would be to go about the manual conversion as stated in the many threads found on here, however sub out the trans for the RB and the drivetrain I would run accordingly. However, seeing as I plan to run Wiring Specialties engine harness, would I need to do any electrical work whatsoever?
I'm sure it's quite apparent how confused I am, any light that could be shed on the subject would be greatly appreciated.
tsahlin489 is offline   Reply With Quote
Old 03-25-2013, 11:17 AM   #2
Con-city_s13
Con-city_s13's Avatar
Con-city_s13 is an unknown quantity at this point
Personally, I wouldn't bother swapping in the manual transmission on a KA before doing an entire engine/trans swap. Wiring Specialties sells a harness designed to adapt to an automatic chassis harness.
Con-city_s13 is offline   Reply With Quote
Old 03-25-2013, 08:01 PM   #3
e5s4y
e5s4y is an unknown quantity at this point
pull the ka and tranny, cut the hole for the clutch master, drop in the rb, splice the 2 wires together thats needed, drive like a man
BustedS13: anything you can hide on your person is free. junkyard law.
e5s4y is offline   Reply With Quote
Old 06-20-2013, 03:07 PM   #4
stedward
stedward is an unknown quantity at this point
I live in Southern Cali. Can anyone tell me were the best reputable shop is to get a 5 speed swap?
stedward is offline   Reply With Quote
Old 06-20-2013, 06:22 PM   #5
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
This is going to sound harsh but:
1: Don't bump a tech thread asking for regional info, that is what the regional section is there for, there is even a thread about this.
2: Look up the tools and the procedure and do it yourself and save a lot of money.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
manual conversion, motor swap, rb25, s13
