#182 | |
![]() Join Date: Mar 2010
![]() Feedback Score: 6 reviews
#184 |
Your best bet if your unsure which primer color to use is ask the paint shop what primer the company calls for to get the desired color. Most of the time you cant go wrong with the standard light gray.
#185 |
Use a primer sealer over everything so you get a uniform color to base over. Black is good for darker colors obviously as it's easier to cover. For something like a bright red or yellow you would definitely want to use a white primer sealer. For stripping bumpers I almost always use a chemical stripper, but do a test first. ALWAYS wipe bumpers with a waterborne plastic prep before priming!
#186 |
![]() Join Date: May 2011
Trader Rating: (50)
![]() Feedback Score: 50 reviews
Depending on your base coat color, is what will help determine the primer color. For example if you are doing silver base coast you will want a light gray primer. But yes, your standard light gray primer can not go wrong.
FS: DSS 1pc Steel Non ABS, 6bolt axles WTB: Boost Gauge, Hatch Roof Wing |
#188 |
![]() Join Date: Feb 2008
![]() Feedback Score: 9 reviews
At work we carry the Valspar line of paint products. We dont have any urethane based primers but have a ton of DTM 2K primers. Does it really matter the type of primer I use? According the label it can be used as a high/medium build filler and as a sealer depending on the amount of reducer I guess. If I stick to one brand of paint/primer I should be fine right?
#189 | |
#191 |
Was just about to ask this myself: I have a pretty fair sized dent mid-passenger quarter panel. Doesn't need to be perfect as it's a drift car, but i'd love to at least get it shaped back out somewhat. I have heard it can be as simple as putting a deflated basketball up there and inflating it to pop it out, but I assume there has to be a better way. Tips?
#192 |
can you get access to the inside of the quarter panel where it is dented? Usually the only dents that just "pop out" does not have a crease or body line running threw it. If it has been dented pretty bad and been pushed in awhile theres a good chance the metal has streched. I will try and gets some pics tommorow at work to help with this thread about straighting metal, i am a certified Painter and autobody tech so any questions that may not get answered i will do my best to help
#194 |
Sorry guys, i didnt get into any metal straightning yesterday, was fixing a new aftermarket hood for a charger, made by extreme dimensions, wow that thing was a basket case
#195 |
Pictures would help... Hammer and dolly usually is the best way to metal finish dents if you can get access. If its a dent in a quarter panel without access to the backside, a weld on stud gun is your best choice. It welds a small stud to the surface and you attach a small slide hammer to it.
#200 | |
Update:
to follow up (I hate it when people don't post follow ups of stuff they said they're going to do): I painted the car in the garage and sure enough it wasn't perfect job but for a first time diy garage job it wasn't a total disaster either just the typical dust and bugs in the paint, orange peel, etc but I wasn't satisfied small items like valences, fenders and sideskirts came out pretty good but for something larger like the car body I really NEED a better compressor (more cfm) and a moisture removal system to do an adequate job in the garage the worse part was that I didn't remove masking tape within 30 mins after painting as you're supposed to (found that out later) so that when I pulled the tape (a couple of days later) it pulled some paint from edges ![]() ![]() ![]() ![]() ![]() so I got annoyed and walked away from the car for a bit eventually I decided that, fuck it, I'll remove the quarter windows, wing, etc and strip/prep the car again and have it sprayed in a booth In midst of this I found out a friend runs a paint and body shop near me so I sent the car his way to get a cheap 2 stage paint job I should be getting the car back this weekend So in conclusion I think that a garage diy paint job is a very duable proposition pending you have the RIGHT tools at your disposal it also depends on your expectations I'm sure that job I did would have been fine in the eyes of many people specially since this will be a track/weekend car and the main goal was to get it all in one color I don't think I would try it again (messy and time consuming) I think that stripping and prepping the car to have sprayed in a booth is way to go |
#201 |
Sorry you were left with a bad taste in your mouth after your first experience
![]() ![]() I have a really cool small painting project (vintage motorcycle) that I took a lot of photos of and I'll post in a few days after I finish up with some tips. |
#202 |
![]() Join Date: Dec 2009
![]() Feedback Score: 21 reviews
Not sure if mentioned anywhere in the thread, but what fillers are good to use for what purposes? I'm about to start doing my own bodywork and paint, as well as some work on a few friends' cars. Would like to know which fillers to use for what. From what I keep hearing/reading, regular red Bondo isn't all that great.
Also, when actually painting how many coats of everything do I need/want to get a nice finish? -Primer -Primer Sealer -Base Coat -Clear Coat
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr Last edited by Irresistible; 04-03-2013 at 12:24 PM.. |
#203 | |
frustration if anything at knowing that my compressor at home wasn't up to the task especially knowing I could have done it at work where we have industrial air with AC units and water traps |
#204 | |
![]() Join Date: Jul 2011
as i'm about to start doing body work and painting my car as well and want to know if my 25gal, 4hp compressor will do the job or if i should borrow my buddies comp. |
#205 |
![]() Join Date: Oct 2010
my cars at the shop currently getting an engine rebuild and ive decided in the mean time I wanna prep the car buy the paint and jst pay a shop to do spray it... simple first question do you just buy fiberglass primer and spray it on top of F.G fenders hood kit? or do you put a layer of body filler on it?? what Grit should i start sanding the regular paint? thanks for your time..
#206 | |
you need to check the cfm requirements of your gun and that of your compressor ~20 cfm is typically what's required and is what most 5hp compressors can do so your 4hp could be up to the task the tank size might be an issues since your compressor would need to constantly run to supply air generating heat and moisture in the line I would want to upgrade to a 5hp dual stage compressor with a 60 gallon tank (or a couple of 30 gallon tanks in line) and a moisture trap system - copper or steel 3/4" or 1" piping with moisture traps and filters if I were to attempt painting a car again something like this: ![]() ![]() |
#207 |
5hp 60 gallon compressor is the smallest i would try to go with, hvlp gun will do ok with that, a 4 hp 30 gallo, would do spot jobs, but at an all over paint job it would work itself to hard and creat alot of moisture. Get a good water trap, cheapos dont collect all the moisture.
#209 | |
#210 | ||
two things went wrong here: 1. Your air pressure and fluid ratio was off( too high or not enough) thats why it looks textured 2. your masking was too close to the painted surface so when you pulled tape it pulled the paint up. I dont demask under the clear is somewhat cured.
-Primer -2 medium wet coats over a surface prepped with 180grit or finer -Primer Sealer- normal one coat over a surface prepped with 320grit or finer -Base Coat- 2-3 coats depending on the color -Clear Coat - 2-3 coats Quote:
