Old 12-30-2023, 07:13 PM   #1
CrimsonRockett
The Architect.
CrimsonRockett's Avatar
Trader Rating: (392)
Feedback Score: 392 reviews
Arrow OEM S13 & S14 Garage Sale - Exterior, Interior, Suspension, Engine Bay. TONS of parts
SHIPPING: At buyers expense
CONTACT INFORMATION - [email protected] or via PM.
PAYMENT OPTIONS: Cash, Paypal, Zelle
Hey Zilvia folks,
I'm working on a list with every single last OEM S13 and S14 part I currently have available that I am looking to clear out.
Please only refer to the list below. Anything not on the list is not available or not for sale.
I will work on updating the entire list with pricing as well as pictures. I have over 2000 pictures of S-chassis parts to work through and have some catching up to do. In the meantime, feel free to DM me on here or Instagram @CrimsonRockett.
I can ship just about everything including the larger pieces like quarter panels and core supports. Those will go via freight.
I also have a ton of items already listed on my eBay page:
https://www.ebay.com/usr/crimsonrockett
S13 Parts List
S13 Exterior
RH Quarter Panel Replacement
Non-Sunroof / Slicktop Replacement Roof for S13 Hatchback
Front Bumper Upper Retainer
Front Fender Brackets
Headlight Metal Lid
Headlight Splash Guards (plastic, sit on radiator core support)
Hood Prop
Hood Hinges
Hood Latch
Cowl Trim Covers
Wiper Arms
Wiper Motor
LH Door Glass Window
RH Exterior Door Handle
Rear Bumper Cover
Rear Bumper Support
Rear Bumper Brackets
Rear Bumper Foam
S13 Hatchback Taillight Set
S13 Hatchback Taillight Metal Garnish
S13 Hatchback Trunk 3rd Brake Light
Fuel Filler Door
LH or RH S13 Hatchback Exterior A-pillar Trim
B-Pillar Plastic Exterior Trim
Front Amber Fender Sidemarkers
Rear Red Sidemarkers
S13 Hatchback LH or RH Quarter Windows (no trim)
S13 Interior
S13 Hatchback Ignition/Doors/Trunk/Glove Box Lock Set with Key
Steering Column
Lower Steering Column Cover
Dash Plastic Vents / Tubing (behind dash)
RH Dash Vent
Blower Motor
Heater Core Box
AC Core Box
Antenna Wiring Harness
LH or RH Door Frame Trim Finisher
LH or RH Interior Door Handles
LH or RH Interior Door Handle Bezel
LH or RH Interior Door Handle Pull Plastic Trim
RH Door Grab Handle
Window Crank Handle w/bezel
LH or RH Triangle Mirror Covers
LH or RH Door Latch Door Assembly
LH or RH Door Lock Rods
LH or RH Door Misc Brackets
LH or RH Speaker Brackets
Radio Brackets
Din Pocket
Glovebox (no handle)
S13 Factory Non-AC Climate Control Set
LH Seat Plastic Trim
RH Auto Seat Belt Track
LH or RH Lap Belt
LH or RH Shoulder Belt
Rear Seat Belt Buckles
S13 Hatchback Rear Seat Belts
LH or RH Kick Panels (Black)
S13 Hatchback Rear Speaker Metal Brackets
S13 Hatchback Non-Sunroof Headliner
Dome Light
Fuel Pump Metal Cover
Misc Interior Brackets
Misc Interior Buttons (Headlight, Hazard, Defroster, Dimmer, etc)
S13 Suspension / Brakes
Front Knuckles
Front Lower Control Arm Set
Steering Rack
Steering Rack U-Joint
Front Brake Caliper Set
Rear Brake Caliper Set
Emergency Brake Cable Set
Rear Lower Control Arm Set
Rear Upper Control Arm Set
Rear Traction Rod Set
Rear Toe Arm Set
Rear Subframe Brace
Rear Subframe Stud Set
Diff Cover
Welded Diff (Non-ABS, 4.08 ring gear, 6-bolt shafts)
OEM Axle Set
Rear 4-lug Hubs
Front/Rear OEM Shock and Spring Set (newer KYB)
Front or Rear OEM Sway Bar
Brake Master Cylinder
Brake / Fuel Hard Lines
S13 Engine Bay
KA24E Complete Air Intake Set (Tubing, filter box, etc)
KA24E Engine Block
KA24E Cylinder Head
KA24E Valve Cover
KA24E Intake Manifold Bare
KA24E Throttle Body
KA24E Fuel Rail
KA24E Distributor
KA24E Alternator
KA24E Power Steering Pump
KA24E Power Steering Reservoir
KA24E MAF Sensor
KA24E Ignition Coil
KA24E Misc Pulleys
KA24E / KA24DE Emissions Components
Misc KA24E Engine/Block Brackets / Parts
Charcoal Canister
OEM Radiator w/hoses
Windshield Wiper Tank w/filler neck
Fuel Filter Bracket
S14 Parts List
S14 Exterior
OEM S14 Zenki Leather Nose Mask
LH or RH Quarter Panel Replacement (complete cut out)
LH or RH Rocker Panel Replacement
LH or RH Strut Tower
Radiator Core Support
LH or RH Frame Rails
LH or RH Door Shell
LH or RH Exterior Door Handle
LH or RH Door Check / Stop
LH or RH Door Belt Trim
LH or RH S14 Zenki Fender
S14 Zenki Hood
Hood Hinges
Hood Latch
S14 Zenki Hood Prop
S14 Zenki Front Bumper
S14 Zenki Fog Light Delete Trim
S14 Zenki Headlight Set
S14 Zenki Corner Lights
S14 Zenki Turn Signals
S14 Zenki Front Bumper Support w/ Retainer
S14 Zenki Front Bumper to Fender Brackets
Windshield Wiper Cowl Trim
Windshield Wiper Set
Wiper Rotating Arm Assembly
S14 Zenki Wiper Motor
Rain Gutter / A-Pillar Exterior Trim
Wingless Trunk
Trunk Support Arms
3rd Brake Light
S14 Zenki Taillight Set
Rear Bumper Cover
Rear Bumper Support
License Plate Light
Front Windshield
LH or RH Door Glass
LH or RH Door Mirror
Rear Windshield / Glass
Rear Glass Lower Trim Finisher
Rear Tow Hook
Fuel Filler Door
S14 Interior
S14 Zenki Black Cluster
Cluster Bezel
Dash Metal Brace
LH or RH Dash Vents (lead to door panels)
Steering Column Trim (2pc with ignition trim)
Lower Steering Column Trim
Steering Column
Throttle Pedal with Cable
Throttle Pedal Stopper
Dead Pedal
Wiper Switch
Turn Signal Switch
Wiper/Signal Holder Bracket
Steering Wheel Clock Spring
Glovebox (no latch)
Glovebox Bracket
Center Console
Side view mirror switch
Ash tray
Radio Brackets
Climate Control Panel
Blower Motor
Heater Core Box
AC Core Box
Dash Vent Piping / Ducts
Emergency Brake Handle
LH or RH Door Panel
LH or RH Window Regulator
LH or RH Door Handle Bezel
LH or RH Door Lock Latch Assembly
Cigarette Lighter
Sun Visor Set
A-Pillar Set
B/C Pillar Set
Front and Rear Seat Set (OEM Gray)
Rear Seat Swivel Brackets
Rear Seat Striker Bracket
Front Seat Belt Set
Front Seat Belt Buckles
Rear Seat Belt Set
Rear Seat Large Interior Plastics
Rear Seat Trim Finisher (behind seats)
Rear Speaker Deck Lid
Light Dimmer Switch
Hazard Light Switch
Defroster Switch
Cruise Control Switch
LH or RH Kick Panel
Door Sill Set
LH or RH Door Frame Seal / Finisher Trim
LH or RH A-Pillar Window Frame Seal
Trunk Carpet Panels Set
Trunk Rubber Seal
Trunk Latch
Trunk Striker
Trunk Edge Plastic Trim Cover
Fuel Pump Cover
Trunk Light
Jack with Mounting Bracket
Misc Interior Brackets (Dash, doors, interior panels, trunk, etc)
S14 Suspension / Brakes
OEM 5-lug Front and Rear Hub Set
OEM 4-lug Front and Rear Hub Set
Front Knuckles Set
Front Crossmember
Steering Rack
Rear Upright / Knuckle Set
Rear Lower Toe Arm Set
Rear Upper Traction Rod Set
Rear Subframe Brace
Rear Subframe Tunnel Bracket / Brace
Brake / Fuel Hard Lines Set
Fuel Tank Straps
Fuel Tank Heat Shield
Fuel Filler Neck
S14 Engine Bay
Zenki AC System Complete Set (Compressor, Condenser, all lines, brackets, etc)
Zenki MAF Sensor
Charcoal Canister
Complete Air Intake System (intake pipe, air filter box, all ducting)
Cruise Control Assembly
Heater Core Hoses
Power Steering Cooling Hard Lines
Fuel Filter Mounting Bracket
Radiator
Radiator Mounting Brackets
-Jspec-
Instagram/CrimsonRockett
Old 01-10-2024, 08:36 PM   #2
Chief 1402
Chief 1402 is an unknown quantity at this point
Pm sent. Turn signal switch
Chief 1402 is offline   Reply With Quote
