Old 04-26-2016, 09:58 PM   #1
Codyluukk
Codyluukk is an unknown quantity at this point
Turbo ka
Hi I have a completely stock 89 240sx 90k miles and I was just wondering how much boost I could have safely and what type of turbo that would be good with it as well
Codyluukk is offline   Reply With Quote
Old 04-26-2016, 10:05 PM   #2
collegekid
collegekid's Avatar
collegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to all
Cody no one has ever turbo'd a Ka. I'm proud of you for diving into uncharted territories.
collegekid is offline   Reply With Quote
Old 04-26-2016, 10:12 PM   #3
yzrider450f
yzrider450f's Avatar
yzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of light
You can't just say "x" psi. That number is arbitrary without turbo specs.
yzrider450f is offline   Reply With Quote
Old 04-27-2016, 06:55 AM   #4
turbo2nr
turbo2nr's Avatar
turbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enough
Send a message via AIM to turbo2nr
14PSI stock motor, more with a smaller frame turbo t2ish less with a bigger turbo t3/t4.
fuel management is the key here.
s14 kouki ka-t
turbo2nr is offline   Reply With Quote
Old 04-27-2016, 07:00 AM   #5
Jorgs_7
Jorgs_7's Avatar
Jorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really nice
google is a thing, no lie
Jorgs_7 is offline   Reply With Quote
Old 04-27-2016, 07:46 AM   #6
silviaks2nr
silviaks2nr's Avatar
For 14psi You need head gasket and head studs at the very least. If you're going to do that you may as well do pistons and rods and main studs too. Honestly I wouldn't run more than 5 or 7 psi on a t28 stock motor
'98 240sx 5spd
kouki 2jz t56 swap build
Old 04-27-2016, 07:59 AM   #7
SoundEfx
SoundEfx's Avatar
SoundEfx is an unknown quantity at this point
Join the site KA-T.org
All of your KA-T questions should be found there.
SoundEfx is offline   Reply With Quote
Old 04-27-2016, 08:15 AM   #8
Gingersmurf
Gingersmurf is an unknown quantity at this point
Just goto ka-t.org
everything you'd ever want to know is there
http://www.ka-t.org/forums/index.php
KAs are like Frank's RedHot, Nissan put that shit in everything
Gingersmurf is offline   Reply With Quote
240 240sx, ka24e, s13 240, turbo
