Old 10-06-2021, 08:19 AM   #1
Yardman_45
Yardman_45 is an unknown quantity at this point
s14 Nissan 240sx S14 with 1JZ non VVTI wont start just clicking on passenger side
He My Car friends in need of some help 240sx S14 1jzgte non vvti car start when it wants to know takes for ever to start and just a clicking sound from the passenger side I replace the Starter, Battery, Computer, ignition switch still doing the same thing.
Yardman_45 is offline   Reply With Quote
Old 10-06-2021, 09:58 AM   #2
Jdmlovess14
Jdmlovess14 is an unknown quantity at this point
I’m kind of guessing here but maybe check the igniter chip. Make sure it’s grounded properly
Jdmlovess14 is offline   Reply With Quote
Old 10-06-2021, 12:23 PM   #3
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
make sure your grounds are properly attached to METAL, not paint.
Old 10-07-2021, 10:30 PM   #4
Yardman_45
I'm going try my friend good working one and I thing I should have one in storage �� thanks I'm going to check this out also
Old 10-07-2021, 10:36 PM   #5
Yardman_45
I'm going to check again all the grounds cables and the positive cables the weird thing the car was running before I park it up for a year.
Old 10-08-2021, 07:02 AM   #6
silviaks2nr
silviaks2nr's Avatar
Is the battery relocated? Will it start if you jump it off from another box or car? Check your clutch pedal switch (jump pins) if the car is still wired to use the factory ECCS relay. If your battery is relocated did you use proper 0 gauge full copper welding wire? Same goes for grounds. You can also try swapping another ignition switch in to test. It takes all of 5 minutes.
'98 240sx 5spd
kouki 2jz t56 swap build
Old 10-11-2021, 02:13 PM   #7
Yardman_45
I did relocated battery and Replace all Wire from the Battery and also check all my ground I also replace the ignitor and ignition switch I'm thinking to replace the ECU.
Old 10-13-2021, 01:23 PM   #8
RalliartRsX
Trader Rating: (32)
RalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfection
Feedback Score: 32 reviews
FUsible link or the large starter fuse?? Or maybe the starter relay is dead??
RalliartRsX is offline   Reply With Quote
