Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Local / Regional / National > USA
USA Talk to others in your region.
Old 09-22-2021, 05:14 PM   #1
Rylee
Rylee is an unknown quantity at this point
KA 240sx dumping fuel out exhaust
hi I'm kind of new to forums so I hope I'm doing it right. I am having problem with a 1989 s13 240sx I bought I while ago. I've been trying to get it running right but cant seem to find the problem. when I try to start it it take a minute to start then when it start it just dumps gas out the exhaust and then it back fires and since it barley has any exhaust on it it start a fire under the car. I have tried putting a set of new injectors on and that did nothing so I try a new fuel rail and presser regulator but still nothing I've even check the return line to see if it was pluged, but it still wants to burn to the ground. I don't know if it matters but it has a brand new fuel pump in it to, but at this point I'm at a loss. I'm no mechanic by any means I'm just trying to lean while working on the car. any help would be greatly appreciated
Rylee is offline   Reply With Quote
Old 09-23-2021, 08:12 AM   #2
tuzzio
tuzzio's Avatar
Sounds like your timing is off. I'd also recommend putting an exhaust on it so you don't harm yourself, others, or the vehicle.
Old 09-23-2021, 09:03 AM   #3
Rylee
Thanks for the reply ill try to get down to the shop today and try to work on timing and see if that fixes it. I plan on puting exhaust on it but dont have any spare pipe laying around. im trying to hold off buyin pipe untill the motor atleast starts and idles. Im working on it in a open shop with concrete floors and i keep a fire extinguisher right next to me after the first time
Old 09-24-2021, 11:25 AM   #4
Rylee
I try timeing it yesterday but it just did the same again
