Old 09-06-2023, 11:29 AM   #1
Tuckedin
Tuckedin is on a distinguished road
Tanabe S14 front Sway bar bushings replacement
Does anyone have a alternate part number for the tanabe S14 front sway bar bushing?
Tanabe no longer offers the sway bars and I need to replace the bushings? Bushing is 30mm and utilizes the factory sway bar bushing bracket.
Tuckedin is offline   Reply With Quote
Old 09-07-2023, 02:00 PM   #2
Thursday7
Thursday7's Avatar
https://www.rhdjapan.com/cusco-front...g-s14-s15.html
Going off logic, any bushing for a 30mm bar will work if it either also uses the stock bracket or comes with its own bracket. The Cusco part in the link above should work given your explanation.
Old 09-07-2023, 10:57 PM   #3
FRpilot
FRpilot's Avatar
Energy Suspension offers universal bushings and are probably easier to source.
https://www.energysuspensionparts.co...r-bushings.asp
They come with a bracket if it doesn't fit the stock brackets and I think the only difference between the greasable and non greasable bushings are that the greasable bushings come with a grease fitting on the bracket.
30mm = 1.1811 inch
Available ES universal bushing sizes close to 30mm:
28.5mm = 1.125 inch (1 1/8" ES greasable & non greasable available)
30.1625mm = 1.1875 inch (1 3/16" ES greasable only)
I would probably go for the 1 3/16" ES greasable (ES site list it as 30mm/1.18in) part number 9.5171
https://www.energysuspensionparts.com/9.5171
Alternatively, you can order it from Amazon, Summit Racing, or even Autozone.
https://www.amazon.com/Energy-Suspen.../dp/B000CN9CTU
https://www.summitracing.com/parts/ens-9-5171g
https://www.autozone.com/suspension-...71r/356503_0_0
FRpilot is offline   Reply With Quote
Old 09-08-2023, 02:30 PM   #4
Tuckedin
Currently looking into this.
Old 09-08-2023, 02:32 PM   #5
Tuckedin
30mm = 1.1811 inch
I already got a ES kit, but I didn't like how the bracket fit. Im still looking into other options.
