Old 07-16-2021, 09:17 AM   #1
spools420a
spools420a's Avatar
spools420a is a well-known jackass
bucking when going into boost
Hey all I finished up a 2871r/550cc/z32 maf/enthalpy ecu/
The car runs great till It goes into boost then it just cuts off and bucks real hard.First thought was boost leak,tested and holds pressure great.It was running great before the 2871r swap so it must be somthing in the area.
the first day my afr at idle were normalish around 14ish yet today they are extremely lean at idle at 17 afr.
My prime suspect is MAF wiring at this point.Zilvia is allowing attachments so ill have to send links and explain
testing the maf with car running and backprobing the (B) 0.5v signal i get 1.40v and more as rpm climbs,(c) is on chassis ground and tested good for continuity, (D) is ecu ground and also has good continuity.(e) has battery voltage tested good.
heres the wiring diagram I followed.(if link doesnt work its the JWT sr20det to z32 maf wiring diagram.
https://imgv2-2-f.scribdassets.com/i...5C%5C%5Cu003d1
The only difference is (b) is chassis ground,I will combine (B) and (C) today to ECU ground and see if that does it.along with voltage drop testing the ground wire
I'm sure someone here has had this issue so please let me know your opinions.
again car ran fine before installing 2871r/z32 maf/550cc/enthalpy.
spools420a is offline   Reply With Quote
Old 07-16-2021, 11:42 AM   #2
spools420a
spools420a's Avatar
Went and changed some wires around on the maf and didnt fix the issue but I did find some clues...
right when it bogged out the afr read 10:0.1 and there is almost no BOV sounds.I did do a boost leak test on the intake side and it holds the 15 psi I will be running BUT I didnt check the exhaust side.Because Im not hearing the BOV while passing the boost leak test Im thinking maybe a massive leak around the manifold before the turbo?
I do have a smoke tester so That will be my nest step but wont be till tomarrow,any other thoughts?
UPDATE!
went to check spark plugs and gap at 0.28" and found two of the coils have split cracks in them.I ordered 1995 maxima coil packs as I read they are a cheaper alternative but wont arrive for 4 days
Does the cracks sound like the cause?
Old 07-16-2021, 06:32 PM   #3
Silv1401
Silv1401's Avatar
Silv1401 is an unknown quantity at this point
What engine and chassis are we working on?
And is your car bucking or is it bogging when boost hits? Big difference here, and tells you where to look. If its bucking like violently and abruptly engine braking, then your issue is fuel, as in abruptly not getting enough of it. Either injectors are too small, your tuning map is crap, or your pump is not pushing enough volume. Bucking is typically attributed to fuel cut, if you've ever experienced that before. Side note, water in the intake can cause this too.. ask me how I know.
If you're bogging, that could be any number of things from faulty MAF, boost leaks, weak spark, *broken coils*, fouled plugs, bad tune, etc. This is usually attributed to running way overly rich. Typically if your MAF isn't running right or isn't giving a signal, then your car will fire up and immediately die, but if you keep pumping the gas you can keep the car alive by bouncing the revs.
Sent from my SM-N986U1 using Tapatalk
Silv1401 is offline   Reply With Quote
Old 07-16-2021, 09:58 PM   #4
Kingtal0n
Kingtal0n's Avatar
you need to pay attention to the wideband and watch the behavior. These engines are simple they need spark fuel air and it goes ecu -> maf -> injectors so pretty basic if there is an a/f problem its one of those. And obv it needs spark so yeah you need to make sure it can spark. And air is just compression test.
Old 07-17-2021, 08:46 AM   #5
spools420a
spools420a's Avatar
sr20det redtop s13.
car idles and revs fine and only does this when getting to around 4-5k rpm
it feels like hitting a rev limit and just cuts out,doesnt feel like bogging or spark related really it feels like the ecu is making it cut out.Ill pull some codes in a bit/check the exhaust side for leaks and test fuel pressure
since it was running just fine before the turbo install/550cc/enthalpy/z32 Im gonna focus on these areasThank you for the reply.
Old 07-17-2021, 08:50 AM   #6
spools420a
spools420a's Avatar
yes agreed,ive only ran the car twice since this has been going on and last time it was lean at idle and pig rich when it cut out seeing 10:0.1 afr.The way the turbo responds and sounds feels like a boost leak but smoke tested the entire system with throttle open and it holds boost.
However I did reuse the exhaust manifold gasket and wondering if I have a severe leak at the manifold which would explain the lean idle/slow resonse and possably the o2 sensor is making it jerk under boost?So today im smoke testing that exhaust side as well.
Thanks for the input and I will try and record the next time.
Old 07-18-2021, 11:12 AM   #7
spools420a
spools420a's Avatar
UPDATE:
I tested the fuel pressure and here are the results...
With no vaccume line removed it at 43 PSI Fuel Pressure
Revving the engine the psi jumps to 50 psi
removing the vacuum line we see 53-56 psi
adding 10 psi of air pressure we are at 66 psi of fuel.
Pretty sure i'm on the right track to the fix now.My first thought was replae the FPR but giving it some thought Im wondering if a partially clogged fuel filter may be the issue since its on the return line side this would increase fuel pressure and reduce fuel volume correct?
anyways i ordered a z32 fuel filter and a walbro 255lph pump just because the old pump is 15 years old and cant even hear iit anymore when i drive like i used to hear it.
if this doesnt fix issue i will replace the fpr though it didnt seem like the diaphram was torn or anything.also ill look for slight kinks in the lines.
Old 07-18-2021, 07:46 PM   #8
Kingtal0n
Kingtal0n's Avatar
1. O2 is not used during boost. I recommend you disconnect O2 sensor until you fix the issues. It is useless for diagnostics.
2. Wideband telling you 10:1 is super rich. It means you have a boost leak or a maf related issue. Wideband needs to read between 11 and 12 (11.2 to 11.5 is ideal) for pump fuel 93 octane gasoline to run the engine properly at WOT.
3. Smoke test is not a boost leak test. You need to fill the compressor -> engine with 20psi of 'boost' pressure using an air compressor.
make sure to disconnect the crankcase vent tube before doing this. DO NOT PRESSURIZE the crankcase. Recommend pulling out dipstick just in case.
My bet is you have a giant boost leak that does not show up until the plumbing hits 5psi+ of pressure. Or you have a spark blowout issue.
Once you test with actual pressure in the plumbing to 20~ psi and rule out boost leaks, you verify the coils are good, spark plugs are gapped properly 0.032" to 0.028" is fine. DO not go lower than .027" or higher than .035". Make sure you are using the correct plugs NGK copper BKR7ES iirc.
From there it is simple maf -> Ecu -> injectors relationship. The maf placement is important, no closer than 5 to 7" to the turbo. Use a large tube for 300zx sensor. avoid reducers that are not smooth. Look at GReddy Z32 maf tube for sr20det for example. The maf should have a few inches of straight tube on both sides.
The other issue is blow-off valves screw with maf sensors, depending on the type of blow off it may be an issue. Push style BOV are designed to leak near idle from variety of manufacturers and this will cause major issues if you've removed the recirculation tubing.
This is how to properly run a blow off valve on an MAF sr20det.
Notice
1. the blow off is as close as possible to the compressor (turbo).
2. The blow off recirculates AFTER the maf, BEFORE the compressor Inlet
3. The blow off recirc is far away from the maf sensor to avoid disturbing the maf sensor
This is a 450rwhp sr20det that I helped this customer to run properly after tuning it and explaining about the maf situation.
Anyway, she's finished and you were spot on. She runs like a dream. No more stalling or hesitation. All the right wooshy noises. She's like a proper commuter now. Thank you for the guidance, I couldn't have done it on my own.
Old 07-19-2021, 05:11 AM   #9
burnsauto
burnsauto's Avatar
well it depends on the kind of smoke test. Some use pressure+smoke, while some just use smoke alone.
But I agree, it does sound like a boost leak. ...at least from sitting in front of my keyboard.
Double/triple check every thing related to holding pressure. Check for tears/holes in couplers, check to make sure you are using the correct size coupler (not one that's close enough), and check any smaller connections (If the BOV is leaking under pressure - if adjustable, try tightening the pressure on the spring to the point where it doesn't open, also the gasket for the BOV if one is used), and any of the hoses going to or from the intake manifold.
Old 07-19-2021, 07:12 AM   #10
silviaks2nr
silviaks2nr's Avatar
Definitely sounds like a boost leak to me too. When you wire your new fuel pump in be sure to use full copper 12 gauge wire with a 40 amp relay. Only use the factory fuel pump +12v as a trigger for the relay.
'98 240sx 5spd
kouki 2jz t56 swap build
Old 07-19-2021, 02:04 PM   #11
spools420a
spools420a's Avatar
Thanks for all the help,YES it even feels like a boost leak.Tested by pressuring with air/smoke at 15 psi (my max boost ill be seeing) with open throttle and it hold the pressure.
Z32 MAF wiring is
A - Nothng
B - signal
C - spliced into D
D - goes to ECU negitive
E - battery power
F - Nothing
C was originally had it own ground on the chassis ground but tried wiring it into D to see if it helped.nope
B gets around 1.5v at idle and as I rev it up it smoothly goes up in voltage,seeing a max voltage of around 3.5v at around 5-6k rpm
D was tested via voltage drop test and good ground.
E - is seeing battery power
I couldnt find what the signal voltage should read at the 5-6k rpm if anyone can confirm if the signal voltage at this rpm is good please let me know.
The fuel pressure is not right though
FSM says
36psi with vacuum line connected
43psi with vaccum line diconnected
I checked the fuel pressure.
with vacuum like hooked up to the fpr it was seeing 43 psi fuel
just revving up the motor the fuel pressure jumpped to 50 psi
vaccume line removed we see around 52-56 psi of fuel
at 10 psi added to the fpr we were at 66 psi of fuel,being a 1:1 fpr i should see 53 psi and its not even consistant as it reads slightly different each time i add pressure
we def have a fuel pressure issue,It may or may not be the issue causing the issue but its somthing that needs solving.
Again thanks a bunch for all the help guys!
Old 07-19-2021, 02:09 PM   #12
spools420a
spools420a's Avatar
Notice
Thank you GREAT info!I didnt know how picky the mAF was?!?
This has me thinking as I have a very small air filter because the one I had didnt fit after installing the MAF.I'll try removing it just to see if it makes a change but wont get to that till after the new walbro pump gets installed.,Also im using the original rubber piping past the maf and it does have some nasty S bend.Also no my bov isnt recirculated,I will try removing the BOV and see if it helps and if it does I will buy a recirc one. Ill try everything you said thanks again!
PS doing the smoke test the system was pressurized with air as well at 15 psi which is a few more psi then im running.It wasnt just smoke alone.
Spark plugs are BKR7E-11 not sure if the 11 makes a difference so I ordered NGK BKR7E.
Old 07-19-2021, 05:10 PM   #13
burnsauto
burnsauto's Avatar
it sounds like you're on the right track looking into the fuel pump and maf. was the maf new or used? can you confirm it worked on a vehicle before? how did the car run before you upgraded the turbo and the supporting mods? are you 100 percent sure that the tune from RSE is accurate? Were the injectors new or used?
it's a shame you couldn't datalog any of this..
Old 07-19-2021, 09:04 PM   #14
Kingtal0n
Kingtal0n's Avatar
The reason you want copper plugs is because they are cheap.
The BKR7ES should be a $2/each plug
gap them down for getting your engine on the right track.
Always use new plugs when diagnosing issues so you can inspect the plugs to determine what sort of issues you are facing (oil/fuel/wet/dry/whatever)
Keep a second and third set of cheap plugs set aside brand new plugs for replacing when you fix some issues, to get a new read on the situation.
Maf voltage looks about correct. 4.5V is approx 450rwhp so 500hp or 520bhp or so at full 4.5 to 5volts which you are probably very far from so 3 to 3.5v is fine
Fuel pressure regulator is adjustable? Set to desired pressure around 43-44psi while engine is off (no line connected = engine off).
If regulator is OEM and the pressure is high,
A. replace fuel filter (use 300zx filter)
B. possible clog in return line
C. possible bad regulator (Never seen one though)
D. possible overpowering the OEM rail (are you using a walbro 450 or some huge pump?)
E. possible bad fuel pressure gauge
In any case, 50psi of pressure is not that much extra pressure over 44psi. It should not make a big difference (5% fuel adjustments?) But it IS a diagnostic concern and should be fixed.
So again, it goes
Maf -> ecu -> injectors
Thus, if there are NO boost leaks, and the maf sensor is CORRECT, and FUNCTIONAL, and placement is PROPER,
The only thing left is tuning wise (injector size & delay setting mostly, maf selection), & wiring related. The ECU must control the injectors based on what it see from the maf sensor. For ROM TUNES I always use a SAFC to dial in the exact a/f ratios as needed because ROM tunes vary from car to car. This is due to differences in the various AGED components i.e. the maf sensor on one car will be 3.2v the other will be 3.4v for example, it needs dialing in using an SAFC to achieve proper a/f ratios. Another example, 550/740/etc...cc injectors vary greatly in lag time (latency delay) and system voltages (one car is 14.4v the next is 13.8v etc) thus the injectors are ALWAYS a variable.
Old 07-21-2021, 05:42 PM   #15
mechanicalmoron
mechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nice
UPDATE:
Why is your fuel filter on the return side? Your injectors are filtering the fuel supply to your fuel filter.
Will it do it without a load?
You never smoke tested it, or what? Kind of sounds like a crankcase leak - large, but restricted by how long and convoluted it is. You could have blown out a seal, plug, delete plate, etc, if your PCV system malfunctioned or wasen't set up right and boosted the crankcase.
mechanicalmoron is offline   Reply With Quote
Old 07-22-2021, 01:34 PM   #16
z31andrew
z31andrew's Avatar
z31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of light
My SR car did something very similar for quite a while, sometimes it would boost and sometimes when I accelerated too hard or too a corner too quickly it would buck hard about 4-5000 RPM. I took it to a good friend's shop, tested out 6 different good MAFs thinking that was my problem and it turned out the tune chip in my ECU was vibrating out and not staying fully connected. This is a long shot for you it seems, but I say just double check and make sure everything inside the ECU cover is solid and secure.
z31andrew is offline   Reply With Quote
Old 07-23-2021, 01:13 PM   #17
Mikester
Mikester's Avatar
Is this solved?
Sounds like a spark issue to me.
Old 08-03-2021, 10:33 AM   #18
spools420a
spools420a's Avatar
Update:
I tightened the bar to the wastegate to keep gate tension higher/changed cracked coil packs/changed out the 15yo walbro pump/replaced fuel lines and the car no longer has the bucking issue that seemed like a rev limit under boost and I can now floor the engine to redline BUT as stated earlier I have a fuel pressure issue and while under boost I was getting around 10.5 afr and would begin to slightly break up.
So the good news in all this is we only have to fix this riich condition and the car should be good to go.Fuel pressure reading are all over the place,I used two seperate guages to be sure it wasnt instrument malfunction.
Today when testing fuel pressure I was seeing 50+ psi at idle then I tried another fuel guage and that one read 43psi at idle,so I went back to the original guage to confirm and now that guage reads 43 psi at idle.so the fuel pressure is just all over the place.
Thenwhen snapping the throttle real fast the fuel pressure would jump to 53 psi.
Since I replaced the fuel pump and lines its looking like a fuel pressure regulator issue is my guess.
Now I do have a $25 dollar ebay 1:1 ratio adjustable fuel pressure regulator but I dont know how I feel about using low quality parts for fueling system,with this being said I also dont beleive my new fuel pump is a real walbro,it has all the metal stampings of walbro but its just too light compared to the old one so I think Im going to buy one directlly from walbro themselves.
Please let me know your thoughts on the fuel pressure issue because Ive never seen a fpr on sr20det fail before but really what else could it be?
Old 08-03-2021, 03:38 PM   #19
burnsauto
burnsauto's Avatar
...$25 fpr
A walbro, without any kind of voltage booster, will put out 43.5 psi @ 13.5 volts. So at least at idle, it's doing what it should.
If I were a betting man, it's that piece of junk FRP. Get one from a reputable company that's known for fueling (Aeromotive, AEM, Deatchworks, etc)
Old 08-04-2021, 08:07 AM   #20
tuzzio
tuzzio's Avatar
It sounds like you're learning and important lesson about cheaping out on components that are detrimental to the health, and well being of your car, as well as purchasing from reputable vendors.
Old 08-04-2021, 08:52 AM   #21
spools420a
spools420a's Avatar
Originally Posted by burnsauto View Post
...$25 fpr
Actually the $25 fpr isnt installed and was never installed, Its the oem one has been the one causing the issues,I intended to use the cheap tomei clone afpr to make sure the fpr is the cause of the fueling issues but now I dont think I will, infact i have a wtb add as we speak looking for a afpr so if anyone has one let me know.
Old 08-04-2021, 09:03 AM   #22
spools420a
spools420a's Avatar
...$25 fpr
Yes it was 43psi at idle the first test but testing it again minutes later it was randomly at 50+psi at idle,just weird random fluxuations in fuel pressure,Mind you this was using two fuel pressure guages to be sure the guages were not the issue themselves.
(btw fuel pump has relay wired in at the pump and voltage drop specs are ok so its not a voltage issue incase someone suspected this)
While I wait for a better afpr I plan on blowing some air through the fuel lines and seeing if theres any blockages in the hard lines,the rubber fuel lines have all been replaced.
Were on the right track and pretty positive the oem fpr has gone mad.
thanks for your help and especially the picard facepalm about the cheap fpr to tell me its not a smart move,though I intended using it just for testing purposes I dont think ill risk it.
Old 08-04-2021, 09:07 AM   #23
spools420a
spools420a's Avatar
any recomendations for afpr under $150?
I found the tomei type s was around $100 and 1:1 ratio should I pull the trigger on one of these?anyone running one?let me know what would be good for the price range.
Old 08-04-2021, 09:16 AM   #24
spools420a
spools420a's Avatar
Yes! thats a understatment when shopping for walbro fuel pumps,Infact they have a page on their website dedicated on how to spot the fakes.I paid a little extra and went through walbro to be sure I got a real one after weighing the suspect one and comparing it too the real walbro I had it was indeed a fake.
the real one was around 350 grams
the suspect one was about 300 grams,enough to where you can feel a huge difference when holding it,looking through the sock hole it has plastic internals what junk.
Old 08-04-2021, 03:26 PM   #25
burnsauto
burnsauto's Avatar
A Tomei would be fine, just make sure it's legit (just remember that Tomei Japan is separate from Tomei USA after Tomei USA was having a lot of quality control issues). Pretty much every major manufacturer is dealing with fakes, they all have the same type of info that Walbro had about spotting real ones and fake ones.
Glad you looked into the fuel pump That would of been bad news, lol.
Old 08-04-2021, 09:06 PM   #26
spools420a
spools420a's Avatar
oops my mistake my filter is on feed side not return. but good eye as that could easily been what the fueling issue was if those lines were switched i'm sure
Old 08-10-2021, 09:44 AM   #27
Kingtal0n
Kingtal0n's Avatar
I like aeromotive stealth pump,
-they last around 10,000 run hours
-quiet and cheap like walbro
-supports 750 horsepower on gasoline through a 5/16" fuel line
I've had one in my car since 2017, 40,000 miles on it at 500rwhp using 5/16" fuel hard line
also recommend:
On ebay you can buy a 'stock' style replacement pump (similar to walbro) 195LPH~ for $30~ shipped
This is the pump you can keep in your car as a backup in case your main pump fails, it will get you home for $30
Old 08-19-2021, 11:23 AM   #28
spools420a
spools420a's Avatar
I dont want to leave behind a dead ed thread so heres the update
the isssue is fixed!!! thanks again for your help
I cant say for sure which fixed the issue so let me go along the last things i did
I gapped the plugs from .28" to .23" ( I plan on upping the gap till i budget some breakup then gapping down from their to get the best gap possable)
I took out the fuel injectors and noticed one had 2x tears on the bottom O-ring,The tears were in a spot the fuel wasnt leaking out but could have been seeping boost past the the lower o ring.
installed a tomei AFPR and bought a good marshal oil filled guage and set the fuel pressure to this.This was important for me because I had 3 different fuel pressure guages and all 3 read different numbers so I invested in a more expensive guage and went off that,also tested the tomei fpr by adding psi to make sure fuel pressure was rising 1:1 ratio
one of these or all of these seemed to fix the issue as it no longer breaks up under boost.
from here I do see another issue and thats Im reading around a 10.8 afr at higher rpm under boost.
would lowering the fuel pressure a few psi maybe help combat this?right now fuel pressure is 36psi with vaccum and 43psi without vacuum.I really dont want to go safc if i dont have too.Thoughts on lowering the FP to lean out the mix a tad,would lowering the FP even be enough to get me in the 11 afr?
Old 11-19-2022, 09:53 AM   #29
spools420a
spools420a's Avatar
update:
the real fix was swapping out the sr coils for audi r8 coils.this does involve a new coil harness and icm delete,both can be bought from a guy in new zeland on ebay if you dont want to make your own.
this changed everything for the better,i can run 17 psi with 0.40" gap and no issues,this improved power/this improved throttle response extremely noticeable much more snappy and responsive/idle is clean not choppy anymore. Literally all pros no cons and i didnt expect it to be this good.
that being said this is the fix for anyone with this issue,to save money you can use 06 07 vw jetta 2.5l coils ith the r8 harness which can be found at most junkyards where the r8 cant.
this thread can close now
Old 11-19-2022, 11:57 AM   #30
inopsey
how does the r8 coils sit on the valve cover? any pics? how much was this upgrade?
also a link to the harness, ignitor delete used would be useful
