Old 09-13-2020, 10:26 AM   #1
Sr20probs
Sr20probs's Avatar
Sr20probs is an unknown quantity at this point
Sr20det won?t even try to start
Hey guys I have a freshly rebuilt sr20det that is timed correctly, has spark and fuel but it?s not even trying to fire. When i test the spark with my megasquirt it?s great, but when I crank it with the plug out it sparks every so often. Grounds are good. Is it the crank angle sensor? I?m at a loss at this moment.
Sr20probs is offline   Reply With Quote
Old 09-13-2020, 11:46 AM   #2
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
check the spark plug gap?
zombiewolf513 is offline   Reply With Quote
Old 09-13-2020, 01:37 PM   #3
Sr20probs
Sr20probs's Avatar
Yes the plugs come .032 that wouldn’t cause it to not start would it?
Old 09-13-2020, 01:46 PM   #4
S14rebuild
The spark plug only fires when that cylinder is at tdc compression stroke. Not suppose to fire nonstop
Engine is fresh rebuilt?.... check mechanical timing and then make sure ur CAS is intalled properly aswell
Old 09-13-2020, 02:09 PM   #5
Sr20probs
Sr20probs's Avatar
Mechanical timing seems to be perfect, I used the mazworxs timing chain tool and put so much patience into it. I have a picture too it lines up perfect. It’s a red top and when it’s lined up the cas lines up with the notch on the right.
Old 09-13-2020, 03:48 PM   #6
S14rebuild
Maxworks timing tool only shows the cams... balancer mark and from timing cover pin need tobe lined up, thats if the chain is on correctly on the crank sprocket.
As for the cas
https://frsport.com/How-To-Set-Crank...gine_t_25.html
Idk about notches..just dots.
Old 09-13-2020, 03:56 PM   #7
Sr20probs
Sr20probs's Avatar
Yes crank is properly lined up on the crank sprocket I made sure of that because I had it jump a tooth when I resealed it and went to line up the marks. I couldn’t get it. When I took off the timing cover I realized it jumped a tooth so I redid it very carefully and it lined up perfectly. It was on an engine stand when this happened.The crank lines up on the second mark with the dark links on the dots in the correct Way. The timing chain has about a 1/4” slack as according to mazworx instructions. I believe the CAS is lined up right. Am I wrong?
Old 09-13-2020, 04:30 PM   #8
zombiewolf513
post the pictures of the mechanical timing.
Old 09-13-2020, 05:05 PM   #9
S14rebuild
Originally Posted by Sr20probs View Post
Yes crank is properly lined up on the crank sprocket I made sure of that because I had it jump a tooth when I resealed it and went to line up the marks. I couldn?t get it. When I took off the timing cover I realized it jumped a tooth so I redid it very carefully and it lined up perfectly. It was on an engine stand when this happened.The crank lines up on the second mark with the dark links on the dots in the correct Way. The timing chain has about a 1/4? slack as according to mazworx instructions. I believe the CAS is lined up right. Am I wrong?
With no pics how would we know?
Old 09-13-2020, 05:13 PM   #10
Sr20probs
Sr20probs's Avatar
for some reason its not uploading the picture. i emailed it to myself to upload it. any ideas? not to sound weird but i can leave my email or phone number to send it. its really getting annoying lol.
Old 09-13-2020, 05:16 PM   #11
Sr20probs
Sr20probs's Avatar
978-944-5062 text me and i can send the picture and get an opinion
Old 09-13-2020, 05:20 PM   #12
S14rebuild
imgur upload or imageshack..copy and paste the link....
I dont text dudes...
Old 09-13-2020, 05:28 PM   #13
Sr20probs
Sr20probs's Avatar
https://imageshack.com/my/images here i didn't even know about these websites. lol just lookin for a answer hopefully this helps.
Old 09-13-2020, 07:07 PM   #14
S14rebuild
Def dont see ur pics..... gotta post the specific links to that picture...
Old 09-13-2020, 07:31 PM   #15
Sr20probs
Sr20probs's Avatar
https://imagizer.imageshack.com/v2/3...922/1jYOc7.jpg
Old 09-13-2020, 08:23 PM   #16
zombiewolf513
reposting for a
Old 09-14-2020, 02:57 AM   #17
Sr20probs
Sr20probs's Avatar
Is this wrong?
Old 09-14-2020, 04:52 AM   #18
S14rebuild
Looks good.
What about ur cas? Posted the link to install properly....is that correct?
Old 09-14-2020, 12:36 PM   #19
Sr20probs
Sr20probs's Avatar
https://imagizer.imageshack.com/v2/3...924/J4bNKi.jpg Here you go hope this is good as well
Old 09-14-2020, 04:54 PM   #20
S14rebuild
Thumbs up...
So spark, fuel, air, compression......what u missing?
Old 09-14-2020, 05:42 PM   #21
Sr20probs
Sr20probs's Avatar
Update, fuel only sprays with megasquirt but not when cranking. Explains why it won’t start. Any ideas?
Old 09-14-2020, 05:51 PM   #22
S14rebuild
Guessn u have a laptop accessing the megasquirt setup
Are u seeing cas triggers?
Injectors all share a common wire color for 12postive with key on
Ecu grounds each injector to fire it
Old 09-14-2020, 08:25 PM   #23
Sr20probs
Sr20probs's Avatar
Thank you I’m gonna have to try that.
Old 09-14-2020, 09:16 PM   #24
Krazy719
Krazy719 is an unknown quantity at this point
I would definitely try retiming the ignition timing you can have it give you spark but not firing in the right order give it a shot literally had this problem today
Krazy719 is offline   Reply With Quote
Old 09-15-2020, 03:25 AM   #25
Sr20probs
Sr20probs's Avatar
How would go about doing that without questioning it haha
Old 09-15-2020, 06:32 AM   #26
Krazy719
Go ahead & put the motor on tdc then pull off the cap on the distributor check if the rotor is on cylinder one if it isn?t pull the distributor out & reset it & if it is on cylinder one I would still pull it out & reset it it could be off a tooth & not firing right best of luck man also what you can do is put some starter fluid in the intake if she back fires from it it?s definitely your ignition timing if you believe everything else is set on timing correctly
Old 09-15-2020, 07:06 AM   #27
Sr20probs
Sr20probs's Avatar
The mechanical timing wouldn’t line up if it was wrong correct? And everything seems good. Has to be that.
Old 09-15-2020, 08:33 AM   #28
Krazy719
No the distributor timing is separate so who ever put it together put the mechanical timing correct & the distributor timing would be separate so don?t mess with the mechanical timing just the distributor timing
Old 09-15-2020, 10:04 AM   #29
S14rebuild
Theres no distributor, cap, or rotor.... its an sr20det
I posted you the link already on how to install the cas CAM ANGLE SENSOR
follow it
Old 09-15-2020, 10:05 AM   #30
Krazy719
Dang that suck I was going off of my Kat but definitely sounds like the cas
