04-15-2019, 02:46 PM | #1 |
New owner looking for reassurance
So i finally bought an s13 with an RB20det. Took it to the shop and discovered slow leaks for power steering AND the clutch. And possibly coolant too but not sure.
Did i goof bad? |
04-15-2019, 06:24 PM | #2 |
Those are very minor issues. Even more minor then engine oil leaks which is usually a seal that needs replaced.
Power steering is most likely going to leak at the hoses which will need replaced. Clutch is going to probably be both the master and slave cylinder, and maybe line. But these are common wear items that have to be replaced every so many thousands of miles anyways. And the parts are not terrible in cost either. Don't let that shop try to screw you over on extra charges, things that don't need replaced asap, have someone you trust do the repairs or learn how to do them yourself. You'll appreciate the car a lot more if can do those things. Sent from my ONEPLUS A6003 using Tapatalk
Join my discord server! https://discord.gg/SDN7fw2 |
04-16-2019, 12:38 PM | #3 |
That's such a huge relief lol thanks. i guess i can keep the fluids topped off until i get it fixed? I also noticed that the aftermarket oil press guage is showing 0 pressure.. hopefully it's just disconnected but is there a way to check if the oil pump is working?
04-16-2019, 01:15 PM | #4 | |
Trader Rating: (130)
Feedback Score: 130 reviews
if the engine hasn't spun a bearing yet, its probably just not hooked up, but verify before putting miles on the car. |
04-16-2019, 06:41 AM | #6 |
Idk dude sounds fucked. PM me if you wanna sell it for cheap and wipe your hands clean of it
loading HATERS.....99% ███████████████] |
04-16-2019, 07:00 AM | #8 |
Well, it sounds like you bought a 25+ year old car! Get some tools!
04-16-2019, 07:06 AM | #9 |
This^^^
04-16-2019, 09:54 AM | #10 |
+1 for all 240s leak p/s fluid
the clutch is leaking? easy enough to replace a clutch line with a new stainless braided line. if yours is still the original/factory one, delete the clutch damper at the same time |
04-16-2019, 01:16 PM | #11 |
also, did you find out if its leaking coolant??? if so, from where???
any mechanic shop worth a shit will have a pressure test kit that can help determine where its leaking |
04-16-2019, 03:13 PM | #12 |
Also you can rent them at Auto Zone or similar, also you can get a UV dye kit for your steering fluid (and likewise for the coolant if its not obvious) and use a black light to trace it to the source.
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 | |
04-16-2019, 04:05 PM | #14 |
its not uncommon for a small amount of fluid to be in that area. like 1/2oz. Imagine the cap of a 20oz coke bottle. That much or less and I wouldn't worry about it. If its more than that, time for a new rack.
04-16-2019, 10:34 PM | #17 |
...this is in the wrong section. Again. Damn man, I can't even get a position as mod.
Half of you in here would bitch at this thread one day and today y'all are helpful. Direct this poor soul to the right section, and help them there. Fuck.
The mark of a true sucka: 'RARE JDM' & 'OLD LOGO NISMO'
04-17-2019, 12:50 PM | #19 |
If you decide to upgrade your power steering system and need power steering rack fittings let me know.
Facebook or Instagram:@tightfitfab Email: [email protected] Check Us Out At: www.tightfitfab.com |
