Old 10-19-2020, 05:23 PM   #1
slider2828
slider2828's Avatar
Aluminum Welding Rod Tests - Wayy better than anticipated
Beading or putting together IC hot pipes and cold pipes. This seems to be fine!
Also I would probably use this for welding bungs to those IC pipes.... Better than JB Welding them!
What you guys think?
http://www.youtube.com/watch?v=fKIKsDfRAcs
Turn and Burn!
Old 10-19-2020, 05:36 PM   #2
S14rebuild
Used this before on some flat bar and aluminum nuts. But Wouldnt trust it to do intercooler piping....
Old 10-19-2020, 09:20 PM   #3
slider2828
slider2828's Avatar
Why not? You running what max 35 psi at any point... that is pretty much nothing....
Turn and Burn!
Old 10-20-2020, 02:02 AM   #4
Kingtal0n
Kingtal0n's Avatar
Tig welding aluminum was always easier for me than steel. I made countless sets of intercooler plumbing over the years and wouldn't do it any other way. It doesn't take long if you have the right tools, bandsaw, carbide bit,... I've even seen a special tool for removing burrs quickly without the use of an air compressor tool. I'm no machinist yet plumbing was always very easy and quickly done, not sure how you can improve that, looking for a way to improve something that doesn't need to be improved.
Old 10-20-2020, 04:10 AM   #5
S14rebuild
Figured between vibration and 25-30psi over the whole area wouldnt hold up.... always tig welded my pipes. Just didnt seem like the best way. Guess somone should try it.
(Ive seen iat bungs brazed and hold up)
Old 10-20-2020, 09:52 AM   #6
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
This guy tested these rods on pipe and looks like it would work well for intercooler pipes. This is a much cheaper alternative to welding.
https://www.youtube.com/watch?v=JYzMHdedIeM
spooled240 is offline   Reply With Quote
Old 10-20-2020, 10:39 AM   #7
S14rebuild
I guess...but it looks like shit, n ur not getting penatration. Guessn jbweld would do the same
Old 10-20-2020, 11:46 AM   #8
SupaDoopa
SupaDoopa's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
If you're justifying this instead of doing it the right way, god bless. That looks like dog shit, isn't going to hold as well as you think and has zero penetration.
SupaDoopa is offline   Reply With Quote
Old 10-20-2020, 12:17 PM   #9
d9m13n
d9m13n's Avatar
d9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really nice
Might be a good thing to stick in the toolbox for trackside fixes, but otherwise I'd rather have my piping done the right way
That wing looks as effective as the electoral college.
d9m13n is offline   Reply With Quote
Old 10-20-2020, 12:45 PM   #10
S14rebuild
This is perfect....just a track/bandaid fix
Old 10-20-2020, 07:35 PM   #11
slider2828
slider2828's Avatar
For me its an alternative to weld on an bund to some aluminum..... It would be stupid to buy a TIG welder to do bungs once maybe 5 years..... I have a crappy mig for car panels or something, but TIG is another level.
But agreed on full piping probably not, but track fix would be awesome!
Turn and Burn!
Old 10-21-2020, 08:54 AM   #12
Abeo
Abeo is an unknown quantity at this point
The problem with that stuff as a trackside fix is once you get the permanent repair done, you'll be battling weld contamination like crazy. Stick to quick epoxy for trackside repairs which can be removed easier later.
I've actually used that stuff a couple times on a motorcycle to fill in where a chain went awry... It's not easy to work with. It's basically like working with solder and not like welding.
Abeo is offline   Reply With Quote
Old 10-21-2020, 08:59 AM   #13
silviaks2nr
silviaks2nr's Avatar
The thing is once you have a TIG you will find a million uses for it and you can build your own cool shit. A good hobbyist AC/DC TIG setup can be had for under $1200 (including a 150 bottle of gas, nice foot pedal, torch, consumables etc.). The machine will pay for itself pretty quickly.
'98 240sx 5spd
kouki 2jz t56 swap build
Old 10-21-2020, 06:24 PM   #14
TheRealSy90
TheRealSy90's Avatar
Or don't buy a whole damn tig to weld a bung and have your local friend that welds do it for you.
Such a good signature.
Old 10-21-2020, 08:40 PM   #15
slider2828
slider2828's Avatar
Its tough to have welding friends close by actually in the SF Bay Area. Either they are full time fabricators that really don't have a lot of time or they are very far because shop rent / fabricators are really really hard to have prime real estate with so much high tech.....
Gotta go outskirts.... Then you think 5 mins to weld a bung and a 40 minute drive 1 way to get it done..... gotta have a few short cuts
Turn and Burn!
Old 10-22-2020, 05:56 AM   #16
silviaks2nr
If there's anything I've learned about cars it's that it's always better to do it yourself not rely on someone else... Even a friend. Put yourself in that friend's shoes too and you end up welding dirty little jobs as favors for everybody.
'98 240sx 5spd
Old 10-22-2020, 12:31 PM   #17
slider2828
slider2828's Avatar
Yup i agree. All my friends have jobs and families. And to do anything in SF bay area with fab, you either gotta be like matt field drift cave building 100k drift machines or not surviving.
I think its really becoming fact of life being older and owning a serious big boy toy.
But ima try this welding rode.
Hope you guys sat through the video, its always done well.
Turn and Burn!
Old 10-23-2020, 03:36 PM   #18
Abeo
Sounds like you are set on using this stuff, so good luck...
If I were in your position, I'd be looking at a $100 flux core mig and mild steel pipe.
Old 10-24-2020, 09:31 PM   #19
slider2828
slider2828's Avatar
Yea i have a mig and gas. But not pipe bending. So i just use my blitz pipes and put iat bung. I tapped and jbwelded thr bung before on my car and was fine on track duty. Figured this would be better than JB
Turn and Burn!
Old 10-24-2020, 10:07 PM   #20
zombiewolf513
works pretty well for fixing A/C tubing.
Old 10-26-2020, 03:33 AM   #21
ixfxi
ixfxi's Avatar
no, for you its stupid because you're making excuses as why you shouldnt buy a proper welding machine. you're literally comparing a tool that has infinite uses, with a brazing procedure that has very limited uses.
yeah, try explaining what you are saying here to non welders - they just dont get it. they dont know the challenges associated with welding, let alone contamination and good prep. the majority of people think stick welding is welding. well, i guess it is... if you work on ferrari chassis'
I dont think this is in his interests. forget the investment costs which in my opinion are significant, most people dont have the space nor do they have 240V.
Old 10-26-2020, 10:41 AM   #22
spooled240
spooled240's Avatar
Some people don't even have workspace with 110V
#apartmentlyfe
