Old 12-22-2020, 06:54 PM   #1
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
Throttle body rebuild service?
Hey just seeing if any of you guys know of a throttle body rebuilding shop in SoCal? I need to rebuild my n15 throttle body because it?s leaking boost. Thanks!
lexus baby
5t341tH is offline   Reply With Quote
Old 12-26-2020, 10:14 PM   #2
NukeKS14
NukeKS14's Avatar
NukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really nice
Don't know them directly but a quick google search turned this up;
https://socalporting.com/our-service...-body-porting/
If they can port them, they should be able to rebuild them as well.
There are quite a few shops out there that do mail-in as well. http://maxbore.com/ That guy has a pretty good reputation and I've been looking into sending my KA throttle body his way when I run out of stuff to mess with on my S14. I'd call and talk to them about what you want done but I don't imagine either would have any trouble taking care of the seals.
Good luck, keep us posted.
NukeKS14 is offline   Reply With Quote
Old 12-27-2020, 06:50 PM   #3
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
Just take it apart, measure the shaft diameter and order the seals. Make sure to orient the seals for boost. Some NA tb's like the KA have the seals flipped for vacuum.
spooled240 is offline   Reply With Quote
Old 12-27-2020, 08:19 PM   #4
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
so if i use a KA tb on an SR i should take it apart and flip the seals?
zombiewolf513 is offline   Reply With Quote
Old 12-27-2020, 08:33 PM   #5
spooled240
spooled240's Avatar
I would flip them. The seals on my 97 KA were backwards for boost. Idk how SR tb's are, but Evo tb's have the seals with the open side facing inwards.
Old 12-28-2020, 06:26 PM   #6
5t341tH
5t341tH's Avatar
You guys got a source for seals? My googling only finds shaft seals for evos'
lexus baby
Old 12-28-2020, 09:48 PM   #7
spooled240
spooled240's Avatar
I can't remember, but it was a site that sold all kinds of seals for many applications. Maybe McMaster Carr. Get the measurements for the shaft and the outer sleeves they are pressed in to and you can find the right ones you need. Make sure they are oil & heat resistant and rated for high pressure. The factory seals are squishy and weak and should be replaced with strong seals with the metal jacket and spring. They look like tiny front main seals.
Old 01-01-2021, 10:38 AM   #8
5t341tH
5t341tH's Avatar
Thanks. Only thing is, when I took apart the throttle body it looks nothing like the SR or KA one. One one side, it's sandwiched under a brass plate. The other side is behind a bearing. I don't have replacements for those parts so I didn't want to take it apart any further and risk not having a working throttle body at all. Wish I had an extra to mess around with instead
lexus baby
