Old 06-17-2020, 08:31 PM   #1
cjmo
cjmo is an unknown quantity at this point
1995 240sx Cranks, Starts, and dies and continues to crank
Hi all
I have a 1995 Nissan 240sx (S14) with a KA24DE running in it with a J7 ECU, or a 1997 Automatic ECU. When I first got the car it was running but since, the head gasket blew and so I've replaced it. I've rebuilt the head of the motor and seem to have compression in each of my cylinders as well as spark with brand new spark plugs and coils. I don't think I'd hear the engine turn over a few strokes if it wasn't igniting properly. I've tried realigning my distributor twice and nothing seems to work. The error codes I have go as follows
13 (Engine Coolant Temperature Sensor) (I've replaced it and don't know why that's still not working, maybe wiring)
41 (Intake Air Temperature Sensor) (I haven't had one working previously)
42 (Fuel Temp Sensor) (Not sure about this one)
81 (EVAP Bypass vacuum) (The EGR has been deleted previously, don't know)
83 (Manifold Absolute Pressure Sensor) (This one I don't know how to fix, assumed it meant there is a vacuum leak somewhere)
84 (TCM Diagnosis communication malfunction) (Was told you get this error because it is an ecu for an automatic on a manual)
87 (EVAP Canister Purge) (don't know)
93 (EVAP)
13-2 (MAP/BARO switching valve)
Link for pics -> https://www.nissanforums.com/threads...-crank.273854/
Let me know which sensors you think I should replace/how to bypass any codes
I've tried a new mass air flow sensor, it hasn't worked.
cjmo is offline   Reply With Quote
Old 06-19-2020, 07:50 AM   #2
jedi03
if you had the head off i would recommend check your physical timing is 100%, make sure you get spark an fuel as well...ground plug against head for spark *carefully* and pull fuel rail off intake and crank should spray a little
Old 06-19-2020, 10:18 AM   #3
S14rebuild
Heck timing and grounds
Old 06-22-2020, 09:39 AM   #4
cjmo
Update 6/22
So little update:
Got the car running, it turns over. Bad news is it bounces between 1000 and 2000 rpms and doesnt go over 2000 rpms. I'll be trying out that other MAF sensor later to see if it does the trick and makes it all work.
Old 06-22-2020, 08:23 PM   #5
NukeKS14
NukeKS14's Avatar
NukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really nice
Originally Posted by cjmo View Post
So little update:
Sounds more like timing to me too, possibly mechanical. What did you do to get it running? Have you put a timing light on it?
NukeKS14 is offline   Reply With Quote
crank no start, ka24de 5 speed manual, s14
