Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Local / Regional / National > USA
USA Talk to others in your region.
Old 11-28-2022, 11:26 PM   #1
FtSkyler
FtSkyler is an unknown quantity at this point
Wipers working in accessory and when parking lights are on
Hey, I have a 1993 s13 coupe and my wipers are able to turn on when I'm in accessory mode or if I turn my parking lights on. To my knowledge, it is only supposed to be operable when the car is on. Windshield wipers work as usual if the vehicle is running. Any suggestions on how to fix this?
FtSkyler is offline   Reply With Quote
Old 11-29-2022, 10:34 AM   #2
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Originally Posted by FtSkyler View Post
Hey I have a 1993 s13 coupe and my wipers are able to turn on when I?m in accessory mode or if I turn my parking lights on. To my knowledge it is only supposed to be operable when car is on. Windshield wipers work as normal if the car is running. Any suggestions on how to fix this?
Check your wiring harnesses in your fenders. They're probably worn through and grounding out on each other.
Old 11-29-2022, 03:00 PM   #3
FtSkyler
my harness is relocated under the dash so i may have wired something wrong. this is the only problem i have with the relocation
Old 11-29-2022, 05:11 PM   #4
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Sounds like you need to double-check your work.
There are two fender harnesses on S13s.
Go over those wires and make sure no copper is exposed.
Old 11-29-2022, 07:40 PM   #5
FtSkyler
ended up swapping to my original hud cluster and now the wipers only come on in acc and on. turning on the parking lights doesn't allow me to turn on the wipers anymore (thank god).
the wipers are only supposed to come on when its key on right? not both acc and on
