02-27-2008, 04:59 AM | #1 |
it depends what your goals are, low wear or high cornering grip. since he's running r compound race tires, i'd say the latter.
02-27-2008, 11:33 AM | #2 |
I get great grip in a straightline right now, and its fantastic in a corner, what I need to work on is wieght transfer. I think some sways and stiffen her up a tad more and shell be even faster. And the car absolutley loves a ton of camber up front, turn in is great....I jsut need some new tires , mine are corded
Signature Exceeds 400x200 Maximum Limits set by the User Agreement!! |
02-27-2008, 05:56 PM | #4 |
well 275 up front is no issue what so ever on an s14, easy peasy, however the rear well.. if he fit 305s in the rear and had stock fenders... i guess to fit 335s you would need say... 30mm fenders? lol get it haha? 335-305 = 30mm lol
02-27-2008, 06:10 PM | #5 |
Except half that width is on the inside so you'd be wrong. It would be 15mm fenders.
02-27-2008, 06:17 PM | #7 |
LOL! That's true, got me there haha... i just came home. well technically if the inside was the same (lower offset wheel) then the outside could be made 30mm wider :P
02-27-2008, 06:29 PM | #8 |
Hey, so I plan on doing a little bit of everything, I have
Fronts 17x9.5 +15 30mm Wide front fenders Tein Tie Rod spacers Can I fit a 255/40/17 RT615 Azenis at full lock without frame rail rubbing? I'm already tubbed and hammered, the frame rail/tension rod is the only questionable parts. The tein tie rod spacers add quite a bit of angle. I'll be using a 275/40/17 Azenis on the rear as well.
-Jackson.Vaughn.Photography- |
02-27-2008, 07:10 PM | #10 |
Guys these are my specs on a stock body with just pulls no body work at all ever performed
Front 18 by 10 + 18 I have ran 265/35/18 and 275/35/18 . Had to hammer the fronts tubs in so they wouldnt rub against the frame, plus i had to pull the front fenders about 10mm. I did one good and the other i messed up cause i was in a hurry. i can go lock to lock even with tein tie rod extenders . Here you can see the one i messed up Rears 18 by 11 + 18 Pulled about 30 + mm in total on stock quarters with no paint work. I ran 285's for a while, the put 295s on and they rubbed so pulled some more then i was able to fit 315 azenis. Here you can see the 295s rubbing before i pulled some more After i pulled they didnt rub any more Heres 315's on the stock body would rub from time to time which is ultimatly why i went wide body. plus they stuck out so much it was looking border line rediculous 295 vs 315 12.4 inch sectional width Front coilover clearance on tein coils 18by 10 +18 with 265 tire . Rear coilover clearance is about an inch. no pic unfortunatly of the rear. Heres some other fitmets Rear i forged 20 by 11 +20 305/25/20 Front te37 19 by 10.5 + 12 285/30/19 I got tons more of pics of all kinds of crazy wheels and tires but i think that gives everyone a good idea of what can and cant be fit. Enjoy
ANTI-STRETCH NAZI Vortech Supercharged Vh45de S14 V8nissans.com |
02-27-2008, 08:41 PM | #11 | |
Thanks for the help, especially you gsracer. Those pics give me a pretty good idea. Few questions though: Do you have any rubbing problems with the 285 tires in front? Also, I'm sure tires that wide in front have to increase the scrub radius, does that produce a noticeable increase in steering kickback or effort or any other negative handling effects? Thanks. -Layne |
02-28-2008, 01:05 AM | #12 | |
looks like 17x9.5 +18 with 275's should be okay Which tein coilovers are these?
02-27-2008, 08:48 PM | #14 |
Yea the 285s would have rubbed quite a bit especially in the 19 inch size, forgot to mention that. Not practical at all. 265 in an azenis type tire is all the size an s chassis needs. Steering is definitly heavy and required a cooler to avoid boiling over.
02-27-2008, 10:09 PM | #15 |
Noted, don't go past 265 front. I kinda figured the 285s wouldn't work. By the pictures it just didn't look right.
The only reason I wanna go with such wide tires in the first place is to put the power down effectively. As you might be able to tell from my screen name I'm doing an LS1 swap. At first it'll be pretty much stock, with just exhaust and intake, then I'll go with heads, cams and intake manifold, then eventually turbocharged, so obviously I'm gonna need some rubber to put down all that power and torque. I know I don't need 335s, but the bigger the better. If something's worth doing, it's worth going overboard haha. Thanks for all the help. -Layne |
02-28-2008, 05:48 AM | #16 | |
GSracer you have run some wide setups, wow! I love those pics, I hope to snag another S14 so I can LS1 it and run a wide tire setup... I'm surprised you ran such a low offset in the rear, you could have fit even more tire under those rolled/pulled fenders (like a 315) had you ran a +30 offset, right?
cardomain.com/id/LS1T56FC = my crazy ls1 v8 rx7 = sold |
02-28-2008, 09:25 AM | #17 | |
Owen, you have any pictures of your LS1FC? I don't think people would mind an FC sneaking into this thread if it helps keep it going, as long as it's maximum-fitment caliber. Thanks. -Layne |
02-28-2008, 10:26 AM | #22 |
I have some pictures of re30's on my car in those exact wheel and tire sizes. I'll post them up when I get home.
Also I can tell you with my 280/280 whp wtq v8 I can spin the 295's and 315's easily from a roll in first and even second gear on throttle only.
02-28-2008, 11:23 AM | #23 |
a 285/35 is not shorter than a 265/30.
02-28-2008, 10:36 AM | #25 |
^lol damn... and thats with a nissan v8 right? Not ls1? Yikes.. Plus its an s14 which is heavier than fc if im not mistaken... weirdness... maybe the compound sucks?
02-28-2008, 12:56 PM | #27 | |
yeah I have a shit-ton of pics of my LS1FC, here are some with the 295/30r18 rears and 285/30r18 fronts on 18x10s all around and some widebody activities I love these tires and the sizes, theyre barely 25" tall so there is plenty of room for clearance and the car can be run very low as well, so much better than when I had 285r/275f in 17" kumho MXs those were some damn tall tires. I think with a 265/35 and then a 285/30 or 295/30 you would be rockin! http://web.mac.com/owen_the_soyboy/iWeb/Site/fc3s%20ssr%20sp1.html and http://www.cardomain.com/ride/2273797
02-28-2008, 01:11 PM | #28 |
I be been thinking of getting some 18 by 12.5 +40 so I can "stretch" some 315's on there LOL then people would shut up ha ha.
02-28-2008, 03:22 PM | #30 |
carbon black volk re30s in 18x9.5+15f and 18x10.5+18r 265/295 kumho mx
looked a bit to sunk imho
