#631 |
Bumping it back alive, have an update. I still run the suprastore 2jz adapter on a later model internal slave CD/JK40C trans in my S13, 98 q45 diff with j30 axles. I've launched the car (no prep) off 20psi anti-lag on 275/40/17 drag radials with no problems, it takes it like a champ. The only issue I still have is the transmission is hard to get into gear at a stop. I'm using a quartermaster internal slave and the factory s13 master cylinder with a spec stage3+ clutch. The car also tends to creep forward when you are in 1st and let off the brake. The clutch (pedal travel) engages about 2in from the top (3/4 way up) and feels normal. I did have a pilot bushing get eaten alive last season and I'm wondering if it happened again even tho I installed a new adapter and bushing last season. It seemed to be causing the input shaft to hang up. Or is my master cylinder or slave not traveling far enough? Maybe shit mating angle even tho I run the bell housing Dow pins somehow? I really don't enjoy pulling the trans out every 1k miles to repair/try to figure out this issue lol.
S13- 2jz, 370z 6spd, PT6262 Nissan Master/GT-R Technician |
#632 |
![]() Join Date: Oct 2007
Whats your air gap set at ? Stoper on the clutch pedal since you run a hydro release ? You have dowel pins on your adaptor kit ?
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
#633 |
Not sure on the gap off the top of my head, using a quartermaster slave and shimmed it according to the instructions. I do have dowel pins. I can adjust the master cylinder rod out and it makes no difference which is why I think it's an alignment or input shaft issue. I need to pull the trans and inspect the pilot bushing again. I know I did have a bit of side to side play with the input shaft, but I couldn't find a spec in the 370z fsm for that.
#634 |
![]() Join Date: Oct 2011
![]() Feedback Score: 27 reviews
I FINALLY mocked up the CD009 (Maverick Motorsports adapter) to my SR. Once it was all put together, my bud decided to remove the fork boot and check the gap on the TOB to pressure plate fingers. I’m glad we did! It barely touches the pressure plate fingers at full engagement. I’m using the stock pivot ball (shorty), stock Z33 fork, and stock Z33 TOB/carrier. I now know I have to use the SR20 TOB, but I wonder if thatll be enough (should I get the taller pivot ball). Here’s some pics
![]() ![]() ![]() ![]() Holy shit these pictures are huge. Sorry about that let me try and edit the size
IG @jerry_beans_ |
#636 |
#638 |
Double post edit
#639 | |
Here is a list of carriers from nissan 12mm : 30501-A3800 14mm : 30501-N1601 16mm : 30501-U0200 18mm 30501-S0200 (Z33) 22mm : 30501-S0160 (Z32) 24mm : 30501-K0404 (S13/S14) 26mm : 30501-K0510 (D21 Frontier / Xterra) 28mm : 30501-N1600 (D22 Frontier / Z31 Turbo) [07/83 - 09/86] 32mm : 30501-U8584 (D40) I did that on my buddy s14 ... im sure you can figure it out with my drawing https://www.instagram.com/p/BKj-KCKA...=15cklkfmhg7no
#640 |
![]() Join Date: Mar 2009
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 10 reviews
I went with a D21 carrier with I did an OsGiken twin disc clutch with my Mazworks conversion bell housing. Not that it's relevant to that guys issue lol.
#641 |
I'm picking up a KA-T car with a cd009 but has a stock 4.08 rear end. What's the preferred or best diff to match this transmission? J30, Q45 or Z33? It'll be a daily driver with occasional sprinted mountain drives and highway runs. I can pick up a Z33 for $100 at the moment but worried about axle fitment... any suggestions would be greatly appreciated. Tons of good info in here! The speedo isn't working at the moment but I believe I've nailed that portion reading through all these pages!
#642 | |
#643 | |
Thanks for the quick response. I'm glad guys are still on here! |
#644 | |
Eh, just drive it with the 4.08. People put way too much thought into the gearing and rear ratio and think it’s going to be miserable and everything else. I don’t even notice it. I mean yea at 80, you’re running a bit high on revs but it’s not out of the norm for Japanese “sports” cars. IE Miatas and b series Honda’s with type r gearsets. Yes that’s completely different but my point is, just drive it, see how you like it, then maybe change if you don’t enjoy it but don’t be scared of it. People make it out like it’s WAYYYY high and stuff like that. It’s not. I actually really like the 4.08 on the street and I’m at basically 500whp but run around 400most of the time. I’d like to try a 3.69 or 3.54 for the faster tracks and it would be fun for long pulls but short snappy acceleration and tight tracks, the 4.08 is a blast. I stick it in 3rd and ride on things like OSW’s skidpad if you’re familiar with that from AdamLZ, Quanbeck, or Taylor Ray’s videos. They run it a lot. Kind of gives you an idea, I run that course completely in 3rd with the 4.08 and can do it just fine even with the boost really low. So I say, get it, try it, and then report back! But I think it might surprise you, especially if it’s lower powered
IG:@DustinClement |
#645 | |
IG:@DustinClement |
#646 | |
Yes I saw your detailed explanation on how to get the speedo working. Would that same setup work if I went with a z33 diff? I think I'm gonna keep the 4.08 in it and buy the z33 diff ($100 bucks) and the axles to keep on the side - this way I can swap if I don't like the 4.08. I believe if I have the above I would only need the Maverick diff bushings.. |
#647 | |
It will be fine, I run a 4.08 in my vq35hr swapped s13, so has a similar rpm limit to your KA-T. The gearing is perfect imo. You would also need to widen the rear track width to run the z33 differential and axles. Just the axles with s-chassis diff and villains/getnuts stub shafts the factory track width is enough. |
#648 | |
#649 | |
IG:@DustinClement |
#650 |
#651 |
Longer lower control arms and lengthening the other arms to compensate. Or spacing the hubs outwards with something like a dual caliper adapter bracket does.
#652 |
Anyone know the length of the input shaft AFTER you trim off 3/8 inch for the mazworx kit? I picked up a swap second hand and want to make sure it was setup properly. The shop that did it originally does so-so work.
#653 |
![]() Join Date: Nov 2004
So, I've decided to bite the bullet, and upgrade my transmission. But, I'm wondering if you guys could help me out a little. First off, I'm located in Hawaii, so I'm looking for the most cost effective swap. Secondly, I'm looking for simplicity and reliability. With that being said, what kit would you guys recommend?
#654 | |
With that said; if you are planning a 6 speed swap, the easy button solution is the Mazworx cast bell housing kit. If not, then bell hosuing adapter, machining the bell housing, shifter mod, driveshaft, reverse and neutral switches to be wired in and speed signal need to be sorted. Its several thousand no matter how you look on it. So do yourself a favor and accept it's going to be that much unless you are patient enough to find a smoking deal. Then when you decide, just choose your poison (cut and shut, Mazworx bell cast bell housing or adapter plate) P.S This is the CD009 swap afterall. However, you do have another Z chassis option; The NA Z32 (those can be had for cheap) swap is a cost effective 5 speed option that will handle 500+ W torque all day long, which comes in much cheaper. You can be all in for less than 1K if you go that route. Apart from that, it's all going to cost you. Good luck! |
#655 |
![]() Join Date: Oct 2004
@D-Clem, I run a lot of track and I have a 4.36 with S15 HLSD.... Highest front straight speed I got is about 145MPH on my 4.08 stock vlsd back then. Car is about 400WHP....
Do you think I will run out of gear on my CD009? @speedgod^s13. Truthfully I thought the CD009 was an easier DIY option then using a NA Z32. It doesn't look like Mazworx gives you a template for the VG cut out....
#656 | |
#657 | |
Spend some time in a gear ratio calculator and figure out what might work best for your goals. I like: http://www.grimmjeeper.com/gears.html because they already have most Nissan trans values pre-loaded and you can directly compare changes. |
#658 |
I read through this thread and I don't see many people posting their experience with the JZ Collins Kit.
I'm up in the air if i need to go with a kit where i cut the front of the bell housing off and attatch the adapter, or if i can just run an adapter plate and keep the stock cd009 bellhousing.. In my chassis the r154 currently fits fine, so i'm hoping i don't have to bash my bellhousing up any more than it is. My oil pan also sits pretty low, its a little below the sub-frame, so i'm hoping that helps with clearance. HELP!! lol |
#660 |
Has anyone put serious power through the 5th and 6th gears? I'm going to be running 1/2 mile and the speeds I want to hit will require hear 6th gear redline runs. My car should be making around 750RWHP. I'm worried about the strength of the top gears.
Any actual experience would be appreciated. |
