Old 10-05-2023, 09:09 PM   #1
Carbonsnail
Carbonsnail is an unknown quantity at this point
S13 KA24de daily driver Coolant and heater hose replacement How often?
I live in Southern California and was wondering how often I should replace both my coolant and heater hoses. The ones on my car now are around 7 to 8 yrs. Also, are ISR and HPS silicone hoses any good? Thanks for your replies.
Carbonsnail is offline   Reply With Quote
Old 10-06-2023, 12:55 PM   #2
thermogod
thermogod has a reputation beyond reputethermogod has a reputation beyond reputethermogod has a reputation beyond reputethermogod has a reputation beyond reputethermogod has a reputation beyond reputethermogod has a reputation beyond reputethermogod has a reputation beyond reputethermogod has a reputation beyond reputethermogod has a reputation beyond reputethermogod has a reputation beyond reputethermogod has a reputation beyond repute
i have ISR coolant hoses and have done about 500 miles on them with no issues. i don't see why they wouldn't last at least as long as new OEM ones. simple parts.
if your hoses are visibly cracking or leaking, then i would obviously say replace them. i would take them off and check the inside for any debris buildup if anything, but 7-8 years doesn't seem too long.
yeah, that's a great steak, but it's not Cypher's steak.
thermogod is offline   Reply With Quote
Old 10-06-2023, 08:44 PM   #3
DEGUZZI
DEGUZZI's Avatar
DEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to all
I've had HPS hoses on my car for about 3 years/25,000~ miles and they've been fine.
I will say the fitment isn't ideal:
Upper hose rubs right against the stock intake tube
And to fit the lower hose, I had to remove and cap off the small airbox/resonator that connects underneath the intake tube
And the experience from my recent endeavors, I highly recommend changing out ALL the 30 year old rubber on these cars
IG: de_guzzi // Build Thread
DEGUZZI is offline   Reply With Quote
Old 10-07-2023, 04:03 AM   #4
Carbonsnail
Thank you both very much. You were very helpful. DEGUZZI are you running an after market fan with your radiator? I have a Mishimoto setup and it keeps draining my battery every 18 months.
Old 10-07-2023, 08:16 AM   #5
DEGUZZI
DEGUZZI's Avatar
I still have the clutch fan
Old 10-10-2023, 07:21 AM   #6
AKADriver
AKADriver's Avatar
I'm almost certain all the coolant hoses other than the radiator hoses I pulled off my '93 in 2018 at 320,000 miles were original, none of them had failed but none of them survived removal, haha.
Old 10-10-2023, 08:08 AM   #7
Thursday7
Thursday7's Avatar
I have a bone stock '92 that I putt around in from time to time, and every rubber component is original. Not that I'm proud of it, and I'd be lying if I said I don't have an assortment of hoses/clamps/fittings from previous engine partouts I've done lying in the trunk at all times, but I digress.
Point being, while not a prudent habit, the rubber components can be trusted for a long ass time, so long as there aren't any unnatural forces like abrasion acting on them. Silicone stuff probably lives forever, idk.
Old 10-10-2023, 01:08 PM   #8
AKADriver
AKADriver's Avatar
Silicone is interesting in coolant hose applications - it has a higher burst pressure but it's also very slightly porous and can lose coolant over time. I actually don't know how it would perform in terms of longevity in a street car versus rubber. Though I know Ford and GM used silicone radiator hoses in cop cars.
