#22651 | |
![]() Join Date: Jun 2003
Trader Rating: (130)
#22652 | |
1996 Zenki 'Baraketsu Tenshi', Burst Angel My work in progress... |
#22654 |
ka's are beefy 4 cylinders. If you do all the supporting mods, headgasket, rings,better cooling etc. you can very reliably run 300 hp. And imo, a 300 hp ka is more fun than a 300 hp sr because of higher torque outputs. hp will make you go fast but torque is what you'll feel. I got a 300 hp ka-t setup in the works rn, and just drove it for the first time a few days ago, super fun. The ka bottom ends are decently strong. if you beat the piss out of it without maintaining it they can spin bearings, and also the pistons aren't well suited for turbo applications, but at around 300hp youll be fine. 8 or 9 lbs of boost with an rsenthalpy tune and call it a day.
#22655 |
Alrighty, I need some help! My car has had this issue for about 4 months and I just can't figure it out. So my ka24e when i get up to 3500 rpm it starts bogging and will sit at that till i floor it and then it goes past it and will be fine. So if you have any knowledge on this please let me know. Thank you!
My maf is working. |
#22656 | |
If you go shit ebay parts and run boost on a stock un/ill prepared bottom and and head, yeah, 300hp will be fun for about three months. Horsepower costs money boy, how much you really want?
#22657 |
![]() Join Date: Oct 2010
![]() ![]() ![]() Feedback Score: 16 reviews
(s14) pulled my gauge cluster out to install some chrome trim pieces to it, now my temp gauge isnt working. not sure what i could have fucked up by doing this.
i checked the 7.5 amp fuse for the cluster and tightened down some of the screws on the back. ive reconnected the 4 plugs and made sure the pins are sitting correctly. what else should i be checking for? the needle isnt stuck in place, i can move it. also i did not disconnect my battery while doing this. ![]() |
#22658 | |
Step 2: See step 1 Now remove your cluster, and go through it cleaning the connections, and placing dielectric grease in each connection after cleaning. Clean the back with denatured alcohol, NOT acetone or any other plastic melting shit. Put it together and it should be fine providing you did not blow anything else
#22659 |
Whats the Part number for the s14 windshield wiper linkage? Its not available on rockauto, anyone know where to buy one new?
#22660 | |
![]() Join Date: Sep 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 20 reviews
https://www.amazon.com/WINDSHIELD-TR.../dp/B07BZVX645 |
#22661 |
Looking to do 5 Lug on my S13 Hatch soon. It has ABS that I'd like to retain, and I've read some stuff about an ABS tone ring pressed onto the back of the front hubs.
I really have no idea what I'm looking for, how to get it out of the hub, and how to put it on the new one. I will also be doing R32 GTR (non brembo) brakes on the front with DBA4000 rotors, if that makes a difference (heard some other stuff about ABS rotors and whatnot). I have these Ichiba conversion hubs. https://www.enjukuracing.com/product...0sx-89-94.html |
#22662 |
Has anyone purchased a z32 turbo driver side axle from rock auto before? Used ones are going for $300+ and they have a reman for $90?
Dont be a pussy...Leave your name |
#22663 |
#22664 |
#22666 |
![]() I quickly ordered decal/windshield banner text in hopes of putting it at the bottom of my windshield, I didn’t think about whether I should get the inside or outside decal I just bought the one that applies from the outside before thinking
Question: If I still put the decal at the bottom of the windshield will the wipers fuck it up or should I find a different spot for it? |
#22667 | |
![]() Join Date: Apr 2019
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
#22668 | |
#22670 |
![]() Join Date: Nov 2008
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
Anyone ever have to fill out an HS-7 form to import a set of wheels? What is "Declarant's Capacity?" I can't find a straight answer.
Just curious, shipped with FedEx and this is the first time I've ever had to deal with this. I usually use DHL.
#22671 | |
Yeah, you have to fill out an HS7 form to customs for importing wheels now. For "Declarant's Capacity" just declare "Individual". |
#22673 |
Hi, probably a dumb question but yeah.
Just got my car an alignment. He took out all the rear camber for me but the car raised up because of that and I want to lower it back to the height it was at. If I lower the rear an inch or so will it gain more camber? Sent from my SM-G935F using Tapatalk |
#22674 |
Yes, the suspension geometry when lowering with independent suspension will naturally camber in the wheels, and often toe-in as well (terrible wear on the tyres.) Reducing the negative camber will often put the tyre closer to the fender so it's a trade-off of being low or less neg camber. Wheel specs need to be factored in to get the perfect stance you want!
#22675 | |
#22676 |
![]() Join Date: Jan 2010
you need to go to a shop that will do what you want them to do. as kanye said, lowering it will get it out of wack again. you really should have hashed all this shit out before letting someone touch your car.
assuming you have adjustable arms. its going to be more expensive than your average run of the mill alignment, because it requires more labor. |
#22679 |
![]() Join Date: Sep 2006
I went from -5 camber in the rear (long story) to -2 and simultaneously lowered the rear about an inch...it's about the same height still, maybe a tad lower.
We don't know your suspension setup or pictures of your current height...so can't really answer what your car's characteristics will be to lowering it more. If you have full arms/knuckles, maybe. If it's mostly stock, ehhh. Best bet is loosen everything up and play with it. Or get someone who knows these cars well to do it. I've paid $200 to get alignments with fully adjustable suspension, but that's them spending like 4+ hours and hooking me up heavily lol
loading HATERS.....99% ███████████████] |
#22680 | |
I have HSD coilovers S14 lcas KTS tension rods DPR camber arms DPR toe arms I only have one photo at the moment but I add in a photo of the alignment sheet. I told him I wanted the rear camber zero'd out and he could get it to -0.030 max which is close enough anyway. And doing that made the rear probably around 2 inches taller. If I drop it 1-1.5 inches it shouldn't make a major difference should it? Talked to a few mates that work at tyre and suspension shops and said it wouldn't do much ![]() ![]() Sent from my SM-G935F using Tapatalk |
Tags |
180sx type x kouki, 1jz, 2jz, 300zx, clutch, faq, ka24de, n/a, non-turbo, question, redtop s13 180sx silvia, s14, search, solenoid, starter, z32, zenki |
