#152 |
![]() Join Date: Feb 2008
![]() Feedback Score: 9 reviews
If Im going to paint over the oem paint after sanding does it matter if I use an epoxy or urethane primer? Ive read to use both. Epoxy first and then a urethane to block. How does this sound? The paint is OE 20+ years old. Lol
#153 |
![]() Join Date: Jun 2011
Painted my engine bay with custom ceramic paint from my local auto paint store.
Cleaned the engine bay as much as my patience would allow. ![]() masked everything off using tin foil and plastic bags with a little tape here and there ![]() Laid down some basic spray can Self Etching Primer ![]() Next was the Silver base coat. Also I did not sand anything at all. But I did remove all the paint off the flat surfaces via a wire wheel and my angle grinder ![]() then I put down the Pink ![]() final coat of pink..I put 3 down ![]() and then Cleared it with an acrylic spray can clear ![]() End result ![]() |
#154 |
i like your "tubs" did you always plan to leave it like that? i think its cool to show the suspension of the car when you open your hood but dont you think your going to get a lot of shit in your engine bay either way it looks good to me just curious on your thoughts behind it.
-Mike |
#155 |
Hey mike
There actually isn't any work done to the "tubs" at all. They come like that straight from the factory. I'm not so worried about stuff getting in there. But I have contemplated making some bolt on covers just to keep major debris out. We'll see. |
#156 | |
![]() Join Date: May 2011
Trader Rating: (50)
![]() Feedback Score: 50 reviews
FS: DSS 1pc Steel Non ABS, 6bolt axles WTB: Boost Gauge, Hatch Roof Wing |
#158 |
![]() Join Date: Mar 2010
![]() Feedback Score: 6 reviews
Most of the time its a good idea to finish with a polish compound with a polishing buffer pad. What i do to not have to use polish compound is after i buff with the rubbing compound ill spray a bit of water on the surface and buff with that over the area. This uses the broken down rubbing compound in the pad for a finer finish...... Old school trick
#159 | |
Trader Rating: (50)
#161 |
Trader Rating: (50)
Actually, its not that bad. I figured on using the AutoZone Duplicolor paint in the Quart cans for about $25each. I already have my own HVLP paint gun and access to a large enough air compressor(friends house). I figure I will need approximately 2-3 quarts of base coat(color) and clear coat for my entire car + sandpaper, masking tape and other misc. items. Color is currently white but i want to do midnight blue, its my fav. Then color sand and buff. I can't wait.
#162 |
I've painted 1 car and lots of body panels, so nowhere near the experience level of the OP. I was using 400 grit wet sand on 2K high build primer and panels came out as smooth as glass prior to shooting the clear, but after clearcoat, I was sometimes seeing sanding lines after all was said and done. I prefer hand sanding body work and primer with wet paper if possible, it reduces the chances of sanding too far or making streaks in filler from clogged paper, and with wet sanding you can almost do your whole car with one sheet of sandpaper lol. What took care of the sanding lines for me was wet sanding the primer with 600 grit before shooting the base coat. Once I did that everything comes out looking pretty now.
#163 | |
#164 |
Trader Rating: (50)
agreed on the 600 grit. i had the same issue with 400grit then going to basecoat. i think that only works if you were going to apply a coat of sealer before basecoat.
#165 |
Trader Rating: (50)
I was talking to a Paint Supply shop and he rough quoted me around $300-$350 for 2 stage, base and clear or single stage for about $280-$300. He also commented that he thought the single stage would last longer or sometime like that. I really am only using the AutoZone brand because it is super fast dry since i will be doing my spraying just outside my garage since its all cluttered up and i have no where else to spray the car. And again the $100-$150 price is not bad either.
#166 | |
http://zilvia.net/f/builds-builds-on...r-project.html This is a very good step by step for painting: Perfect Paint Job always follow manufacturer specs and instructions to the T. SPI products are excellent and also very budget friendly, and the dude at SPI knows his stuff! |
#167 | |
#168 | |
Trader Rating: (50)
#169 | |
#171 | ||
![]() Join Date: Mar 2008
I know with single stage paint you don't have to worry about clear coat flaking off and you can buff if it ends up looking dull over time. my car's clear coat started flaking off so I'm pretty turned off by 2-stage paint right now ![]() |
#172 |
Most OEM reds are single stage. Other solid colors used to be but manufacturers are moving away from that. Single stage is a good option for solid colors but generally costs a lot more for a quality product vs. a cheaper base and a good clear clear of that same color.
Metallic single stage paints are obviously not good as there is little depth to the final finish and you can not sand and buff the paint after it's cured. Whatever trash is in there or orange peel you have to live with or repaint the whole car. |
#173 | |
Specially on a red car like ours from what I've been told. |
#175 |
Extra clear is not the answer, its the quality of the product and proper paint prep that will give you a long lasting finish. Also you have to take care of the clear coat if you want it to last, environmental issues will cause damage ( acid rain, dessert heat, areas of extreme cold and snow etc...) As far as good products, i personally use the dupont system but there are many other good brands. I feel PPG and the dupont systems are the best
#176 |
have you guys tried this foam masking product? It's used to fill in gaps to protect door jams and other areas from overspray.
PDF: http://www.nortonautomotive.com/uplo...-Tape-8278.pdf |
#177 | |
#178 | |
#179 |
Also if you're doing your own paint job you might as well take off all the panels and spray the jams and undersides of hood/trunk/doors to have a really great finished job. Sure this isn't cost effective for a shop needing a quick respay (a shop would charge $3500-5k for this detailed kind of job) but if we're talking DIY it's worth your own effort even if you aren't doing a full color change!
#180 |
![]() Join Date: Jul 2010
So what would my steps be when it comes to plastic pieces? I picked up some oem side skirts and they're red and looks like they sprayed primer over the paint and it's flaking off a bunch. What kind of grit should I sand it down with and do I have to use an "adhesion promoter" before the primer because it's plastic not metal? Do you have any advice on how to match the paint to my car because you can tell the car has obviously been painted before so I'm not sure the current color it is or if it's just been resprayed the same color so I don't want it to come out a different color.
