Old 09-13-2020, 06:28 PM   #1
tb13
tb13's Avatar
tb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to behold
SR Turbo Oil Feed Issue
I recently picked up a complete SR that had been sitting for quite sometime and found it has a stripped oil feed. This isn't a big deal, but upon further inspection I found the hole to the oil passage is incredibly tiny compared the the two other blocks I have and 4 others friends checked.
The picture below is what the engine in question looks like inside the turbo oil feed, you can tell the threads have seen better days and the very small hole leading into the oil passage.
Original full res image
This image shows what every other SR I have referenced looks like.
I have verified the block is a DET block, not a drilled/tapped DE block. I am wondering if anyone has seen something like this? I can't tell if there is a broken off fitting in the hole, but before I start drilling into it I wanted to confirm that this is not normal.
tb13 is offline   Reply With Quote
Old 09-13-2020, 07:06 PM   #2
S14rebuild
From the comparison pics looks like something is in there(looks shallower) but if ur 100% sure theres not. Just drill it open ..grease on the drill bit and go slow, clean up as u go. Help keep shavings out of the oil passage.
Old 09-13-2020, 07:19 PM   #3
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
can you take an off-angle shot of the hole you have so i can see the threads? from the image it looks like a broken off banjo bolt or something.
preliminary thoughts are, someone welded the hole shut then drilled a smaller one to act as an oil restriction for a bb turbo.
zombiewolf513 is offline   Reply With Quote
Old 09-13-2020, 07:30 PM   #4
S14rebuild
Noones welding that precisely in there lol
Something was broken off in there....reverse drill bit will solve this
Old 09-13-2020, 08:13 PM   #5
zombiewolf513
lol idk people do some weird shit. that was just a shot in the dark, cant really tell whats going on with the threads. if its something stuck in there yeah extraction bit. easy.
Old 09-13-2020, 08:33 PM   #6
tb13
tb13's Avatar
Thanks guys, it was really confusing me, but broken off banjo seems like the case. I'll try to get it out tomorrow with a small reverse bit/extractor and see what happens.
Old 09-15-2020, 08:10 AM   #7
jedi03
a small easy out should get it too...i agree looks like something broken off in there
Old 09-15-2020, 06:10 PM   #8
TheRealSy90
TheRealSy90's Avatar
Could be a broken off end of an AN Adapter/restrictor.
Such a good signature.
Old 09-29-2020, 06:41 AM   #9
ApexAutoParts
ApexAutoParts is an unknown quantity at this point
I as of late got a total SR that had been sitting for at some point and discovered it has a stripped oil feed. This is anything but a serious deal, yet upon further investigation, I found the gap to the oil entry is unbelievably minuscule looked at the two different squares I have and 4 other companions checked.
Regards,
auto parts store
ApexAutoParts is offline   Reply With Quote
